Question about Malibu Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer
Have a 200 watt low voltage system. currently using 140 watts. tied in one more 10 watt lamp, and transformer shut down, flashed E indicating a problem. Pulled new lamp off system and lights came back on. Have I reached the limit of the transformer?
  • Malibu Master
  • 5,245 Answers
Yes possibly:
Did you unplug transformer before adding light.
Does wire size match distance and gauge requirements?
Copy following link:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Gene
h
Posted on Oct 23, 2013
  • 691 Answers
SOURCE: I just bought a new Malibu Landscape Lighting 200
working with those outdoors transformer I have ran into couple would short the unit out by installing it wrong or exposing to lots of waters/moister. Again, it could also be a factory fault unit, some products will only last only few days before it blow out. It happen and most of those unit have 5 years warranty on them. I would take it back and get another and if it happens again than you may not installing it correctly or installing too close exposing to lots of moister and may short the unit out. I don't recommend trying to fix it still having warranty on them, get a replacement and start over. good luck and i hope that help some
Posted on Jul 10, 2009
gotgeek2
  • 565 Answers
SOURCE: Replacement of on/off trippers for intermatic low voltage timers
These should work:
http://www.nextag.com/timer-trippers/shop-html
Posted on Jan 02, 2010
SOURCE: Malibu 300-Watt Low Voltage Transformer ML300RTW Not Functioning
My power went off at my house. After it came by on how do I reset the transformer to come on automatically?
Posted on Jul 05, 2010
SOURCE: My Malibu 200 Watt Power
There is no fuse and no repair parts
I've been all over the Malibulights.com website looking for anything that might help the large number of people with Malibu questions. The website has very little information and no parts and the site offers no help except the following:
1) Malibu gets the customer money, and other people troubleshoot for their customers
2) When buying a power pack, the total bulb wattage on the line has to match the power pack wattage
10 - 20 watt bulbs = 200 Watt power pack
15 -20 watt bulbs = 300 Watt power pack
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack.aspx
If your power pack is oversized, it will burn out the bulbs and burn out the power pack
3) A power pack makes a humming noise when it has power >>> check your power source if power pack won't work >>> no other troubleshooting is offered
4) Replace burned out bulbs ASAP or the power pack burns out the other bulbs
5) Unplug power pack when working on bulbs [otherwise, the power pack burns out which is why people write fixya asking why their power pack won't work after replacing all their bulbs]
6) Nowhere on the Malibu site does it offer-or-explain burned out power packs or power packs that don't work, but they show plenty of new products for you to buy.
Posted on Oct 19, 2010
SOURCE: Why is my malibu 200
Tripper might be worn down and not pushing switch.
Switch might be broken or worn down.
Improvise by setting timer to override and plug power into cheap plug-in timer.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Posted on Mar 21, 2011
What is the rated wattage for the mastercraft drill
the wattage is on the plate attached to the drill and will still be the same as before you attach a step down transformer to get to the correct voltage
get a step down transformer that has a large wattage rating for 120 volts ( say 1200 watts ) as most 1/2 drills are 750 -1000 watts )
the wattage is for the rated current through the transformer and if the drill is of low wattage , it just gives the transformer a greater degree of serviceability in the duty cycle
Nov 16, 2015 | Audio Players & Recorders
Dusk to dawn sensor for 24 v light system
Malibu transformer is 12 volt AC
They make a photo eye for ML300-600-900 watt units, but not for 75-100 watt units
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire
Gene
Water Heater Timers Save Money
Oct 04, 2013 | Malibu ML200RT - Low Voltage Power Pack...
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
Transformer problem
Malibu power pack has to match total watts of bulbs
15 bulbs each 20 watt = 300 Watt power pack
10 bulbs each 20 watt = 200 Watt power pack
Mar 01, 2010 | Malibu ML200RTW - Low Voltage Power Pack...
Malibu 300watts connected to 4/50-watts spot light and 5/7watts l
sir, you have a voltage drop problem. you make no mention of what wire size you are running to the fixtures or what the voltage is required. I need to know the wire size you have and the voltage required to run the lamps to come to any decision to repair your problem. write me back at tmierzwa@twcny.rr.com and we'll see what we can do.
Oct 24, 2009 | Intermatic 600 Watt Low Voltage...
When controlling a 300 watt cable lighting system
Sounds like a loose connection. If they all fo out, it's at the beginning of the circuit. Check all connections at the start of circuit.
Sep 01, 2009 | Lutron Electronic Low-Voltage...
Low voltage only or can timer be used for 110 v
1 hp= 750 watts
125 vac = 125 volts alternating current, wall outlets
5 amp= 5amps
125vac x 5amps= 625 watts
a timer is a switch with a clock on it. just like a switch in a lamp cord.
Dec 12, 2008 | Hardware & Accessories
NEW 600W L.V.TRANSFORMER DOES NOT PRODUCE ENOUGH POWER
This is more than likely what has happened . I am going to guess that your original low voltage trasformer was a 120 volt .6KW. Or 600watt transformer that has one lead from it to the lights . The newer less expensive transformer is also 600 watts , but the new one may have 2 sets of wire terminals on the back( 4 screws ). If this is the case , you have a transformer that is 600 watts output but it has 2 seperate 300 watt outputs that won't run 600 watts from 1 set of output screws . You will have to seperate the lighting load and may have to run an additional low voltage wire to half of your lights . In other words . Put 300 watts of light on 1 set of 12volt output screws and 300 watts on the other se of output screws .that will solve your issue . Good luck and enjoy your lights again . John
Nov 03, 2008 | Garden
Malibu Intermatic Inc. ML121RT  Low Voltage 121-Watt Power Pack with Timer Logo
172 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
