Question about Avaya 4610SW IP Phone
Avaya 4622 keeps saying "Finding Router" - Avaya 4610SW IP Phone
Will not print
more information please- have you tried re-installing the printer driver to test your data connection to the printer?
Jan 16, 2014 | HP Officejet 4622 Multifunction Inkjet...
Avaya 1616 IP phone doesn't take the router IP when assigned statically. There is no DHCP. It shows Bad router after the phone gets a restart.
bad router means that you assigned an IP in the router section, that can not be found on teh network.
You dont have a DHCP server on the network?
Sep 13, 2011 | Avaya 1616 IP Phone
Hi I buy the new phone AVAYA 1616I, but it does not work, it always "finding router" can you help me onm this?
Hi tung_nd,
I see that your are having issues with your AVAYA, see details below.
* First find out the IP address of your Router.
*Inout that IP address in your AVAYA, this should make you AVAYA detect the Router or Network.
*once the Network is detected then you can set you AVAY for use.
Your AVAYA will need an IP address to connect to this will enable it for use, this should fix your concern.
Make sure that you have all the details that you need to be able to set up your AVAYA like the port number that it wwill be using in the aNetwork.
There will be 2 ethernet ports on the back of your AVAY one will be connected to the Router which should give the AVAY the power to turn it ON and the network connection to provide data transfer, the other ethernet port will be connected to your computer this is where the data from the router goes to if you have files that are shared in the network, and if you are running application from a Network.
I hope that this will be helpful regarding your query.
Have a nice day,
mvincentc
Apr 28, 2011 | Avaya 1616 IP Phone
Does anybody know how to flash the firmware of an avaya 5610sw IP from the VPN to the regular in office
1) Edit your existing 46vpnupgrade.scr file as follows. Don't forget the line at the very bottom of this document!
2) Next set your phone's GROUP back to 0 by pressing the MUTE button (just press it don't hold it down) then enter GROUP on the keypad (47687) and press #.
3) Reboot your phone and the non VPN firmware should be re-installed on the phone.
# Release Date: August 26 , 2007
# 46XX Software Upgrade Script for VPN Capable H.323 IP Telephone
# This file upgrades the following telephones to the
# indicated releases:
# 4620, 4610, 4621, 5610 VPN Build 252
# 5620, 5621 VPN Build 252
IF $GROUP SEQ 0 GOTO NOVPN
IF $MODEL4 SEQ 4610 goto DEFVPN4610
IF $MODEL SEQ 4620D01B goto DEFVPN4620
IF $MODEL SEQ 4621D01A goto DEFVPN4620
IF $MODEL4 SEQ 5610 goto DEFVPN5610
IF $MODEL4 SEQ 5620 goto DEFVPN5620
IF $MODEL4 SEQ 5621 goto DEFVPN5620
goto END
# DEFVPN5610
SET APPNAME i10aVPN23252.bin
goto END
# DEFVPN5620
SET APPNAME i20aVPN23252.bin
goto END
# DEFVPN4610
SET APPNAME a10bVPN23252.bin
goto END
# DEFVPN4620
SET APPNAME a20bVPN23252.bin
goto END
# DEFVPN4625
SET APPNAME a25VPN25252.bin
goto END
# END
GET 46vpnsetting.txt
# NO46xx
# NOVPN
GET 46xxupgrade.scr
Oct 14, 2010 | Avaya 5610 IP Phone
Partner-18D (lucent avaya phone)on the display it
Get yourself 2 alkaline AA batteries, keep the power on, and look for the door on the lower part of the face on the ACS processor module. Pop the cover and replace the batteries.
Carl
Nov 20, 2009 | Avaya 700340193 Corded Phone
How to configure Avaya's IP Phone 5610?
What IP did you give the phone? When it says discover, its looking for the call server, which it is not finding.
Which system is this on? If IP office, you may need to build an IP route in the system for that subnet.
Feb 13, 2009 | Avaya 5610 IP Phone
Wireless-G router not finding networks
the ip address of your computers should be different from the others. you need to use the network wizard in order to have a network of your computer. you need to run the network wizard to all your computers
Feb 24, 2008 | Linksys Wireless-G Broadband Router
Avaya 4610SW IP Phone Logo
237 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
