Question about Acer Aspire 6530-5143 Notebook PC
Acer aspire 6530 bios update fail, What to do now?
    Master:
  • 630 Answers
May be not supported bios version, Internet speed slow, Your devices not match that software. I suggest you go to Acer help store and full technical support provides. If local help contact techsupportmart hear good technician available i hope solved you problem.
Thanks..
Posted on Oct 22, 2013
SOURCE: ACER Aspire 6530 - Windows Vista sound problem
I had the same problem, and it always seemed to be a resource issue. (CPU running near 100%). Somehow my Acer ePower Plan was set to "balanced" and when i looked at the settings for CPU speed when the computer was plugged in, it was set to LOW !!! So, I changed it high, rebooted and it now sounds great.
Posted on Jul 07, 2009
SOURCE: Acer Aspire 1640Z BIOS problem
Dear all,
I also posted this one under "Notebook Bios Problems" which might notbe the correct place. Anyway here it is for you to see and maybe youcan learn from my experience.
Have done a VISTA upgrade with Acers upgrade DVD.
It recommended to upgrade the BIOS - after doing this notebook is dead.
(1 long and 2 short beeps).
If I want to flash a new BIOS with Crisis method which BIOS shouldI use i.e. how do I know if I need the AT or UMA version - how toverify this on the notebook (my version is 1642 ZWLMI)?
I would very much appreciate some help on this - thank you
LATEST NEW - it WORKS AGAIN:
I was a little bit worried when I started icon_sad.gif but later I was all smiles icon_biggrin.gif icon_biggrin.gif
So a BIG thanks to everyone who posted possible solutions here in this forum:
1: I bought a NEC model UF0002 USB floppy Disk Drive Unit.
2: Downloaded the zip file from the ACER homepage with the BIOS
(chose the one that should be the correct version for VISTA:
It contains 2 WHP files: ZL9A3A24.WPH and ZL9I3A24.WPH as I
learned from NoClaim's post I chose the ZL9I3A24.WPH.
3: Downloaded the zip files with the Crisis recovery zip-file (See d0gi's
post: http://www.rechner.org/b1800.html ).
4: un-zipped the files
5: copies the file ZL9I3A24.WPH into the crisis directory - deleted the
BIOS.WHP that was allready there. And renamed ZL9I3A24.WPH
to BIOS.WHP.
6: ran the WINCRIS.EXE program (did an unbootable format of the floppy)
7: I now had a recovery floppy.
8: all steps above obviously done on my desktop PC.
9: removed battery from my ACER 1640Z laptop
10: unplugged powercable.
11: inserted the USB floppy in one of the USB ports on the laptop
12: pressed the <fn> and <esc> keys
13: plugged the powercord
14: Turned on the laptop
15: waited a bit - lights came on on the laptop (no beeps)
16: waited a little longer and the light on the floppy came on
17: waited still a bit longer until I could hear the floppy was working
and then I let go of the keys <fn> and <esc>
18: after a while there was no activity on the floppy any more and
shortly after the laptop shot down.
19: the laptop started up again on its own and IT WORKED
20: THE LAPTOP IS BACK AND THANKS TO ALL OF YOU I SAVED A LOT
Posted on Jan 13, 2009
  • 18 Answers
SOURCE: Bios reset on a acer aspire 1640z
To reset the bios in a laptop you need to unplug the power supply and remove the battery. Once you do that press and hold the power button for 45 seconds then put the battery back on and plug it in and then try starting it. Everything in the bios will be reset to the factory.
Good Luck
Posted on May 04, 2009
durtopian
  • 408 Answers
SOURCE: Acer Aspire 5100-USB, Touchpad, keyboard all quit working.
Bad motherboard or a failed attempt at a bios upgrade/flash
Posted on Jul 28, 2009
drifterK
  • 4924 Answers
SOURCE: acer aspire one 1640Z XP BIOS RECOVERY WON'T READ USB WITH BIOS
if I understood correctly you have the recovery software loaded on a stick flash drive and you want to boot from usb to restore the pc .....There are a few things that you have to know about to do that ...
first you have to go to bios and enable boot from another device ....other than hdd /cd or flopy ... for some elder bios this isnt even a choice ..or ..if it is ,,it will be as a sub options into the hdd...choice ..
another thing that you have to keep in mind ..is that you have to disable the other options to force it boot from this one ...or ....to press f8 on boot and manually choose the usm or the stick name that will appear on boot devices...
the most important thing is that if you already formatted the hdd it does notr have a usb driver loaded and that why willl not see the device ...also the device you are using to boot ...has to be specially formatted to be bootable ....this is made ussualy with a hp format tool ...and it is explained in more than one places on the net ...just look for making a boot-able stick (usb device)
in short ...make sure the sticvk is boot-able ...second the pc ha s teh capability to boot from another device ...and this is a feature that you already enabled like first boot device ...
than things will be easy ...it will ask you to press any key to boot from the usb ...and continue like an installation from the cd ...
if you cannot do it ...I recommend using a cd ..or an image that you will ***** in a virtual cd ...for those that do not have cd drive ( use daemon tool )
Posted on Dec 21, 2009
How reset bios password
cannot get into bios, system disabled 08414 acer aspire 6530, plz help
Jan 10, 2014 | Computers & Internet
The volume on my acer aspire 6530 is to low although the control
if you have external speakers, try adjusting the volume there!
If you don't, then click on 281bf5a1-868f-4ef8-aedd-d25642705e45.png icon, click 'Mixer', adjust the levels.
Or click on Start, write in "Sound",4b2d9ebd-91e4-43cf-8490-3de18c6bc30c.png
Adjust the settings for device/s you use to hear sound.
Dec 18, 2013 | Acer Aspire 6530-5143 Notebook PC
The crystal eye web cam on my acer aspire 6530 can not be found...it was working for a little while when I downloaded skype...then it just stopped. How do I get it running again?
You need to redownload the drivers for your crystal eye web cam. Go to this link: http://us.acer.com/ac/en/US/content/drivers
When you get there, select "Notebook"...then select "Aspire". Then scroll down and select Aspire 6530. Then where you see "Operating System", select your operating system (ex: XP, Vista, or Windows 7). It will then show all the drivers for your operating system...scroll down until you see the camera driver software and then download and reinstall it. Hopefully this will help...good luck.
Aug 11, 2011 | Acer Aspire 6530-5143 Notebook PC
I brought an acer aspire 6530 for my wife but it seems to run far slower than the old machine and it keeps switching itself off.
I think that Aspire series have some kind of BIOS problem, so it must be flashed with newer version.
But, you could lose your guarantie for that stuff. So best way solving this is to give it back to store. Let them solve this problem.
Jan 29, 2010 | Acer Aspire 6530-5143 Notebook PC
I have a big problem....i have an acer aspire 6530g and i recently installed a bios update which screwed up my cp.so i went to reinstall windows xp pro and it wont reconigze any of my partitions..i hit...
You need to have your motherboard resetted. There is a jumper on the board that say reset. Move the jumper to that and turn it on for a few seconds. Then turn off and put the jumper back to the original spot.
Oct 17, 2009 | Acer Aspire 6530-5143 Notebook PC
I cant enable the wireless on my acer aspire 6530 can you please help
Try going to the device manager and uninstalling it. Then restart you laptop and let it re-install.
Sep 02, 2009 | Acer Aspire 6530-5143 Notebook PC
Acer aspire 6530 Tuba
I had similar problem and it seemed to be the headphone jack. Inserted my headphone jack a couple of timesand it started working again.
Mar 31, 2009 | Acer Aspire 6530-5143 Notebook PC
I need a 48 Bit BIOS update for my Aspire 1712SMI Notebook to run a larger HD. Please provide me with a download URL on the ACER web site where I can download it. If you do not have this BIOS, who has a...
Go here. Once here, select notebook, Aspire 1710, then bios. Follow the instructions carefully....a failed BIOS update can render your computer useless.
Thanks and please take a moment to rate this as fixya.
Jul 06, 2008 | Acer Computers & Internet
Acer Aspire 6530-5143 Notebook PC Logo
243 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
