Toshiba laptop wont boot correctly. Upon start up it flashes blue screen. Does not recognize optical drive to try to fix windows 8 or reinstall windows 8.1.
    Problem Solver:
  • 14 Answers
Sounds like the hard drive has an issue. Do you hear a very faint clicking sound when it tries to boot up? put your ear near the front of the laptop, bottom of keyboard area and listen for a clicking sound. if you hear a click click click click sound repeating continuously, its a failing hard drive. If you hear ths sound, you will need to buy a replacement hard drive. Replacing it is easy. Turn your laptop upside down and look for the small door that houses your hd. Unscrew the door and take hard drive out. Now you take this hard drive to Staples and ask them for a replacement. Once you know what you need, whether Sata or IDE hard drive, you can buy a replacement cheaply on eBay or buy it from any computer store. pop the hard drive back in and then you should be able to install a new operating system on the laptop. If you do not hear a clicking sound, then you may have a corrupted windows boot. Have you tried booting in safe mode? as you turn the power on, hold down the f8 button. You will get a screen asking if you want to boot in safe mode. Select, safe mode with networking. If it boots normally in safe mode, you can then put in your windows cd and do a repair. If you cannot boot into safe mode, and you have tried replacing hard drive, but cd/dvd is still not working, then you may need o take it in or diagnostics. You can buy very cheaply on eBay, a connector that will allow you to connect your hard drive to another computer via USB. This will allow you to test the hard drive and also possibly get data of of it, provided the hard drive is not too badly damaged. I hope this helps.. Please ask any questions you might have.
Posted on Oct 22, 2013
5 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: New Laptop Optical Drive Causes 0203 failure ide #2 error at boot
it's in the bios, hit F2 when it's booting, and go to drives, and set it from there..you will see them..you may need to turn them off, and then restart, then F2 again, and then turn them back on.
check your computers warranty here 4 FREE
Posted on Mar 13, 2008
lolita
  • 385 Answers
SOURCE: Toshiba Satellite P105-S6084 Laptop Boot Problems.
This happens sometimes due to faulty memory or faulty software that causes errors in filesystem. You need to obtain a Windows XP with the correct edition that is installed and boot into it. Then go into Recovery Console and wait for the c: prompt asking which windows you want to log into. Select 1 for C: windows. Then it will ask you for the administrator password. Enter it or press enter if there is no password. Type chkdsk c: /r at the c:\windows prompt and leave to run. It will take about 15 -30 mins. When finished, type exit and press enter. Press ctrl+alt+del to restart computer.
If problem is fixed, computer should start up fine now.
If you still have the problem, let me know so we can try something else.
Thanks,
Lolita
Posted on Jun 18, 2008
SOURCE: wont boot to start up windows
1. Disconnect the AC adapter from the laptop.
2. Remove the battery.
3. Press and hold the power button for about 30 seconds then release it. (You will not see anything happen)
4. Connect the AC Adapter to the laptop. Make sure the AC Adapter is plugged in.
5. Turn the computer on as normal.
6. Once Windows boots, insert the battery.
If the notebook still does not power on, we recommend the notebook be serviced by our authorized repair depot. You can set this up for service yourself by going to www.acerpanam.com; click on the link for Depot Repair. If you are out of warranty, or you would rather do this via phone, please contact Acer Technical Support at 1-800-816-2237, Mon-Fri 7am-9pm CST and Sat-Sun 8am-5pm CST excluding holidays
Posted on Oct 04, 2008
SOURCE: toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
Posted on May 20, 2010
Wont go past boot menu
your dvd rom or your disc might not working properly. there can be one more problem that you RAM is creating problem just pull out RAM and clean it then insert it and do the process again.
Feb 07, 2014 | Toshiba Satellite M115-S3094 Notebook
I have a toshiba satelite L655-s5117 laptop and it won't boot up even when i try and boot from windows 7 disk it won't
Probably a faulty hard drive. go into the setup screen and verify the HD setting is correct. save your settings and reboot. if this doesn't solve it, then take out battery and disconnect power, remove hard drive and reconnect. try reboot. if none of that works, then replace hard drive and reinstall OS.
Mar 10, 2013 | Computers & Internet
MSI N1996 motherboard with 640gig sata drive / sata DVD ROM / NVIDEA Graphics card G7500 - wont boot up windows 7 even though i install new sata drive and try new installation it wont boot up! Pre...
hi there.
this is all the info i can find.plus try the link at the bottom might help you out some more.
If your computer blue screens when you turn it on, then loading in safe mode could help you get into your computer to sort out the problem. To boot safe mode in Windows 8: Hold Shift and press F8 upon startup to open Recovery Mode. Select See Advanced Repair Options, press Troubleshoot and select Advanced Options.
How to fix the blue screen of ***** - Cheeky Munkey
getting blue screen error Google Search
Nov 17, 2017 | Intel Motherboard
I have a 8 Gb Lacie Moskeyto flash drive, without ejecting it from my laptop, my laptop was left to sleep. Upon starting up my laptop, my 8 Gb Lacie flash drive, was left "Unrecognized" by...
When you switch on your computer press the F12 key that should take you to the boot screen , scroll down to the usb drive and press enter it should boot up to that .
Nov 02, 2017 | LaCie MosKeyto - USB Flash Drive - 16GB...
When starting up my eeepc 904hd it takes me to the screen asking if i want to start as normal or use safe mode or continue you from an earlier point wean i click any of these it comes up windows then the...
try to choose last known configuration that worked...is the second from the bottom ...and if it gives you blue screen again ..it measn that it is a hardware issue ..try to go to bios when you start it ..by pressing F2 immediately ..and there choose optimal factory defaults ..and than F10 to save the changes...after that ..start it again and try to see what happens ..if it still do not what to boot you have to try reinstalling it ...but go to a professional if it is a kinda eee with no optical drive ..cause you need a boot-able memory flash drive....to reinstall it ..
May 12, 2010 | Acer Aspire One PC Notebook
Dell latidude d610 wont start properly
Can you select "safe mode" from the boot menu? As much as I hate to recommend it, I think you should wipe the hard drive and reinstall Windows (I hope you backed up everything of value on your computer). If you can't successfully reinstall the operating system, then I'd say, in all likelihood, you have a defective hard drive which would need to be replaced.
Feb 11, 2010 | Dell Latitude D610 Notebook
How do you reinstall Windows XP on an Toshiba Satellite A60 PC Notebook?
1. boot your PC or laptop from the Windows XP CD (To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer).
2. You will see "Press any key to boot from CD" displayed on the screen, at this point press any key to start the computer from the Windows XP CD.
3. You will see the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4. Read and agree to the Microsoft Software License Terms, and then press F8.
5. Follow the instructions to select and format the c: partition where you want to reinstall Windows XP.
6. Follow the remander of the instructions on the screen to complete Windows XP Setup
7. Reinstall any drivers which are required.
8. Reinstall any software programs which you need.
9. copy your data back to the drive.
Jan 07, 2010 | Toshiba Satellite A60 Notebook
Freezing in 'safe mode'
Have you tried accessing the bios to set boot order? It may be trying to load from the hdd before the optical/usb drive.
During the flash screen, press F2 (though it can vary by maker) and change your boot order to load the USB drive first.
Hope this helps!
Apr 29, 2009 | ASUS Eee PC 1000H Laptop
Re installing windows xp
You will need to enter the boot menu at start up and select boot from CD, or set the CD drive to boot before the hard drive in the bios or utilities. When you first start the machine there will bw a Toshiba screen, on this screen it will tell you what to press for boot menu or utilities. Some machines zip right through this screen so you'll have to be quick. After you get it to boot from CD, make sure the disc is in upon start up and you're good.
Jun 28, 2008 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
