Question about Farouk Systems Chi Flat Iron
MY chi farouk flat iron turns on but won't heat up. When I turn it on it says 56 hours of use. I've tried restarting it-nothing. What is going on?
How do I fix Chi flat iron if it is not heating up?
Hi is there power to the element if there is then I would say the Element is to long new and needs a replacement
Hope this helps
David
Aug 16, 2014 | Farouk CHI Royal Treatment Gold Ceramic...
Where can I get a chi flatiron fixed in the Nashville, TN area? One of the ceramic plates broke lose.
I don't know about in Nashville, but you can send it in to www.flatironrepairs.com. Should be fixable.
Feb 06, 2011 | Chi Nano Digital Ceramic Flat Iron 1.25...
My CHI straightener has a GFI plug that needs replaced.
look up leviton 16592 on amazon or something similar. I just had to replace this on a sedu iron. About $20, but cheaper than a new iron.
41x1vrxnoql._sl500_sl135_.jpgtransparent-pixel._v192551059_.gif Leviton 16592
Jan 23, 2011 | Chi Nano Digital Ceramic Flat Iron 1.25...
Where can I get my Chi Flat Iron fixed. I only used it 3 times but had the iron over a year because I have my hair ironed at the beauty shop due to its length. I bought the Chi to do touchups and am...
Chi Flatiron Repair Fix it Yourself User Photos
Most appliances come with manuals that give you company contact information. My guess is the iron is out of warranty. As irons have high voltage components, do it yourself is not advised. Staying alive is better than fixing an iron. That said, the above link even tells you how to take it apart. I have a hunch that good parts would have to come from another broken Chi iron. And where would you get that! Maybe someone on the above link can be contacted. Alas, you simply wanted a reliable business that might check this out. I doubt you want to pay a technician for his time in taking this apart. I wish you well.
Jun 04, 2017 | Chi Nano Digital Ceramic Flat Iron 1.25...
Brand New Chi flat iron! No light, no heat, no reason!!!
Have you checked it on different plug ins? I realize this sounds silly, but I had the same problem once and had a fit...all to find out my plug in had tripped. Bathrooms usually have those plugs that have the little button to reset the current. Maybe if you try that and different plugs.... If not, I would take it back as it is obviously defective. May have a bad connection, short, bad fuse, etc, and you would not want it anyway because it would not be safe.
Jan 05, 2011 | Farouk Original Chi 1 Inch Ceramic Flat...
Farouk Systems Chi Flat Iron Logo
26 people viewed this question
Top Farouk Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Farouk Health and Beauty Expert? Answer questions, earn points and help others
