Question about Sony PVW-2800 VCR
Loading motor timing out.threading at times. - Sony PVW-2800 VCR
    Champion:
  • 236 Answers
Tell us step by step what happens.
Posted on Nov 16, 2013
My bobbin will not load after my needle broke.
More than likely, when the needle broke, it knocked your machine out of time, ie the needle arrives at the bobbin at the wrong time to intercept the bobbin thread. Search for sewing machine timing or take it for service.
Apr 20, 2017 | Sewing Machines
Normal tension for kenmore model 158.12112?
Remove the thread from your machine. Install a brand new needle.
Rethread the machine from the beginning being sure to ALWAYS RAISE the presser foot when threading the upper thread. Make sure the thread path is correct and that the bobbin is loaded and threaded correctly. Set the upper tension to the midway point--the factory standard, but every machine will probably require some tweaking.
If, after testing your machine, stitches are still not being formed, it is quite possible the machine is out of time. Search for sewing machine timing or take it for service.
Mar 21, 2017 | Kenmore Sewing Machines
I have brother xl2620 changed thread and now won't pick up thread from bobbin. Have cleaned everything still won't work
Try a brand new needle. Check that the bobbin is loaded and threaded correctly. Change the type of thread you are using--Avoid old or bargain bin variety. If these recommendations don't help, the machine may need its timing fixed. Search for sewing machine timing or take it for service.
Feb 09, 2017 | Brother Sewing Machines
Problem with singer 590c. Thread bunches up & breaks or the bobbin thread wont sew. 1 time happened to get everything right & it sewed beautifully.Today I cant get it to pick up the bobbin thread.
Make sure to use a brand new needle.
ALWAYS RAISE the presser foot when threading.
Unthread and re-thread from the beginning.
Verify the thread path is correct.
Set the upper tension to midway between High & Low numbers.
Verify the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly and check the result. The upper tension can be tweaked so the upper & bobbin threads meet in the middle of the fabric.
If it is still not working properly, the machine may be out of time and require service.
Nov 20, 2016 | Singer Sewing Machines
Embroidery machine bobbin not picking up thread
If you thread is coming out all tangled continue.
I Had this problem and found I had missed one leg of the threading.
I had an experienced seamstress look at our portable and could not get bobbin working. I took thread and redid it ,seems I had missed leg that went down.
she did to now all is well.
Sep 21, 2016 | Sewing Machines
WHY??!! *Check if thread is entangled. Check if needle is bent. So far as I can tell everything is fine, used new bobbin, new needle, still getting error. How do I know if the motor has become locked
Time to take it in and have the repair tech service & clean upper tension assembly. When you clip/ change threads be sure not to pull the thread back out of tension assembly. Snip thread at spool, raise foot to release tension and then pull the short thread out from the needle. The Automatic tension is very delicate and pulling thread out backwards can cause thread/lint build up and problems like your having. Sal the Sewing Gal
Oct 30, 2015 | Baby Lock Ellure
I was sewing with elna machine and ran out of thread. This caused the thread to ball up underneath and "jam" the machine. I cleared it out and rethreaded it, but now the top thread doesn't catch the bobbin...
it is possible that the sewing machine has a timing problem, but check to see if the needle is inserted correctly into the needle holder
make sure the bobbin is inserted correctly into the bobbin case if the machine has a top loading bobbin
if the machine has a side or front loading bobbin also make sure the bobbin case is inserted correctly into the machine.
and also make sure the top thread has not come off the thread take up lever
Aug 20, 2013 | Brother XR-65t Mechanical Sewing Machine
Timing chain noise 2007 650 can am outlander
So just unscrew the black plastic screw until it unseats frombthe threads but not letting it come out completely the three turns clockwise while not in the threads then screw it completely in?
Sep 28, 2011 | Polaris ATV
Lower bobbin thread tangling
You need to adjust the tention on you thread bobbin and on the needle....also, check to see if the needle is touching the plate or the foot.
I have had this problems too. Most of the time it is just a simple adjustment and cleaning.
Good Luck
Aug 02, 2009 | Sewing Machines
Sony PVW-2800 VCR Logo
42 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
