Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I cannott connect my kodak ESP1.2 printer to my new imac computer, i just keep getting a message that says file server will not allow any addittional users to log on surprisingly when i first got the computer i plugged the printer in using the USB cable and it worked fine, then it just stopped, now that dont work either and i am at a loose end on how to deal with it a lll
  • 30 Answers
SOURCE: Printer will not communicate with computers
Whenever I have seen this problem it has usually turned out to be one of the solder points on the USB connection in the printer. Of course it could be a logic board problem as well. Well done for testing your problem so thoroughly (eg trying different cables and machines) but I think it needs a repair agent now unless it is under warranty (or you can solder well). Mind you it's probably cheaper to purchase a new one then to pay to have it repaired.
Posted on Feb 06, 2008
  • 30 Answers
SOURCE: New Kodak EasyShare 5100 will not print!
You might have to reformat your hard drive as there is something in your OS that is hindering the printing.
Posted on Feb 08, 2008
SDtester
  • 41 Answers
SOURCE: 2 Problems: 1) Unable to get printer to print from desktop; 2) Kodak SW won't install on laptop
Download and install the new software and printer firmware from kodak.com (link below - firmware and software is the same for all the 5000 units). Do not use the CD, and Uninstall all previous versions before installing the new software you download from the site.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?operatingSystem=mac_os_x_10_5_x&downloadLanguage=en
I hope this helps. If you still have problems respond to this message with what happens and I will try and get you more help
SDtester.
Posted on Mar 05, 2008
crayzeetrayn
  • 837 Answers
SOURCE: Kodak 5300 printer problem
I would suggest the following :
1) Remove the Kodak printer and all its software.
2) Disconnect the USB cable from the computer.
3) Reinstall the entire software applications for the printer just as if you were installing it for the first time.
4) When asked to connect the printer .. Use a different USB port .. even if you have to switch something out .. but do this step irregardless.
Now what I want to know is ..
1) Can you print from the computer?
2) Black still "gone" ?
Let me know
Posted on Feb 01, 2009
  • 2692 Answers
SOURCE: Kodak AIO 5100 won't work
Hi Kat. Can feel your frustration. Sorry.   The OS (Windows etc.) opens the UI file but I could not find out who provides it. It is a DEVELOPER file.  It is a little over my head but I f you have the VISTA install disk. Save all of your important files, then have Windows reinstall itself. It wil tell you that "their is already a version of Windows installed , do you want to fix it" Say yes. Aftwer that I would again download the files and software I pointed you too and reinstall it. If it still doesn't work . I woudl take the printer back where I had purchsed it from and demand my money back as irt is not a compatable product as you were led it to be.
UI file is a document that implements a single, specific ruleset API for a single, specific client type. For example, one UI file might allow text-based clients (such as Friv to play rock, paper, scissors, while another lets SVG clients (like Gamut) play chess.Clients locate and download UI files through the UI finder.
UI file logic is generally written in ECMAScript according to the ECMAScript API.
Posted on Feb 18, 2009
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From
your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Running an iMac and MacBook Pro side by side - have just brought Pro back from overseas where purchased nad am using it on home server for the first time. Can receive messages in Mail but not send from...
i used to run into this when i was in school. im pretty sure its something to do with the server settings allowing non-administered computers that are running on the server to send out connections or mail for some reason. so im guessing the solution would be where ever you created the server from
Sep 17, 2010 | Apple MacBook Pro Notebook
Need help installing kodak esp-5 printer . I just bought an hp pavilion pc series 2159m. I cannot get printer to work.
Get the software/drivers from Epson http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=12998/12999&product=EKN035324
If you have installed the drivers before connecting the printer to the computer, try a new USB cable and plugging into a different port. If you use a print server or a hub, go for a direct connection. Make sure the printer is online and has good ink.
I hope this helps.
(btw: pavilion 2159m is just your monitor so what OS does your computer have?)
Apr 11, 2010 | Kodak ESP 5 Printer
Need router number
i can only help with #3, a good printer for imac under $100 is any of the hp photosmart line
Dec 01, 2008 | Dell Inkjet 720 Printer
''Twain is Missing'' keeps coming up - can't scan from printer
Download appzapper , you get 5 free goes with it. Drag your old HP software onto it and it will find all the hidden files. Zap it. Hopefully this will have delete all HP related files.
Download the latest files from HP for your Mac. If you do this first AppZapper will delete this as well, so you'll only have to download it again.
So basically, you're deleting all the old files for HP Deskjet 5510 printer and installing all new ones.
Nov 10, 2008 | Apple iMac G5 Desktop
SDtester.
Mar 04, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Connecting printer to SBS (Small Business Server)
You can physically connect the printers to the server and share it from there or leave the printers connected to your computer and have the server connect to them via a Local Port which routes to your computer!! To do the Create the local ports you'll need to 1.) share the printers on your pc 2.) Go to the server and go to printers in control panel 3.)Click on Add a new printer then next 4.)Select Local Printer connected to this computer; De-select Automatically Detect Printer 5.)Select Create new port and select Local Port 6.)In the enter a port name, enter the full network path to the printer i.e. \\your-pc-name\printer-share-name click ok 7.) Select the drivers for that specific printer(if its not there click on have disk then browse to the drivers to install them) 8.) Continue through the installation until finish) 9.) Repeat steps for additional printers Keep in mind that your computer still needs to be on! You can check to see if your printer support a network card to make them fully network printer you can add them to the server this way and only the server would need to be on! Or you can also get a print server(Device that makes regular printers into network printers). Now when it comes to the scanning, i don't know of any way to share a scanner with just windows alone, but there are third party software that allows you to do that Check out http://www.remote-scan.com/ There are also printers that sorta do the scanners sharing by automatically scanning and putting files in a designated area on the network! Hope this was helpful regards, babb
May 02, 2007 | Canon LaserBase MF5650 All-In-One Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
32 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
