Question about Bulldog& Remote Alarm System With 1-wire Hookup
Bulldog remote starter RS82 will not start car
  • 112 Answers
Does it try and do anything ?
Posted on Nov 07, 2013
4 Suggested Answers
  • 27 Answers
SOURCE: No range for my Bulldog Remote Start.
Get a Viper 5900, it has a 1 mile + range
Or a viper 5601 has a 2000 ft range.
Bulldog is DIY and entry level stuff. You cant expect much from them.
The wire antennas work the best when they are stretched out. Not wadded in a ball or in a loop. If you have to loop it use figure 8's. Try streatching it up the "A" pillar and in the headliner across the top of the windshield. Also, do not ground the antenna, and let the end hang.
Also check your hot and ground connections. Make your ground at the kick panel sheet metal. Do not use a factory ground or a metal bracket in the dashboard. Do use a file or sandpaper to buff the ground site to the bare metal.
Guy
Posted on Jan 10, 2009
  • 1596 Answers
SOURCE: Bulldog deluxe 500 doors will not operate with the remote
Bulldog has it BAD that Way I have seen this More than Once I nstalled one In A Chevy Blazer and 7-8 Months Later it Started "STARTING ON ITS OWN There HELP LINE NEVER HAD An Answer for Me So I Disconnected it Keep Tryin or Send it Back To them Sorry Not So Helpfull I Just Would Disconnect it
Posted on Feb 12, 2009
  • 139 Answers
SOURCE: put an rs82 bulldog remote starter in my 2005 town and country, and after 11 seconds it stops and re engages the remote starter and stops after 11 seconds and stops completely
It sounds like the RS82 is not getting a proper tach signal. If you are using tachless mode, the 12 volt constants may not be providing the desired signal. Recheck your connections to ensure that they are solid. The high amperage wires should be soldered. You will need to connect the tach wire if the connections are good. The tach wire can be connected to the negative side of the ignition coil's blue/brown wire or the blue/green wire at the PCM or you can use any one of the uncommon colored wire at a fuel injector.
Posted on Oct 17, 2012
How do i get my bulldog seurity rs82b to crank longer
If you are using the "tachless" start option and the unit will not crank long enough to start the vehicle, you might want to opt for using the tach wire set up. When selected, and following the Tach set up, the unit will then crank until the engine is producing the preset RPM programmed into the unit's memory.
My experience with the RS82 is favorable, but every now and then, the tach wire must be used to be more reliable, especially on some older model vehicles. I have no knowledge of being able to add crank time such as DEI units are capable of.
Dec 16, 2014 | Bulldog Vehicle Parts & Accessories
Put an rs82 bulldog remote starter in my 2005 town and country, and after 11 seconds it stops and re engages the remote starter and stops after 11 seconds and stops completely
Oct 10, 2012 | Remote Starter with Keyless Entry
Have model #RS82 installed it on a 2001 Dodge Dakota(no alarms or power windows, did not connect red&black#2,blackwhite#3, &black white #3 wire from the 9 pin harness. After making all connections...
Did you install the hood pin switch? If so, does the blower and dash lights come on when you press the start button on your remote? I have one installed on my 2005 and it works great. I did not install the hood pin switch ( Not the best idea if you take the vehicle to a mechanic for engine repair.) But I shorted the wire as if the hood were closed all the time.
Nov 28, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Bulldog Remote Start Problem
if thats a key resisor bypass i never heard of that, i would check with with bulldog to see if may be a set upproblem
Jan 24, 2010 | 2000 Chevrolet Impala
Ive installed a Bulldog RS82 remote starter on a 2008 toyota camry. The remote starter works fine, the problem I'm having is that the keyless entry remote on the Toyota key does not unlock the doors after...
there is no solution to this, it is factory setup to prevent you from locking your keys in the car when it's running and so the trunk can not be opened by accident
Nov 16, 2009 | Vehicle Parts & Accessories
Feb 12, 2009 | DLX 500 Remote Car Starter
Bulldog& Remote Alarm System With 1-wire Hookup Logo
131 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
