Question about MTX Ford Explorer/Mercury Mountaineer/Mazda Navajo 1991-2001 Thunderform Loaded with 10 Inch Woofer and ... Car Speaker
Upper brake light works, lowers fail to engage when brakes are engaged, but the lights do light up when the turn signal or headlights are turned on.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
First try replacing the bulbs in the corners and see if they work with new bulbs
Posted on Oct 23, 2013
Tip
Check Brake Light Bulbs: All cars have three brake light bulbs that create the...
Check Brake Light Bulbs: All cars have three brake light bulbs that create the brake light illumination affect. If the lower two bulbs fail no lower brake light operation will occur. I know what you're thinking, you might say two brake lights at once? But in reality one brake light went out at a time and you did not notice. People only tend to notice something when they almost run into the back of your car to help persuade them to inform you the brake lights aren't working. Remove either of the brake light bulbs to confirm the bulb is ok or burned. After the bulb has been removed inspect the filament and replace if failed. If the brake light bulbs are ok continue to the next step.
Checking the Turn Signal Switch: Most American cars are designed to have the brake light switch wiring intergraded into the turn signal switch. Because the brake light bulb and the turn signal bulb are one and the same the turn signal switch interrupts the brake light circuit and installs the blinker signal circuit when the turn signal switch is activated. If this switch fails it will not allow the brake light signal through to the brake light wiring. To test for this condition a car repair manual is needed to test incoming and outgoing electrical current. If brake light switch power is present at the turn signal switch but not at any outgoing brake light wires the turn signal switch has probably failed.
on Dec 18, 2009 | Sport & Outdoor - Others
Tip
Both Lower Brake Lights Not Working
on Dec 18, 2009 | Honda Civic Cars & Trucks
2001 Town & country brake lights not working, but the third brake light and tail lights are working. I also just replaced the brake light switch thinking it was the problem, but it wasnt
I think the brake light and turn signal are on the same bulb on these, correct?
If so do the turn signals work?
If they do than I would bet that the turn signal switch itself is the problem. The power for the brake lights is routed through the switch (except for the third brake light that is supplied power directly form the brake switch). The turn signal switch will interrupt power from the brake switch and supply power from the turn signal flasher depending on if the right or left turn signal is engaged.
Sometimes wiggleing the lever or pushing the four way flasher button with the brake pedal depressed will intermittantly cuase the brake lights to work. If this is the case than it is the turn signal switch that is causing the problem.
Feb 11, 2011 | Chrysler Town & Country Cars & Trucks
2002 Jeep Grand Cherokee - Brake lights not working properly. With lights off Driver side no brake light when brake is engaged. With lights on and all rear lights on, engage brake - no driver brake light...
The problem is that the tail lights, light bulbs get too hot and melt the plastic where the bulb socket goes into the lens assembly. On the lens assembly you will see one to three metal tabs where the socket fits into. Lift up the tab a little bit with a screw driver and place a small amount of either metal or plastic underneath the tab so it will get a good connection. It will fix the problem.
Nov 27, 2009 | Jeep Grand Cherokee Cars & Trucks
97 dodge dakota stop lights not engaging, bulbs good
at the brake pedal the is a switch, when you press the pedal moves away from it which turns the lights on
May 11, 2009 | 1997 Dodge Dakota
Turn Signal Problem
check rear lamps, sounds like bad earth (brown cable) to the lamps.
Mar 23, 2009 | 1998 Volkswagen Golf
Faulty turn signals 98 vw GTI
bad ground from the rear tail light
Mar 23, 2009 | 1986 Oldsmobile Cutlass Supreme
Car Audio & Video Logo
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
