Question about Minolta Maxxum QTsi 35mm SLR Camera
Need the battery chamber door - Minolta Maxxum QTsi 35mm SLR Camera
    Novelist:
  • Minolta Expert
  • 357 Answers
Minolta is out of the camera business (and has been for years) try Ebay.
Posted on Oct 25, 2013
Can I replace the latch or change the full internal chamber?
sir,
this part is available with Nikon agency, to replace this you have to open the whole camera, then detach the front portion, it doesn't matter, just a piece of rubber or sponge fix on the battery lid, this will be help full to hold the battery at contact perfectly.
Jan 09, 2016 | Nikon 1 J1 Digital Camera
Where is the memory card located?
The memory card slot is near the battery chamber. There is a small slot parallel to the battery chamber. Check the bottom of the camera. There is a door that can be slid outside to open.
Jun 14, 2015 | Canon PowerShot SD500 / IXUS 700 Digital...
APS film chamber stuck shut. Door won't open when film chamber release button is pressed
Sorry to hear about this issue. If you have a change bag, I would put a few jewelers screwdrivers in it then put the camera in it. With the bag closed up I would attempt to forcibly open the back. With the camera in the bag there is not any chance to expose the film. After the film is removed wind it back into the cartridge. Now send it off for developing.
Good luck,
Cordially,
May 03, 2014 | Minolta Vectis S-1 35mm SLR Camera
Need battery chamber lock for minolta maxxum HTsi plus
I'm assuming you need the whole chamber door. I think it would be pretty hard to find just the door, so I would suggest buying another HTsi Plus just to get the part you need. I looked on Ebay and saw an "HTsi body for parts". It was $30(USD) including shipping, not too bad. If there was a source to purchase just the door, I'm sure it would cost $10-20; so buying another camera body might be a better choice. You could probably buy a decent used/working HTsi for around $60-75. So it is up to you to decide what your best course of action is. If it is the door that you need, they are removed very easily (no tools needed).
Jun 07, 2011 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Hi, I Had Dynax 505si super Maxxum Xtsi Minolta, I enjoyed using it . but only every after 6 months or sometimes 7 months, if im on vacation only. last 4 months last tme i used it and it was fine,,but...
If your door to your battery compartment is broken, there are no parts left to repair it. Film cameras go for dirt cheap used. As long as the camera works, you could tape the door shut. The batteries should last for many months, so taping would be your only option.
Apr 25, 2017 | Minolta Maxxum XTsi 35mm SLR Camera
How do you remove the heater core from a 1997 ford f-150
Heater Core Removal & Installation To Remove:
NOTE: If a heater core leak is suspected, the heater core must be leak-tested before it is removed from the vehicle.
  1. Remove or disconnect the following:
    • The negative battery terminal
    • Engine coolant
    • The heater water hoses at the heater core
      1. Compress the holding tabs
      Remove the A/C plenum demister adapter for_f150_dmstr_adptr_rem.gif
    • The screw
    • The A/C plenum demister adapter Disconnect the vacuum line. for_f150_vac_line_rem.gif
    • Vacuum line Remove the heater core bracket. for_f150_htr_core_brckt_rem.gif
    • The screws
    • The 13 screws
    • The blend door assembly from the case
    • The heater core
To Install:
NOTE: Lubricate the coolant hoses with MERPOL(R) meeting Ford specification ESE-M99B144-B or plain water only, if needed.
  1. Install or connect the following:
    • The heater core
    • The blend door assembly into the case Blend door assembly for_f150_blnd_door_assmbly.gif
    • The plenum chamber top
    • The 13 screws
    • The bracket
    • The screws
    • Vacuum line
    • The screw
    • Engine coolant
Jun 20, 2010 | Cars & Trucks
Model QTsi Maxxum. Need a new battery chamber door. The door is broken off. Any ideas?
The battery door on these models just hooks under a wire next to the battery hole. They can pop off rather easily as they are a small piece held in place by a spring, essentially.
You can often find the part on ebay for a few $ and snap it in place yourself. The same battery door is used by the XTsi, HTsi, STsi cameras.
Its very possible that you did not lock it properly the last time you put in new batteries. Hold the door down while you turn the quarter as you lock or unlock it. Otherwise the pressure of the battery spring will prevent a good lock.
LightspiritPhotography.com
Dec 18, 2009 | Minolta Maxxum QTsi 35mm SLR Camera
Battery chamber door
battery doors are sold on Ebay alot cheaply
Dec 22, 2008 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Audi A4 Y Reg 2001, Central locking
reset you computer, do this by removing the positive battery cable for 10 mins.
Nov 11, 2008 | 2001 Audi A4
Minolta Maxxum QTsi 35mm SLR Camera Logo
53 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
