Question about Ghp Group Inc Ghp Pleasant Hearth 1,800 Sq Ft Wood Burning Stove Heater With Blower,
How to adjust pilot light on aVFF-PH26D? - Ghp Group Inc Ghp Pleasant Hearth 1,800 Sq Ft Wood Burning Stove Heater With Blower,
Is there a way to adjust the pilot light on my wall space heater. I don't know the model number.
normally pilot lights are on a fixed jet size and cannot be adjusted
call a gas fitter for a diagnosis and fix as the problem may be else where causing the large pilot flame
Oct 12, 2016 | Heating & Cooling
How do I find adjustment screw for pilot light on 1998 white rodgers hot water gas 6 gallong
most pilot's are not adjustable. if it is not staying lit, replace the thermocoupler.
Jan 06, 2015 | Water Water Heaters
Pilot light flame too loeeds adjustment
Adjust the pilot flame height using the adjustment screw for each burner.
Mar 12, 2014 | Magic Chef Ovens
PILOT LIGHT IS TOO HIGH HOW DO YOU ADJUST PILOT LIGHT?
on main gas valve there is a port wit a cap on it marked pilot remove cap slowly adjust screw till pipot flame covers proper area of thermocouple (usually 2/3 ) re install cap on port. NOTE IT IS IMPORTANT YOU ONLY ADJUST PILOT SCREW NOT MAIN VALVE THAT MUST BE DONE BY A TRAINED PERSON WITH PROPER GAUGE
Oct 27, 2013 | Heating & Cooling
How do you clean the pilot light needle valve on a furnace?
you need to the pilot orffice out is blocked .
Mar 21, 2012 | Heating & Cooling
Adjust pilot light on hot water heater
On most water heaters there is no adjustment to pilot light. About the best you can do is clean pilot and burner. If you are having trouble keeping pilot light lit then I would replace the termocouple.
Nov 16, 2010 | Water Heaters
Oven pilot light too large. Can I adjust it or simplely blow it out and relight when needed?
No, do not just blow it out and relight as needed. This could be dangerous. Besides who would want to light the pilot every time you use the oven. A correctly adjusted pilot light uses a negligible amount of gas. A correctly adjusted oven pilot light should be steady and blue about 1/4" to 1/2" high. If it is yellow it is getting too little air. If there is a space between the flame and the feed tube it is getting too much air. To correct either problem turn the pilot adjustment screw slightly on the gas line near the pilot light as directed by the manufacture. Once you get it adjusted correctly leave it on.
Aug 03, 2009 | Garland H283 Gas Kitchen Range
Hotpoint RGB524 pilot won't light
sounds like you have a standing pilot system.if so and you have turned up the adjustment screw and no better .you will have to replace the pilot tube assemblie
Dec 31, 2008 | Hotpoint RGB524 Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Ghp Group Inc Ghp Pleasant Hearth 1,800 Sq Ft Wood Burning Stove Heater With Blower, Logo
48 people viewed this question
Top Ghp Group Inc Home Experts
Donni Steen
Tom Chichester
Are you a Ghp Group Inc Home Expert? Answer questions, earn points and help others
