Question about Refrigerators
Whirlpool side by side 26 MSSA and the refrigerator door suction seems to not be working anymore. It doesn't close tight. What to do????
Sea Breeze
  • 4654 Answers
SOURCE: My whirlpool Refrigerator motor keeps running
Keep an eye on the running time and temparture of the refrigerator. It will need time to return to normal cooling temps since the defrost and hot temps inside will take maybe a few more hours to reach normal. If not, get back with me and I will go through a step by step process on eliminations,  If so I will need age of fridge, Make and Models Numbers, Thanks Sea Breeze
Posted on Oct 27, 2007
IFIXALL
  • 868 Answers
SOURCE: Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Posted on Jun 06, 2008
joboo1
  • 257 Answers
SOURCE: Refrigerator Door not closing properly
Hi, No the door is not adjustable like you might think Since it is smaller than the other door any alignment problem is really visible. First do check the bracket to make sure you didn't lose a screw and that the brackets are solid and don't move. The problem is the level of either the refrigerator or the floor. If you have a 3 ft bubble level put in on the top of the refrigerator along the front, NOT on the door. There are feet on the bottom front corners of the refrigerator, you may have to remove the plastic grill to access them but depending on the model and age of your refrigerator it should be attached with clips. The feet screw in and out but with weight they won't move easily so you may have to jack the front a little, remove some stuff or try a crescent wrench. Once the front is level check the front to back, the refrigerator needs to tilt slightly to the rear so the door when partially open will close by itself. Again you didn't give a model so on some the rear feet are not adjustable and some are. I suspect you may have adjustable and the box is not squared up. If after adjusting the front and the entire refrigerator tilts like an uneven table leg then you have to adjust the feet likewise. Use your level diagonally across the top both directions, it should be exactly the same. If you have non adjustable and they are uneven it is the floor and you have to use shims under the low foot. Good Luck!
Posted on Jan 30, 2009
  • 10 Answers
SOURCE: sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Posted on Feb 11, 2009
odiebugs
  • 949 Answers
SOURCE: Beeping from refrigerator about once a minute.
If this is listed under the right model, then the only thing it could be is some models have a
door alarm,that will beep if the door is not closed. You could check and clean the gasket.
Or it the switch that tells the fridg that the door is closed. Check if there is a top door adjustment to bring the door closer to the fridge where the door hinge is. This might apply or push on the switch more.
Posted on Mar 29, 2009
I have a whirlpool refrigerator. The refrigerator is not cooling and there is condensation everywhere. Why is this happening and what do I do about it?
check that the door is sealing properly. condensation is an indication that warm air is getting in somewhere. check the door seal and alignment of the door.
Sep 30, 2016 | Whirlpool Refrigerators
Need gaskets for CSX20E Hotpoint side by side
Seals don't lose their magnetism. Check the door closes all the way round and adjust the hinges if it doesn't sit straight. Check there isn't a relief valve frozen up or blocked (it allows air to escape when the doors are closed). Check the drawers are fully pushed back in and not stopping the door closing properly
Sep 11, 2012 | Hotpoint Refrigerators
Side by side kenmore refrigerator no suction on produce side
There is no suction normally. The door has a spring type mechanism to keep it firmly closed, and the magnetic seal takes up the slack. Check the door/ hinge is straight and tight and look at the top of the hinge. There is a small cylinder about 5mm high with a number of dimples in it. One of these should have a pin in it that operates the spring mechanism; if it is missing the door will not close well.
Also make sure there is nothing in the fridge protruding, stopping the door from closing and the seal sticking!
Apr 18, 2012 | Kenmore Refrigerators
My freezer is very cold but not freezing water into ice. The door was only partially closed because a towel was in the way but after fixing that it has been 6 hours and it's still not freezing. The...
That really cause the freezer not to freeze water because of that towel. Since you already remove the obstruction, just observe it and it will gonna freeze the water. Be sure that the door gasket magnet has tightly closed freezer door and no cold air is going outside. If there is, again it will takes longer to freeze water into ice.
Just observe and it will gonna go back to normal operation.
Good luck to you.
Jul 03, 2011 | Frigidaire Side By Side Refrigerator 26...
The Whirlpool side-by-side refrigerator, model ED2KVEXVQ01 occassionally leaks water onto the floor. There could be a cup or more of water, but the problem has occurred a few times, but may go weeks or...
sometimes we overload our refrigerators and the doors will not close properly, next time you notice the water see if your doors are closed tightly and the seals engaged tightly. My wife has this habit of not checking after she has put away the remains of a big dinner or BBQ and I find drips of condensate water all over the floor as a result. The defrost collection pan overfills and the excess water goes on the floor. once the doors are closed properly the problem goes away.
Aug 03, 2010 | Whirlpool ED2KVEXVQ (217 cu ft) Side by...
Why does the door stick if opened,closed and reopened
Hi, what I think your referring to is "suction". If you open the door and then close it when finished but then you decide you want to open it again and it is really tight or "seems" stuck, that is normal and I'll explain why. It's all related to the second law of thermodynamics which states "hot will always migrate to cold" or at least that's the jist of it, we'll keep it light for this lesson, and NO there won't be a test tomorrow lol. What takes place when the door is opened is this. The warmer ambient air which is at room temperature rushes into the fridge, (actually migrating to the freezer/evaporator) and pushes all the cool air out. When the door is then closed a vacuum or suction if you prefer is created via the warm air in the unit being "pulled" to the freezer. This action usually only last's several second's, hence the door will open easy again shortly there-after. Sometimes if you listen closely you can actually hear a slight whistle or whoosh sound from this action occuring, it's actually pretty COOL...pun intended lol. Hope that help's, let me know please. I should also add if the door is just simply opening when at rest or when it shouldn't, check the seal and magnet around the door perimeter. The magnet is just there to insure a good seal,(contrary to some believing it should "pull" the door closed...nope. I mean it will to a small degree, but it just help's keep it closed and insure it seals) but should be in contact with the cabinet perimeter around each section. Good luck. macmarkus :)
Nov 21, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool side by side refrigerator door not closing by itself. Ideas?
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Flap on ice dispenser door won't close
clean it again and make sure when you use it that all the ice falls out if not and its open a little it will cause it to freeze open
Jun 26, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator suction/vacuum noise, rear section when freezer door is closed
there is no suction system. flush your defrost drain tube with boiling water and a turkey baster. should get some pretty nasty sludge out and sound will go away.
Dec 28, 2007 | Whirlpool GS6SHAXMQ Side by Side...
Refrigerators Logo
361 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
