Question about Brother HL-2070N Laser Printer
Replace pickup roller
I am having trouble getting the pick-up roller out to replace it.
2 Suggested Answers
JayBlair
  • 328 Answers
SOURCE: Brother IntelliFAX 4100 pickup roller
Need more info. Do you need help in replacing the roller? If so, it is a big job. You have to completely remove the doc feed asm and all covers to get to the roller shaft asm. Best to let a tech do it for you.
Have you tried cleaning it with some roller cleaner. Try a little bit of Goof-Off cleaner on a cotton rag.
Posted on Aug 18, 2008
Hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
The pick up roller may be worn and in need of replacement. The slight grinding noise is the pickup roller trying to work but slipping
Oct 30, 2012 | HP Office Equipment & Supplies
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Cards not feeding through on SP35
You will need to replace the Pick Roller (the first roller you see from the card hopper.
You most probably have a smooth roller and the new type are ribbed. The printer has to be dismantled to replace the roller. Suggest you contact your local reseller.
Jun 24, 2009 | Datacard SP35 Printer
Pickup roller
first you need to get the Blue perspex cover off the Lid by pulling it from the rear. After juggling it off the cover needs to be removed from the base by bending it outwards to release it from its catches. when the outer case is removed from the base you will then need to release the PCB from the base (leave it sitting on the base) to allow you to remove the card hopper, this unclips from the bottom edge.
you now have access to the Pick Roller. You will need a long T12 (Torx Screwdiver) to remove the 2 x screws which hold the Pick Motor in. When the Pick Motor has been released you can replace the Pick Roller (ensure the roller is the correct way round)
Aug 26, 2008 | Datacard SP55 Printer
Replace rollers on Deskjet 712C printer ?
Use RUBBER RENUE REJUVENATES to rub the rubber pickup rollers will fix your problem. You don't have to replace whole thing, save your Buck.
Mike Huang
Feb 13, 2008 | Office Equipment & Supplies
Trouble with paper feed
Frequent jams are because either scanner picks up more than one paper or does not pickup at all. If scanner picks up more than one paper, then paper is sticky. If the paper is thin, it can pick up two at a time. Fan the papers so that they are not sticky.
Paper at the point of entry into the scanner must be crisp. If folded or 'dog-eared' trim it. Rotate the paper if any other side is crisp, roate the image later.
Clean all the rollers thoroughly, the pickup roller, retard roller and other rollers in the scanner. One can rotate the inner rollers and clean totally, not just waht is seeable area. If the rubber is worn out, it must be replaced. TRy a single page to check if the rubber is okay. Jarring noise is because the motor is 'stopped' and cant rotate because paper is stuck. This can affect motor/inner parts, but is designed for normal use.
Feb 02, 2008 | Canon DR-7080C Flatbed Scanner
HP 7110 printer paper rollers
usally when a printer picks up too many sheets the pickup rollers are dirty or covered with paper dust use a microfiber towel moistened with water or rubbing alcohol wipe them off then if it still picks up too many sheets the surface of the pickup roller is worn.replace pick up roller the printerworks .com may have parts or hp partSurfer.com
Oct 20, 2007 | HP OfficeJet 7110 All-In-One Thermal...
Brother HL-2070N Laser Printer Logo
22 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
