Question about Wine & Spirits
1995 chevy lumina van
Quit and there was no response
  • 78 Answers
SOURCE: In my 1995 Chevy Lumina
check if you're getting power to the red and the yellow, it may be that you are only getting a permanent live but no switched live and if so you will need join the red and yellow on the radio side together using the connectors on the loom so you will have one permanent live leading into two (red and yellow) wires into the radio. clear as mud, good luck
Posted on Dec 07, 2007
  • 625 Answers
SOURCE: is there an inside switch for the rear door lock on the 95 chevy lumina van
if you mean for power locks the same power lock activates all the locks
Posted on Jun 15, 2008
  • 491 Answers
SOURCE: changing spark plugs 95 chevy lumina van
you will have to take off the coil packs and move them out of the way. then go in from the top. its kinda tight but just move whatever else is in the way
Posted on Jan 09, 2009
  • 32 Answers
SOURCE: 98 chevy lumina. Code 113, 102, 171. runs then
the code 113 is intake air temp cicuit, high input.
the code 102 is mass air flow volume air flow circuit, low input.
the code 171 is system too lean (bank 1)
I sure hope this helps you out. Dont sound like anything too major though
Posted on Sep 24, 2009
  • 1024 Answers
SOURCE: I have a 1995 Chevy Lumina with the ''Low Oil'' light on.
may be the oil sending unit is bad
may be the oil pump
is there any noise in the engine?
have the oil pressure check at a repair shop to make sure you have enough oil pressure
if it's ok then have the shop replace the switch while they have the old one out to check the pressure
Posted on Mar 09, 2010
I have no oil pressure in my 92 chevy lumina van Apv why and where is the oil pressure sending unit Located it's a3800 motor
Check around where the oil filter screws on,check oil pressure with a gauge to make sure it's not the pump gone,if ok screw on a new sender.
Oct 29, 2015 | 1A Auto Parts 1993-1995 Chevy Lumina APV...
Starter for a 1995 chevy lumina mini van,where is it located in the engine
these are located at the front of the motor were the motor bolts to the transmission between the rad and the motor
Oct 26, 2011 | 1995 Chevrolet Lumina
Firing order for 1995 chevy luminua van 3.1
your local auto store should have a manual on your 95 chevy for under 20 bucks, the fireing order is there along with lot's of other details for your chevy, good luck
Dec 21, 2009 | 1995 Chevrolet Lumina Apv
Where do you put transmission fluid in a 1995 chevy lumina van
you will have to locate the trans. dipstick under the hood take out the dipstick and use a funnel to pour fluid in dipstick tube
Aug 02, 2009 | 1995 Chevrolet Lumina Apv
How do i get the turn signal flasher out of my 1995 chevy lumina
Should just plug in (2 prongs) Not sure if you have Lumina van (on firewall just left of steering column under instrument panel) or sedan/coupe (driver side under dash, on passenger side of steering column)
Apr 24, 2009 | 1995 Chevrolet Lumina
Where do i find the turn signal flasher on a 1995 chevy lumina mini van
check for a panel inside the glove compartment, or under the dash.
Apr 24, 2009 | 1995 Chevrolet Lumina Apv
Changing spark plugs 95 chevy lumina van
Jan 09, 2009 | 1995 Chevrolet Lumina
Is there an inside switch for the rear door lock on the 95 chevy lumina van
Jun 14, 2008 | 1995 Chevrolet Lumina
Wine & Spirits Logo
89 people viewed this question
Top Wine & Spirits Experts
deton8 von Splosion
Bill Boyd
Dave braun
Dave braun
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
