Question about HP Wireless Optical Mouse
Hp wireless usb receiver - HP Wireless Optical Mouse
    Problem Solver:
  • 9 Answers
What's the problem with it? Are you not able to hook it up?
Posted on Oct 28, 2013
Need a solution to provide wireless access for an older HP Pavilion 760N
Dieter:
You can buy a wireless receiver at most computer stores. The receiver plugs into a USB port and receives the signal from your router. If you are hoping to connect to WiFi hotspots, be careful and make sure that you have good security software!
Aug 07, 2015 | HP Pavilion Computers & Internet
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
What is a receiver for a wireless keyboard?
Hello.
A receiver is a small usb stick included with your wireless keyboard and mouse. It receives the wireless signal from your mouse and keyboard and send it to your computer.
Sometimes it looks like a usb flash drive or a plastic thing with a usb cable to plug in your computer.
Hope it helps!
Feb 09, 2011 | HP USB Wireless Keyboard/Optical Mouse...
Will not connect..its not in sync with my pc
Hello
Turn the switch to the "On" position, located underneath your mouse if your mouse has a switch.
Restart your computer to have a fresh starting point for troubleshooting. Sometimes, just restarting your computer can resolve issues you have with your HP wireless mouse.
Move your HP mouse about 39 inches away from your receiver.
Unplug your USB receiver, if you have one, and wait about 10 seconds.
Replug the USB receiver into another USB port, closer to your mouse if possible, then resynchronize your mouse and receiver.
Press and hold the connect button on your receiver, while plugged in, until you see the LED light flash.
Hold and press the connect button underneath your mouse until the LED light on the receiver stops flashing.
Check to make certain the button under your mouse does not get stuck in the depressed position and releases. Also, make certain you complete this resynchronizing process in 60 seconds, or else you must start over. Your mouse will now have a new identification number from resyncing.
Unplug the USB receiver, wait 10 seconds, then replug the receiver firmly into the USB slot, pushing it in entirely. You will notice the receiver's activity light turn on, then off in the next five seconds.
Press the connect button underneath your mouse until you see the activity light turn on again on the USB receiver.
Check to make certain the mouse connect button does not remain depressed when you release it.
Nov 14, 2010 | HP Wireless Optical Mouse
Can the HP Pavilion 763n PC Desktop use a wireless router?
Your computer has a "built-in" 10/100BT network connection integrated on the motherboard but to go wireless you'll have to add either a PCI (internal) or USB (external) wireless network adapter to transmit/receive the signal from your wireless router. Think "walkie-talkie" here with the wireless router installed AFTER the modem (phone line outlet needed) located in a central area of your home and transmitting/receiving to the individual wireless network adapters that must be separately installed in each computer.
Oct 19, 2010 | HP Pavilion 763n PC Desktop
I was given the wireless 1045 is there a usb plugin that goes with it ??? If so is it posible that this key board can work offf the usb addapter that I use for my mouse its a microsoft also. the model...
The keyboard is also paired with a wireless mouse. They both use the same USB wireless receiver. If the wireless mouse you are using is not from the set then no, you can not use the same receiver for both.
Jan 09, 2010 | HP Multimedia Cordless Keyboard/Mouse...
Have hp usb wireless reciever how to connect gp9120 kybrd
this wireless keyboard is belong to same receiver if it yes then press the connect button from keyboard site as well as form the receiver site to get synchronize the frequency. Then it will start working.
Sep 18, 2009 | Gyration GP9120-001 Wireless Keyboard
Sharing HP PSC 1410V All-In-One
Yes, you can and it is pretty easy.
You should get the HP Wireless Printing Upgrade Kit
(Q6236A#A2L)
Price: $69.99
Here is there product description from HP.
Get everything you need to print wirelessly in this simple upgrade kit! It includes a printer receiver and PC receiver for a wired desktop or notebook PC, and it's easy to both install and use.
Works with most HP printers and All-in-Ones, plus all PCs, wired or wireless.
* Print from virtually anywhere in your home or office via the wireless 802.11g connectivity
* Eliminate ugly cable clutter but still get the same print speeds as via USB
* Retain full all-in-one wireless functionality: print, fax from your PC, scan, and access photo memory cards access and PC status
* Set up fast: just plug the receivers into your printer and PC; there's no configuration
* Protect your signal from interception with the secure wireless connection
* Use with a network, or just one PC
* Compatibility: most HP printers, all PCs (wired or wireless)
** I checked and your HP is on the compatibility list - it is ok***
What's in the box?
1 printer receiver
1 PC receiver
William
Feb 15, 2008 | HP PSC 1410v All-in-One Printer
HP Wireless Optical Mouse Logo
18 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
