Dvd sayde - Washing Machines
2002 chevy cavalier radio says Err Cal
The problem with having your interior cleaned by someone other than yourself is that the, someone other, just happens to spray "everything" in site to make the job easier and look cleaner. Unfortunately electrical buttons were included in the spraying frenzy and that is a no no. All sorts of problems happens when you spray these buttons including window buttons and it sounds allot like your problem.
Jul 10, 2013 | 2002 Chevrolet Cavalier
When i load a disk it says loading then it sayd no disk
Take a Q-Tip and rubbing alcohol and gently clean the laser lens, allow several minutes to dry before use, if this fails! replace the player because laser assembly not cost effective.
Mar 06, 2012 | Audiovox D1788 7 in. Portable DVD Player
When i load a disk it sayd loading then it says no disk
Grab a Q-Tip and rubbing alcohol, gently clean laser lens and allow several minutes to dry, if this fails! it is cheaper to replace the player.
Mar 06, 2012 | Audiovox D1708 Portable DVD Player
When I put a disk in the Memorex dvd tv combo it sayds inncorrect disk? What can I do to make this work. I purchased it from another person but they said it worked for them. Any suggestions?
The disc may be in a format the player does not recognize.
PAL vs. NTSC, region number wrong....
Be sure that it is a "normal" DVD, and not something burned from a computer, or a DVD-R
Jun 10, 2011 | Televison & Video
My ipod touch is locked cause i forgot my password andit sayd connect to i tunes and wenn i connect it i tunes sayd it cant connect until i unlock my ipod touch so wat should i do..?
Your problem can only be solved with a full restore of the system. When you plug it in, you should have the option to do a factory restore, which resets the iPod and deletes all data, including passcode data.
Jul 08, 2010 | Apple iPod touch
Fix please
You have to have a proper player to be able to play VCD. Do a search on Google as there are numerous different ones. Find the one that you feel has all of the features you need.
Aug 12, 2009 | Shinco Initial Technology Portable DVD...
Player not responding
Please remove any disc from the unit and try resetting it by removing the disc and placing the unit in stop mode. If you now press and hold the fast forward skip button on the front of the main unit for over 10 seconds. To confirm the reset, when you power the unit off and on the language selection screen should dispaly.
Jul 12, 2009 | Samsung BD-P1500 Blu-Ray Player
On my PT-50DL54 the HDMI HDCP stopped working
Try unplugging the television for 10 or 15 minutes and try again.
Apr 30, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
TV SHUTS OFF
You gotta change the vcr
motor charge belt that's all the problem because the vcr sistem is out of time and the micro detects the error and shuts off the tv.Good luck
Oct 17, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Samsung HT-P38 won't play DVDs but plays CDs just fine
I called Samsung. They told me how to do a software reset and solve the problem
1. Take out all CDS.
2. Turn off and then on.
3. HOld down stop for 5 - seconds.
Problem Solved!
Apr 11, 2007 | Samsung HT-P38 System
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
