Question about 2002 Mercedes S430 Chassis Computer h71928214g 220 Type, Body control BCM; SAM, Signal Pickup & Activation, S430, S500, S600 and S55, left hand engine comp, thru VIN A229601; 220 Type, Body control BCM; SAM, Signal Pickup & Activation, S430,
What are the functions of a Mercedes C280/2007 SAM computer and can i take one out of the same model an transfer with out it to e re programmed ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
No computers are programed to specific vin numbers
Posted on Oct 23, 2013
My 2008 mercedes ml550 power lift gate has quit working and all lights on rear of vehicle quit working, turn signals, 3rd brake light, reverse lights, rear camera. On occasion all work ok
You should check the rear sam control unit.It is located in the right hand side of the trunk.remove the panel and you will see a fuse block.look directly below it.that is where the rear sam is located.remove the connectors and check for corrosion.this is a very common problem.the rear sam will need to be coded so take it to a reputable repair facility.
Dec 12, 2016 | 2008 Mercedes-Benz Mercedes Benz Ml Class
No power to the A/c compressor 2003 mercedes c230
Are you sure? It is not fused and is feed directly from the front SAM(N10/1). Look for a blue wire with a green stripe that is all alone to a small connector at the front SAM(fuse box). Check for power at the SAM on that pin. If there is power at the SAM then the wire is either broken, you used a bad ground for testing or the ground may be bad. You can always ohm out the wire to make sure. it is the correct wire and it is not broken.
Oct 11, 2013 | 2000 Mercedes-Benz C-Class
I have mercedes s320 cdi 2001 and need to know which sam module unit controls the dash lights and instruments/gauges would be grateful for any help
Go to manualsonline.com Then in the search window type in Mercedes-Benz 2001 S class. Then go to page 156-157-158 and so on till you find exactly what you need. You can also go to the index in the manual if I miss understood what you are needing. Hope that Helps!
Sep 03, 2013 | Mercedes gl 320 cdi control unit sam. ....
How do you change the frount sam?
must get your car to dealer workshop should need diagnose cpu to replace sam because need re coding new control unit otherwise most of function will not work in your car.
Dec 15, 2010 | 2001 Mercedes-Benz C-Class
2004 S-430 command unit shows "No sound available"
PROBLEM IN FRONT SAM CONTROL MODULE WITH FUSE AND RELAY.WOULD BE BEST TO TAKE TO DEALERSHIP MERCEDES BENZ IS A EXPENSIVE CAR TAKE SPECIAL TOOLS AND HIGH SKILLS.
May 25, 2010 | 2004 Mercedes-Benz Mercedes Benz S Class
Possible faulty SAM system for rear lights
not a faulty rear sam more likely a poor bulb holder clean the area that the bulb sits in
Jan 26, 2010 | 2001 Mercedes-Benz C-Class
Mercedes c class c180 2001
hi,rear sam control ,fuel gauge,tail light,depends what equipment install at the rear,ty
Oct 01, 2008 | 2001 Mercedes-Benz C-Class
2002 Mercedes S430 Chassis Computer h71928214g 220 Type, Body control BCM; SAM, Signal Pickup & Activation, S430, S500, S600 and S55, left hand engine comp, thru VIN A229601; 220 Type, Body control BCM; SAM, Signal Pickup & Activation, S430, Logo
111 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
Timllfixit
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
