Bryant Plus 90 Manual
Question is there a water line hooked up to the furnace?
  • 582 Answers
SOURCE: I have a Ruud 90 Plus Model UGRA furnace and blower starts immedi
NO BECAUSE THE BOARD IS TELLING THE FANS TO STARTARE THE CONTACTS FUSED TOGETHER OR STUCK IN THE CLOSED POSISTION CHECK THIS FIRST
Posted on Aug 10, 2009
shastalaker7
  • 1515 Answers
SOURCE: what size gas line can be used to run to the attic
Hi, If you are trying to get gas to the furnace, you will have to tee off the water heater with 1/2" black iron gas pipe up to the unit. This is code. At the end if the run you will need to install a gas shut off valve and reduce to 3/8" flare to connect a 36" flex to furnace. I have 2 men who do just this, run gas lines all day. That is how it is done. Hard work. We use a rigid portable pipe machine to do this. Best of luck,
Shastalaker7
Posted on Dec 21, 2009
Testimonial: "it helps to know you're in the right direction. Makes the smaller jobs not normally done, easier."
Therinnaiguy
  • 1420 Answers
SOURCE: Bryant Plus 90 Furnace - Blower works fine and
PRSSURE, DRAFT SAFGUARD, AUX-LIMIT SWITCH(WHEN USED)OR BLOCKED VENT
SWITCH(WHEN USED) DID NOT CLOSE OR REOPENED (DOWNFLOWONLY)
If open longer than five minutes, inducer shuts off for 15 minutes
before retry.
Check for:
* proper vent sizing
* defective inducer motor
* restricted vent
* excessive wind
* low inducer voltage(115VAC)
* defective blower motor or capacitor
* defective pressure switch
* inadequate combusstion air supply
* disconnected or obstructed pressure tubing
If it opens after trial for ignition period, blower will come on for
90 sec. recycle delay.
Check your air filter for blockage, check pressure switch for a buildup of moisture. Make sure your inducer motor is turning and creating a vacuum to the pressure switch. Make sure all venting is clear and free of water or debris. Make sure there is no water in inducer motor and all drains are draining.
Posted on Jan 28, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: Bryant Plus 90i furnace vibration
You have not mentioned if the vent pipe has any anti-vibration mounts or not. If not, use rubber mounts to suspend the vent. It may be transmitting your noise.
Posted on Mar 11, 2010
  • 117 Answers
SOURCE: bryant furnace plus 90 led code is blinking once
these codes are on the inside panel of the front cover of the furnace. lift off and look inside.there should be a code explain chart on the panel by the light. this panel will need to be replace correctly for the furnace to work as there is a door switch.
Posted on Feb 01, 2011
Bryant Plus 90 furnace
possible your supply duct leak or break
Feb 11, 2014 | Heating & Cooling
I have a bryant gas furnace plus 90 the furnace kicks on and the pilot lights but the fan that blows the heat thru the house wont turn on! I keep getting error code 44 and 41 what can i do to fix that?
make sure fan wheel turns freely
check for voltage to fan--if you have voltage check capacitor output against capacitor rating, must be withing 5%, if that checks out replace blower motor
Jan 17, 2014 | Heating & Cooling
Bryant furnace plus 90 led code is blinking once then 3 times fast. What does it mean?
Jan 31, 2011 | Heating & Cooling
Bryant plus 80 heat exchager is cracked, i'm looking for a replacement heat exchanger
Hate to tell you but heat exchangers are hard to match up. Unless it is relatively new then in most cases they have a warranty of 10 years. So you will have to replace furnace. You might be able to find a used furnace or go to web site and enter model number of your Bryant to get replacement.
Oct 23, 2010 | Heating & Cooling
Mar 11, 2010 | Heating & Cooling
Bryant Plus 90 Furnace - Blower works fine and intermittently blows warm air but will not bring house to temp set on thermostat... Get a 1-3 error (one blink and then 3 quick blinks of the LED) Thanks
before retry.
Check for:
* restricted vent
* excessive wind
Jan 28, 2010 | Heating & Cooling
What size gas line can be used to run to the attic to hook up the bryant 310 multipoise. The easiest accessable one is from the water heater
Shastalaker7
Dec 20, 2009 | Heating & Cooling
I have a Bryant Plus 90i furnace and a Bryant2.5 A/C
go mid.range....cfm dont go to hi spd or no cooling pick up
Aug 18, 2009 | Bryant Heating & Cooling
Filter for Bryant plus 90i
Bryant Furnace Filters www.iaqsource.com Every Bryant filter in stock For every Bryant furnace and AC
may want to check on the filter itself and the housing for numbers that could assist its type and size
this site may help you
Jul 04, 2009 | Goodman CLJ30AR32 Air Conditioner
Heating & Cooling Logo
131 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
