Question about Kenmore 44102 Front Load Washer
The front of the washer has come loose. I believe it's missing a couple of clips. It makes a lot of noise. I would like to repair it.
    Sergeant:
    Champion:
  • 257 Answers
It seems the tub bearing went to it end cycle. The cost of repair is as high as buying the new one.
Posted on Oct 22, 2013
3 Suggested Answers
SOURCE: kenmore Front load washer model
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Posted on Aug 30, 2008
  • 106 Answers
SOURCE: Kenmore front laoder washer with loose wash basket
Highly likely that either your bearings or spider arm has gone out, this is no easy fix. You can 'search' above or click on 'troubleshooting' in blue to browse
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
Posted on Feb 28, 2009
Whistling
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
Jul 22, 2014 | Whirlpool Washing Machines
Rumble on spin
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Feb 27, 2014 | Frigidaire ATF6000ES Front Load Washer
During spin cycle loud clunking noise
Feb 16, 2014 | Frigidaire GLTF1670A Front Load Washer
Machine makes noise on spin cycle
Feb 15, 2014 | Frigidaire Washing Machines
Spinning cycle sounds rough
Feb 12, 2014 | Frigidaire ATF6000ES Front Load Washer
GE WDSR2080D5WW wont spin or agitate
The coupling might be bad. Take cabnet off by removing 2 screws from counsel, then flip up and pop 2 clips and the cabnet will pull away from machine. Then pop 2 clips off pump down in front of machine then take the 2 quarter inch screws out of the 2 clips holding motor then you'll see coupling. Any questions call Chris's r Repair at 716-258-1944
Dec 21, 2011 | GE WDSR2080D Top Load Washer
Will not spin. makes ticking/clicking sound but no spinning.
For washer that's not spinning but making a clicking noise, then your washer could have a broken coupling. I believe that with Frigidaire, they're calling it as "Gear-crank"
Please check the link below so that you could see what a gear-crank is:
http://www.repairclinic.com/Frigidaire-Washer-Dryer-Combo-Parts?n=49
You need to contact a repair tech to check the coupling of you washer. If it's the one on the picture, then it would only costs you $5 for the coupling.
Have a great day!
Sep 18, 2009 | Frigidaire ATF6000ES Front Load Washer
How do you open up a ge wwwse3160aoww washer. the wash agitates fine but makes a lot of noise when it try to go to the spin cycle. it makes a bagging noise and spins slowly
Slip a putty knife or other thin object between the top and front panels a couple inches from each side. You should see the clip release from the top panel. Pull the front panel down from the top
Jan 05, 2008 | GE WBSR3140DW Top Load Washer
Maytag Washer Noise While Spinning
Most washer models have snap-clips holding the front of the top panel down, with hinge-like clips at the back. Carefully pry up the top panel on the front of the machine using a tool that won't scratch the finish, such as a plastic or wooden wedge. If it does not pop loose fairly easily, then carefully examine the back of the machine to see if this is a rare model that has screws holding down the top panel. (But really, it _should_ just pop loose.) Once the top panel is tilted up to expose the inside, you should be able to see everything you need to see inside the body to evaluate a spinning drum problem.
Aug 04, 2007 | Maytag MAT13MN Top Load Washer
Kenmore 44102 Front Load Washer Logo
16 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
