Question about GE Antique Radio VintaRadio Antique Furniture Tombstone 1931 Wood Radio Brass
I need a manual for a GE J-805 1940 console radio and some help with the antenna
USER MANUAL GE CLOCK RADIO 7-4853C
Try Googling (GE)(7-4853C)(manual) without parens.
Jan 28, 2018 | Home
I need to know what replacement antenna to get for my tk-3130
I found the manuals at:
http://www.hitechwireless.com/products/Kenwood-TK%252d3130-ProTalk-XLS.html
This radio is a UHF radio but it doesn't saw on the site what the frequencies are or the type of antenna connection, BNC, SMA, ?
The manual shows 464.5 MHz to 467.925 MHz so an antenna for 464 - 468 MHz would do.
Manual also at: http://kenwoodusa.com/
Contact form at: http://www.kenwoodusa.com/Contact/
See if they have a replacement antenna for you.
Oct 24, 2013 | Kenwood Protalk XLS TK-3130 (2 Channels)...
I need a manual for my 1940 GE Console radio and help with selecting antenna
any old twig will do, your are not going on a dxpedition
Oct 22, 2013 | Radio Communications
Need antenna
This radio has a standard BNC antenna jack. Radio Shack does now offer an antenna with a BNC connector on the end that you can use with this radio.
Dec 03, 2012 | Uniden Bearcat 855 Xlt 50 Channel Scanning...
I pulled my ipod to car lighter hookup out of the car lighter today and the entire thing popped out. i put it back but now my radio won't turn on... at all. my antenna won't even go up. i don't know what i...
in some vehicles the 12 volt power plug in is on the same fuse as the radio or console, as for the antenna not going up that makes sense, the power for the power antenna is most likely supplied by the radio, no power to the radio no power to the antenna. good luck and I hope this helps.
Aug 10, 2010 | 1990 Volvo 240
Radio won't pick up any stations. Any schematics to connect a new antenna?
I wonder if theres a connection on the back for an external antenna? What does the owners manual show?
Apr 17, 2010 | GE 7-5295 Undercounter DC /Radio Combo -...
NEED A MANUAL FOR THIS UNIT GE DIGITAL CLOCK RADIO MODEL 7-4890A
Hello
I found the manual that you were looking for. Just click on the link below and it wil direct you to the page where you can download the manual.
http://www.retrevo.com/s/GE+7-5290+Clock+Radio
Hope this can help you.
Best regards
Andrea
Oct 20, 2009 | GE 7-5290 Clock Radio
Aquatronics Radio MS1550G 4X40W
I have an Aquatronics MS1550G radio on my 2006 Suntracker. The radio speakers have sound, but the sound is barely audible. I have used the reset button with no success. Is there a quick fix to this problems?
Aug 08, 2009 | Aquatronics Car Audio & Video
GE Spacemaker TV/Radio combination Model #7-7650
Yes, you will need an external antenna to pull in the digital signals. It will not work with the built-in antenna on the GE. Alternately, you can use an external antenna (ie, rabbit ears), connect them to the converter box, then connect the converter box to the antenna jack on the back of the TV (I think it has one). Granted, not an elegant solution for a kitchen TV, but it beats not using it anymore.
Cheers
Nov 11, 2008 | GE Televison & Video
GE spacesaver 05GP009
I had this same problem, I wanted to use this tv with a converter box and the only way to do this was to hook up the converter box with an external antenna to the small 3.5mm input on the back. If you go to radio Shack and get an "F to 1/8" Adapter"the radio shack part number is "278-257". It worked perfectly. I'm able to get many clear channels, and with the converter box I now have remote control. It works well. Good luck, I hope this helps
Mar 02, 2008 | GE SpaceMaker 05GP009 Television
GE Antique Radio VintaRadio Antique Furniture Tombstone 1931 Wood Radio Brass Logo
Top GE Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Jim Goldsmith
Jim Goldsmith
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
