Question about Whirlpool WFW94HEX Washer
Hello, I have a whirlpool duet wfw94hexlo washer. got an error code, drain filter assy., cleaned it put it together. when you go to start machine all seems normal. you push start, door locks, light comes on, timer starts counting down. after 4 or 5 minutes machine beeps has error code F01 E02
    Sergeant:
    Champion:
  • 257 Answers
Great! you have the MCU (motor control unit) need to replace. Removing the rear panel so you are able to see the motor and MCU. Replacement is easy, almost no screw on the board.
Posted on Oct 22, 2013
SOURCE: Whirlpool Duet HT GHW9400PL0
Thanks to Coldcut and several others, I have followed the trail of problems and solutions and successfully fixed the annoying (to say the least) FDL and F11 error codes issue on my Whirlpool GHW9400PL0 purchased in 2005, broken in 2008. I too was extremely frustrated with a load of wash taking 1 or 2 days to complete. Some of the fixes (unplugging the washer for an hour, simultaneously pressing start and cancel) worked temporarily, but eventually I had to call for service. Before that, I fearlessly took the door lock unit apart (not recommended) and reinstalled it. It did not work. I ordered a new door lock. It did not fix the issue. Coldcut already knew that would not work but I tried it anyway. Not a big ticket item and I was afraid to muck with the CUU circuit board.
The whirlpool service center sent a repair guy out within the week, but he failed to show on the scheduled day. Calls to the service center confirmed that he was on his way. An hour late, the service center confirmed I was next on his schedule. Two hours later, I asked to speak to a manager who listened to my compaint and informed me in no uncertain terms that they did not care about customer satisfaction and would not be interested in monitoring their repair partners. I am so glad I took a half day off work without pay to wait for someone who did not value my time. I told the service center I would never buy another Whirlpool appliance and they politely told me that "it was my decision". Indeed.
The repair guy showed up the next day (another no pay day), asked me what the error code was, checked his computer, and informed me I needed a new CCU at twice the price of major online parts suppliers. I sent him away after paying the $80 service fee, and ordered a new CCU online.
With the new CCU on the way and nothing to lose, I took the CCU out of the machine. gaga24008 had wisely advised to be careful prying the board out of the case (thank you) and following Coldcut's instructions I resoldered the relay legs with my circa 1968 Wen soldering gun. Put everything back together (I had previously removed and replaced every connector in the entire machine) and waited for the 6 whimpy relay clicks to prove it didn't work-- but it did work! I've completed 15 or so loads of wash since, and no problems. I'm hanging on to my expensive replacement CCU just in case. I'm wary of the postings which refer to immediate problems after installing a new CCU. My next step will be to hang the dang thing by a bungy cord. Thanks to the many people who have posted solutions to this aggravating issue. I'll be visiting FixYa for any future issues with my tools and appliances.
Posted on Oct 12, 2008
  • 13 Answers
SOURCE: Whirlpool Duet Front Loading Washer Won't Turn On
mains filter blown door lock fail main pcd fail appliance doctor
Posted on Feb 02, 2007
SOURCE: Whirlpool Duet won't run
Ok... so I had the problem, tried a couple of things... nada. So I stared at it and thought for a minute and looked at all the buttons. I looked a the button to the way right that said something like hold down for 3 seconds. I did it and all of a suuden it worked. I hope this helps you guys out.
Posted on Mar 03, 2008
  • 1294 Answers
SOURCE: Whirlpool Duet Error code F 32
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. All you guys are going to rate me....................
Posted on Jun 16, 2008
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Sep 06, 2014 | Whirlpool Washing Machines
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer isn't draining properly. Cleaned out filter but keeps flashing numbers.
My duet is also doing that. The error code that I get is F02. If you press the cancel button twice, it will cancel the error code. Then press and hold the start button until the door locks again. It should continue on the cycle. If not, press cancel once and put the dial on 'drain and spin' to complete the cycle. I think the problem is probably the computer control module, but I am hesitant to spend the money on the part which is about $150 without labor, because my washer is 7 1/2 years old. Replacing the part does not look hard to do. There is a You-Tube video that shows how to take your duet apart and put it back together which shows the computer control module.
Nov 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Duet front loader.. once it starts washing it stops and an error f2 code comes up and it will not complete the washer the clothes are left wet. if i move to spin only it still wont same code comes up
Hello & Welcome to FixYa
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error 21 was on washer, we cleaned out drain then started washer it appeared to be working, but then error message 21 came on again. It is very late so tomorrow morning we will open drain again.
Hello, it can only be dirty filtersomething in the pump drain line blocked up or failed pump. I would check the filter again and if its clean put the drain hose in a bucket see if it drains but chances are you will need a new drain pump. hope this helps please rate my answer thanks
Jun 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F 02 code. washer won't drain properly
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is error code f 21 on a whirlpool duet sport wfw8300 3.8 cubic washer?
This means that the drain pump is clogged. Tip the machine back and remove the three screws on the bottom panel. The pump has a filter inside. Pull the filter out and clean it, it will fix the issue for sure!
Apr 13, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool WFW94HEX Washer Logo
281 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
