Question about Cameras
My osseoset 200 implant motor W&H product supplied by Nobel Biocare shows messages err.99 and err00 when switched on? can any one suggest why is it so?
4 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: Err 99
cleaning the contacts ought to be done using a pencil eraser(i am very specific about this)to fix this error
vigorously scrub the lens contacts with an eraser. Then  gently use the eraser to clean the camera contacts (holding the contacts face-down to prevent eraser rubber from falling into the body).Put the lens back on… and the camera shoudl be fixed!
Try this and post back before you rate..
Posted on Nov 01, 2007
  • 51 Answers
SOURCE: Err 99 when I attach lens
I had the same problem with my camera and i found this guide online very helpful in most cases
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
Posted on Jan 29, 2009
  • 262 Answers
SOURCE: After a few shot,my camera show "Err 99"
There's a very comprehensive essay about the various possible causes of Error 99 here (follow link).
Posted on Jan 21, 2011
Error 99 is my problem... any ideas on a fix?
This may help you, it is from Canon.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
Does the "ERR 99" message appear? If so, then the CF card is the most
camera body.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
For factory service, forward your digital camera (remove the CF card
and battery) properly packaged and insured, with a letter describing the
difficulties. Be sure to include your name, address, telephone number,
and proof of warranty (if applicable). Send to the Canon Factory
Service Center at the following address:
Canon Factory Service Center
100 Jamesburg Road
Jamesburg, NJ 08831
Tel.# (732)521-7007
or
15955 Alton Parkway
Irvine, CA 92618
Tel.# (949) 753-4200
Your equipment will be examined and you will be advised of the
findings.
The length of time for the repair will be dependent upon the nature of
the repair and availability of parts if needed. If the repair entails
something that is not covered in warranty you will be sent a written
estimate to the address that you have provided.
Thank you for choosing Canon.
Sincerely,
xxxx
Product Support Representative
Dec 26, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Error 99 keeps coming up I reload the battery turn on off but after a few shots it comes up again and the red shows indicating that it is still processing the shot.
Here is the diagnostic process, allegedly from Canon themselves. It's quite old, a newer camera probably has a SD card rather than CF.
To isolate the cause of the issue, we [Canon] suggest that you do the following:
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the camera should be serviced.
Jan 19, 2011 | Cameras
My tamaron 28/200 lens when fitted to. cannon eos 350 d. shows err 99 when switched on ,previosly ok ,disconect lens and camera functions ok,only have one lense
Try cleaning the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Sep 27, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My canon eos rebel xti keeps showing error code 99
following:
steps:
camera body.
Sep 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Rebel XS ERR99
This is something I found when googling your problem.
your EOS 10D is displaying an "ERR 99" message.
following:
steps:
camera body.
May 25, 2009 | Canon Cameras
Err 99 appears after every click for canon eos 30 D
Err 99, but lens-to-body problems are common- thought error 99 is a bit of a catch all- generally a lens and body conflict. And also Err 99 means that something wrong happened, but then it cleared out before it could be further determined.
Here is the blurb from canon to try:
following:
steps:
camera body.
100 Jamesburg Road
Jamesburg, NJ 08831
Tel.# (732)521-7007
or
15955 Alton Parkway
Irvine, CA 92618
findings.
Please leave for me, a rating...
May 15, 2009 | Canon MF8180C Color Laser MFC Printer
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99
Hi Ben ,
To isolate the cause of the issue, we suggest that you do the following:
camera body.
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 | Cameras
Canon EOS 400D SLR - Err 99
Try going into the menu and turning off the lock for shooting without a lens. Then try firing it without a lens to see if it works. Very often a lens problem can cause the Err 99 message.
Also, check to make sure the pop-up flash is not stuck down. That could also cause it.
Unless you have used your camera a LOT, it shouldn't be a bad shutter. They usually only quit after many years of use. I think Canon quotes 125,000 shots as the normal life of a shutter in a digital SLR.
CameraRepairs
Jul 14, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
From RICHARD'S NOTES
Dec 04, 2007 | Canon EOS-10D Digital Camera
Cameras Logo
471 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
