Question about Philips NP3900 Streamium Network Music Player
White screen after updating - Philips NP3900 Streamium Network Music Player
Hey i have update my nokia n73 mobile phone after this it is starting but nothing displaying every thing is white on screen what to do pls rply
Is it white screen hang ? Or Your phone boot up in normal with white screen ? If it is white screen hang you need to flash your updating might lose some data.Contact mobile repairing shop or mail me at raingamj@rediffmail.com.thanks for visiting fixya
Jul 20, 2011 | Nokia N73 Cellular Phone
Flashing white screen
you update and now its not working?????????????
May 07, 2010 | Sony Ericsson K800i Cellular Phone
Screen turn to white & cant recovery the system
I would reinstall windows sounds like the update corrupted it.
Feb 22, 2010 | ASUS Eee 4G Notebook
InstallatIon of Mac OS X 10.4.10
White screen issues on your Macbook are more often than not, an indication that you may have a connected peripheral or device which may be hindering your Macbook's normal start up function
What you need to do first, is remove all peripherals from (printers, scanners, USB drives etc.) and then reboot your Macbook.
If your Macbook starts up normally without a white screen, leave all the peripherals disconnected and see if you can proceed to run all of your software updates, in Apple menu>Software Updates, first, including updating to the final version of Mac OS X 10.4 Tiger, 10.4.11.
Once all of your updates are completed, then you will need to go through a process of elimination by connecting one peripheral at a time, then properly shutting down and restarting your Macbook with each device, to see if your Macbook goes to a White screen.
Depending on the number of peripherals you have normally connected to your Macbook, this may seem a little tedious at first. But considering how bothersome a White screen is, it will be worth it solving the mystery of which peripheral is causing the white screen and failure to boot up normally.
If it turns out that one of the devices you had connected was in fact, causing the white screen, this will be the opportunity for to research online, visiting the affected device's manufacturer's website or even use Google, to confirm if there are any known issues and/or updates available to address that issue.
There are other variables which can come into view with a white screen issue, but this is a good way to start in terms of working toward a viable solution to this issue with your Macbook.
I hope this helps, let me know if you have more questions.
Regards,
-Mactechtrainer
Sr. Mac Support Specialist
Jan 25, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
White screen appear
If the problem started after changing your graphics driver, then reinstall the old driver. Acer should have the original drivers on their web site. If you don't want to go back, you could try updating the bios, that also should be on the web site.
Jan 17, 2010 | Acer Aspire 4315 Notebook
White screen after turning on laptop, have to reboot
It's sounds like the lcd is going out.
But it could also be GPU related.
Try updating the motherboard firrmware / bios
Updating the Video Drivers. If that produces the same results then more than likely the lcd will have to be replaced.
Let me know if you have any more questions.
Nov 23, 2009 | Video Game Consoles & Games
Blank white n70 screen
sir plz update phone software click on this and phone updating software http://www.nokia.co.in/get-support-and-software/download-software/device-software-update/download if problem persist tell me again
Sep 04, 2009 | Nokia N70 Cellular Phone
Magellan Triton 400 update failed unit stuck in white screen
Hey, Had the same exact problem, found a website with instructions on how to fix it. Turns out there was a corrupt file in the update, so you have to download the update directly from magellan and copy/paste into folders yourself. Anyway, here's the link--it worked perfectly for me!
http://www.gelb.com/jungleghost/Articles/Upgrade_Fails_to_Complete.htm
May 30, 2009 | Magellan Triton 400 Handheld GPS Receiver
White screen on g1 andriod
Sir,
Try doing the "slide to unlock" motion on the white screen. Also third party application software problem. If not solved, update the firmware. For firmware update go to the manufactuer's site for download else contact customer support.
Link 1 for more info.
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 10, 2009 | Google Android
White Screen
The "White Screen of Death" was a problem plaguing the TomTom One V3 about a year ago. This was brought up in another FixYa thread here- http://www.fixya.com/support/t192218-blank_white_screen
As the solution suggests, call the manufacturer and you can easily have it fixed/replaced
Nov 17, 2008 | Tomtom ONE 130S Car GPS Receiver
Philips NP3900 Streamium Network Music Player Logo
41 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
