Question about Toshiba Office Equipment & Supplies
Receiving data not printing
The data from the computer is not transferred to the printer and the page is not getting printed. The printer icon disappears immediately
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Get IT person
Posted on Jul 06, 2014
Benimur
  • 6966 Answers
SOURCE: Printer not Print data in English Language
Hi, you may want to reset/restore the Epson LX300 to default settings. This can be done by pressing down on the FONT button while powering on the printer. If done right the LX300 will print a test page with the firmware version. It is also possible that the drivers are corrupted. In Start, Printers & Faxes, delete the LX300 printer, restart your PC and then re-install via Add Printer. In some cases, defective parallel cable can also cause problems. Unfortunately the only sure way of checking is by replacing the printer/parallel cable with a known good/operation cable. If the printer would really be requiring service, a Service Manual is available at (http://www.eserviceinfo.com/index.php?what=search2&searchstring=DPA-300) Hope this be of some help to you. Good luck and pls post again how things turn up.
Posted on May 26, 2007
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
itdude4321
  • 13 Answers
SOURCE: Nothing printing
I work with Zebra printer on a daily basis and it sounds like you will need to restore the printer to the factory defaults. However if you choose to do this you will remove the network settings, assuming your print has a NIC and you are using it as a network printer. Record the network settings before you default the printer so you have them on hand to re-enter the settings. You will need to enter the Advanced Setup 3 to load the defaults, Once the defaults are reloaded go back into Advanced Setup 3 to re-enter the network settings. This should solve you problem.
Posted on Feb 02, 2008
SOURCE: HP Deskjet 6940 printer - printing but no ink transferred to page itself
I have the same issue, but with a HP DJ 3550, I´ve heard about the data execution protection (DEP) migth help when changing the options, but still have to try it
Posted on Jul 17, 2008
checkitright
  • 1362 Answers
SOURCE: Print Data light blinking
-try converting the PDF file
-the driver may need to be reloaded
if you print from Word does it go trough? if yes then that particular file is the problem
Posted on Aug 12, 2008
Canon LBP6000. Data transfer to the printer timed out, or a transfer error has occurred. Click [Resolve Error] to resume printing, or click [Cancel] after pausing the job, then try to print again.
Best to un-install the printer drivers, softwares related to this printer. Go to Canon.com and download the latest drivers and software. Connect the printer to the computer and let the computer recognise it and then install the drivers from your download. You can also check if there is any damage to the cable as this could also stop the communication between the computer and printer.
Dec 09, 2013 | Canon LBP6000 Laser Printer
Have just installed Windows 7 Ultimate and downloaded/installed the driver for Panasonic DP-C322. After successfully installing, I printed a test page that consisted of 100's of pages, some blank and...
The "test" output should have been one page.
If the printer properly interpreted the data-stream that it received, it _would_ have generated just that one page. However, if the printer is not "interpreting" the data-stream, but instead is printing it, character-for-character, then you could have gotten the mountain of output that you got.
Turn the printer off. Turn the printer on. Try again to print your own, small, "test" page.
May 05, 2011 | Panasonic WORKiO DP-C322 Printer
Prints one or two lines then you get a scrambled error message and it stops until you press on button then it does the same thing again, I have unplugged everything several times and even uninstalled and...
Use the HP Toolbox to perform the following tasks:
  • Calibrate the printer to align the print cartridges.
  • Clean the print cartridges when lines and dots are missing from your printout.
  • Print a test page to check for clarity after cleaning or to verify that the printer can receive data and print from the computer correctly.
  • Print a diagnostic page to show how the print cartridge nozzles are working.
  • Calibrate the photo tray to correctly position your photos.
  • Check the ink levels of the print cartridges. Adjust the printer configuration.
  • Investigate warning conditions.
Opening the HP Toolbox from the printer icon
  1. Double-click the HP Digital Imaging Monitor and make sure you are on the correct printer tab.
  2. Click Settings and then click Print Settings .
  3. Click the Printer Toolbox choice.
Opening the HP Toolbox from the Printer Properties
  1. Click Start .
  2. Click Settings .
  3. Click Printers .
  4. Right-click the icon of the printer in use.
  5. Click Printing Preferences .
  6. Click the Features tab.
  7. Click the Printer Services button.
Oct 25, 2010 | HP PSC 2355v All-In-One InkJet Printer
My printing problem is not a constant thing - it seems intermitent. Sometimes when I want something printed and get no result, I see the icon of the "x" (delete) in the lower right hand corner of my...
may be the data transfer to the frinter,cables secure, driver compatability if it win 7, its to do with how the computer sees the printer and feeding data to it
Jul 07, 2010 | Lexmark X125 All-In-One InkJet Printer
Why do i have to use a usb to be alble to print
The printer has to receive "data" and "commands" from your computer. The USB interface is used to transmit what the printer needs to receive. Other possible data-transfer interfaces, e.g., wireless, or parallel, may not be installed in your printer.
Feb 02, 2010 | Lexmark Z2420 Printer
How to cancel printing a document
If the document is currently printing and you are using Windows, then at the bottom right of the screen you should see a printer icon (picture).
Double click on that icon and it will open the printer dialogue box and you will be able to cancel the printing from there.
Don
Oct 26, 2009 | HP Photosmart 3180 All-In-One Printer
Says memory is low cant print how to fix
Do the following:
1. Make sure that the memory does not have any faxes in it waiting to be sent if so send them.
2. Make sure that the memory does not contain any received faxes still waiting to be printed if so print them.
3. Use the HP ToolboxFX Fax tab to perform fax tasks from the computer. The Fax tab contains links to the following main pages:
● Fax Tasks. Perform such tasks as sending a fax or clearing the fax memory.
Fax Data Properties. Manage the space used to store faxes on a computer. These settings apply only if you have chosen to send or receive faxes remotely from the computer.
Enhanced I/O
The enhanced I/O (EIO) feature allows all-in-one memory to be used for storing data received from the
host computer. When EIO is enabled, more data can be sent to the all-in-one in shorter amounts of time
so that the user can return to the software program more quickly. The
EIO feature has the followingoptions:
Auto. The all-in-one uses EIO memory allocation to increase the speed of data transfer from the host computer to the all-in-one, if necessary. The default setting is Auto.
Off. The minimum amount of all-in-one memory is used to store data that is sent from the host computer.
Page Protect. The formatter creates the entire page image in page-buffer memory before physically moving the media through the all-in-one. This process ensures that the entire page is printed.
Oct 21, 2009 | HP LaserJet 3055 All-In-One Printer
Jul 14, 2008 | HP Deskjet 6940 InkJet Printer
20 mem overflow
The printer received more data form the computer than can fit in its available user memory. You may have tried to transfer too many macros or soft fonts, or graphics that were too complex. This problem is also caused by printing too many typefaces at 600dpi. Press Continue to print the transferred data, then simplify your print job or install additional memory. I don't know why it would just start doing it, perhaps a memory module has gone bad and there is not as much available RAM as there used to be?
May 14, 2008 | HP LaserJet 4 plus Printer
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
67 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
