Question about Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh mp171 sc392 error allready changed drum unit
5 Suggested Answers
  • 24 Answers
SOURCE: SC392
SC 392 Possible causes -
· Someone forgot to remove the toner seal of the PCU
· ID sensor defective
· TD sensor abnormal
· Drum does not turn
· Development roller does not turn
· Poor connection of the PCU
Regards,
Posted on Jul 07, 2009
SOURCE: RICOH AFICIO 2027 SC392 CODE,IM AN ENGINEER AND
• Someone forgot to remove the toner
seal of the PCU
• ID sensor defective
• TD sensor abnormal
• Drum does not turn
• Development roller does not turn
• Poor connection of the PCU drum unit
Clean connector of TD sensor and
Try Change the development unit, adjust TD sensor.
Clean and you verify the connector of PCU.
Good luck...
Posted on Oct 21, 2009
santosj27
  • 263 Answers
SOURCE: hi i have printer, Ricoh
Checks if the side door or the front door is closed
Posted on Jan 18, 2011
  • 70 Answers
SOURCE: What can correct an SC392 on a Ricoh MP W2400?
SC392:Toner density sensor initial setting is not performed correctly.
  • No developer
  • Developing roller does not turn.
  • Development roller coupling gear is not correctly attached.
  • Poor connection of PCU
Source: Ricoh Errors
Posted on Jun 03, 2011
How to empty ricoh mp171 waste toner
Ricoh MP171 does not have a waste toner container. It recycles used toner back in the developer unit - where it is mixed with new toner and developer powder, and can be used for printing again.
Jun 24, 2017 | Ricoh Office Equipment & Supplies
Ricoh mp171 admin not working on web image monitor
Hello.
If you didnĀ“t change it it should be "admin" and the password field empty.
One of the causes that desable browser access is an address book error message. Can you see it in the browser or in the device display?
Nov 03, 2016 | Ricoh Office Equipment & Supplies
How do I fix the error code SC 542 for Ricoh MP171 SPF?
Fuser problem will need to be fix ibefore code can be reset
Oct 14, 2015 | Ricoh Office Equipment & Supplies
How to clear error sc392 on ricoh aficio 270/220 photocopier
A few things to look for is make sure the developer roller and drum are actually turning (missing gear, teeth, etc...). Are any obstuctions blocking the developer from brushing the drum (I place paper between the drum and developer so I don't scratch the drum during *ssembly, if I forget to remove it - code). And make sure the connectors are secure.
It's not enough that we do our best; sometimes we have to do what's required.
or
https://www.google.com.af/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CCIQtwIwAQ&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DvPe5fL_erZs&ei=jSWMVNb3L8jOygOjhYAg&usg=AFQjCNGPjBajIAh-ZNVxMbICi6EYxdN3zQ&sig2=4OZiTxo5eatVb3bXAD_6Zg
search the above link and watch the video
Dec 13, 2014 | Ricoh Aficio 220 270 Drum 60 000 Yield...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
What does sc392 mean on a mp2510
seal of the PCU
ID sensor defective
TD sensor abnormal
Drum does not turn
Apr 03, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
  • No developer
May 06, 2011 | Ricoh Office Equipment & Supplies
RICOH AFICIO 2027 SC392 CODE,IM AN ENGINEER AND RESET SC CODES BUT STILL DOESNT WORK. HAVENT COME ACROSS THIS BEFORE.I KNOW ITS TD SENSOR FAULT, CHANGED WITH ANOTHER 2ND HAND UNIT I KNOW WAS WORKING FINE...
seal of the PCU
Good luck...
Oct 12, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
SC392
Regards,
Jun 11, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
I have error code 392 with aficio
SC392 is a problem with your Photoconductor unit (PCU)...could be the density sensor, drum or developer roller not turning. Is it a new unit? Have all the seals been removed?
It could be as simple as a bad connection. try removing and re-installing the unit.
I don't want to necessarily say just order another unit, because the problem could be on the drive of the machine, But it is most likely the PCU itself.
Just a question, when you turn the power off/on, are you using the MAIN power switch (red button)? The button on the control panel will not reset anything.
Apr 08, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 2022 All-In-One Laser Printer Logo
201 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
