Question about Canon P170-DH Calculator
When a number is more then 6 digits the display dims digits on left side and you cannot read the numbers.
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
Light displaying radio station not working
back light dead.
so use the dimmer knob. all cars have a dash dimmer that runs all car parking light on, dimmed lamps. all.
so fiddle that.
get the operators guide, (lost) ????
read the pages on dash dimming.
if that dont fix it, check fuses. next.
Jan 21, 2014 | 2003 Toyota Corolla
Front panel configuration
Motherboard installed in computer case;
Processor to the Top, 3 Ram Memory slots to the Right, 5 white PCI slots to the Bottom;
Down in the Bottom/Right corner, is JFP1, and JFP2.
The Front Panel header is JFP1. (Junction Front Panel 1)
The header with two rows of pins, and is positioned Horizontal. It is parallel to the bottom of the motherboard.
(The other Front Panel header is JFP2. It is positioned Vertical, and is above JFP1. You may be using it also. Read on)
There are two rows of pins for JFP1.
5 across the Top, 4 across the Bottom.
The pins on the Top row are numbered ODD.
The pins on the Bottom row are numbered EVEN.
Top row, starting from the Right side, going towards the Left;
Pins 1, 3, 5, 7, and 9.
Bottom row, starting from the Right side, going towards the Left;
Pins 2, 4, 6, and 8. There is NO pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the Harddrive activity LED light is dim, when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for the Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It is/was for the factory.
D) Pins 2 and 4 are for the Power On LED light. A Power On LED light that has 2 wires.
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Looking at JFP2. (Junction Front Panel 2)
Vertical with two columns of pins.
3 on the Right side, 4 on the Left side.
The Right side is numbered EVEN.
The Left side is numbered ODD.
Starting at the Bottom on the Right side, going Up;
Pins 1, 3, and 5.
Starting at the Bottom on the Left side, going Up:
A) Pins 1, 3, and 5, are for a Power On LED light, that has 3 wires.
Pin 1 is for the Positive wire. (Dual color LED )
B) Pins 2, 4, 6, and 8 are for a Speaker. The speaker for BIOS Beep Codes.
Pin 8 is for the Negative ( - ) wire.
Regards,
joecoolvette
Jun 24, 2012 | MSI MS-6580 Motherboard
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
How do I change the time stamp heading- when I send a fax it shows the wrong month , year, date and time
1. Press <function> then the "Down Arrow" below the <start> button until [ENTRY MODE] appears.
2. Press "Right Arrow" below the <start> button until [DATE&TIME SET] appears.
3. Press "Right Arrow" (current set date will appear).
4. Enter two digit number for day. (To correct a mistake press "Left Arrow")
5. Enter a two digit number for the month.
6. Enter the four digit year.
7. Enter the two digit number for the hour, then two digit number for the minute.
8. Press <start/memory> (The display will read [POLL SECURITY])
9. Press <stop> to exit.
Mar 11, 2010 | Sharp UX-B750 Inkjet Fax
Toshiba estudio 160 Password
Code 08- 263 does not work with the e160
And I cannot find anywhere in the service manual where it specifies how to read it...
Nov 09, 2009 | Toshiba Office Equipment & Supplies
How do i change the name on the phone
This should be what your looking for..
From an individual extension with a Display Phone:
  1. Press [ Feature ] [ 0 ] [ 0 ]
  2. Press [ Left Intercom ] one time. The display reads: Enter Name (If a name was previously assigned to this extension, it displays instead.)
  3. Enter the two-digit code for each character you want to enter. (See Valid Entries below)
    For example, to enter the name Andy, press [ 2 ] [ 1 ] [ 6 ] [ 2 ] [ 3 ] [ 1 ] [ 9 ] [ 3 ] . The display reads: 12 ANDY
  4. If you make a mistake, you can press [ Mic ] to clear the display. Repeat Step 3 to enter the correct name.
  5. Press [ Feature ] [ 0 ] [ 0 ] to exit programming mode.
Valid Entires:
Letters A-Z, numbers 0-9, and blank spaces.
Character and Digit Codes:
Letters: Numbers:
A=21 N=62 0=00
B=22 O=63 1=10
C=23 P=71 2=20
D=31 Q=72 3=30
E=32 R=73 4=40
F=33 S=74 5=50
G=41 T=81 6=60
H=42 U=82 7=70
I=43 V=83 8=80
J=51 W=91 9=90
K=52 X=92 BLANK = 11
L=53 Y=93
M=61 Z=94
Mar 10, 2009 | Lucent PARTNER18 Corded Phone
Display blank
You need to replace the display backlight lamp.
Enter model number here to find assembly diagrams and parts.
Contact the seller by phone if part is not listed on the website.
Jan 02, 2009 | Ovens
Fax not being sent
Somehow, a group dial # has been set. Here is how to delete it:
NOTE: Group Dial Numbers are entered using the One-Touch keypad on the left hand side of the WorkCentre. To change a Speed Dial that is within a Group Dial, the Group must be deleted first.
  1. Press the [Menu] button.
  2. On the left hand side of the Control Panel press the One-Touch [12] button.
  3. The LCD Display will read 'Select One-Touch for Group [01-20]'.
  4. Press the One-Touch key to be used for the Group Dial.
  5. One of two displays will appear:
    • If the Group Dial number has not been used:
      1. The LCD Display will read 'Group No: ### 1. YES 2. NO'.
      2. Using the Dialing Keypad press [1] to accept or
      3. Press [2] to return to step four.
      4. The LCD Display will read 'Enter One-Touch / Speed Dial> ##'.
      5. Continue with step 6.
    • If the Group Dial number has been used:
      1. The LCD Display will read 'Group ## Used 1: Renew 2: Other'.
      2. Using the Dialing Keypad press [1] to 'Renew'. This will cancel the Speed Dial or Group Dial entry and the Group Dial will be deleted.
      3. Press [2] to keep the current entry and select another Group Dial
      4. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
        Thanks, Joe
Apr 26, 2008 | Xerox WorkCentre 470CX InkJet Printer
Dim Digital Display
Connie P, Unfortunately it is not possible to make the display brighter. The only solution is to replace the entire clock/timer. The price for the part is less then a hundred dollars and if you will give me the complete model number and a color, I can help you to find the best deal. Gendos...post back
Jan 06, 2007 | Frigidaire FEF326 Electric Kitchen Range
Canon P170-DH Calculator Logo
16 people viewed this question
old marine
old marine
