Question about Compaq Computers & Internet
Yellow light flashed - Compaq Computers & Internet
What is the yellow flashing light
In the cross-sections, when there is a yellow flashing light "a driver may proceed through the intersection or past the signal only with caution."
Mar 21, 2013 | iBuyPower Gamer Computers & Internet
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Hi, I have a pronto m51. The yellow led in the
If it's the yellow battery light it will blink when the battery voltage is very low, too low to drive and lower than the red blink.
May 10, 2010 | Invacare Supply Group Invacare Pronto M51...
When i turn on my PS3 it as it starts up a yellow light comes on
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
Apr 16, 2010 | Sony PlayStation 3 40GB System
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Having the yellow flashing light
Sounds like maybe a power surge killed the TV. If it is newer, try contacting the Manufacturer for warranty repairs.
Apr 16, 2009 | Toshiba TDP-ET20U DLP Projector
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
