Question about Gbc Magnapunch Die WireBind 3:1 Round
I have a GBC Magnapunch but i have no power - Gbc Magnapunch Die WireBind 3:1 Round
My gbc heatseal laminator is rolling back and foward continuosly .even when reverse botton is not press. why
Can be for two reasons.
The synchronous motor in it is faulty, or there is something wrapped against the roller and it is lifting the spring or throwing it into reverse.
Contact GBC direct
GBC heatseal laminator Google Search
Sep 01, 2017 | Gbc Office Equipment & Supplies
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
My gbc heatseal h300 wont feed paper.
I have the same machine, GBC H-300. I have it apart right now, and found the feed motor gear in pieces.
Motor Gear 18T 120v part #26700056
Mike Dettling
May 26, 2011 | Grilling
I'm looking for an owner/operator manual for a GBC 3260X1 shredder. Is there a link that I can go to?
Hi
Please click on below link for user/operator's manual for GBC 3260x Manual---
GBC 3260X1 shredder User/Operator's Manual
Hope this helps...
Daniel
Oct 08, 2010 | Office Equipment & Supplies
GBC dloads
No. 1, they aren't compatible, and 2, there is no left or right trigger on the gbc
Sep 16, 2008 | Nintendo Game Boy Color Console
GBC CC85
Is the power indicator On? If not check your power source first. Check your main power cable. If its ok, check your fuse then. If all are ok. Try pressing the power button with force and longer time. Hope this fixes everything.
Sep 17, 2007 | Quartet gbc CC85 CC Shredder
Gbc Magnapunch Die WireBind 3:1 Round Logo
219 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
