Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Hot to replace oven ignitor
The oven wont start no clicking sound so is not ingnating
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Here is a link to the igniter to order and there is also a video on that same page to show you how to make the repair.
Posted on Oct 26, 2013
Oven heating up very slowly on Viking VGRC 365-4QDDS.
hot surface ignitors are notorious for failing or getting "weak" and not draw enough amperage ( 3.2 - 3.6 amps ).... replacing both ignitors is always a good idea to start out with as the gas bi-metal valves don't fail very often. Ignitors can be replaced relatively easily ( with the POWER OFF ).... replacement ignitors can be ordered here, im sure..Ceramic bases should be similar / exact size and mounting bracket should be as close to exactly the same as original as possible!!!
Replacement for Viking igniter: click here Flat Style Oven Igniter Kit
Jan 12, 2014 | Viking Kitchen Ranges
My oven wont stay hot while baking?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Whirlpool Kitchen Ranges
Hot point oven wont light ,ignitor glows but seems like no gas.top burners work
heatman101
Jun 04, 2010 | Hotpoint RGB528 Gas Kitchen Range
Takes a long time to lite
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has failed...
Yeah it sounds crazy, but read this..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 03, 2010 | Maytag CWG3600A Gas Single Oven
Igniter comes on but gas won't light
It should glow almost a bright white. If its just an orange glow then replace the ignitor. Its probably just weak. If its weak it will not allow enough current to flow through it to open the gas valve. Good luck _MJ_
Mar 24, 2010 | Frigidaire FEB27S5A Electric Single Oven
Oven wont light unless you turn on a stove eye and
Sound`s to me you need a new hot surface ignitor. Sorry to hear you may have changed the valve & regulator for nothing, but that happen`s quite often when you get the symptom`s you`ve described, I`ve even seen tech`s. do it. The reality is 9 times out of 10 when a hot surface ignition gas/lpg oven won`t light it is the ignitor.
Pick up part number 74007498 for approx. $40 and you`ll be cooking.
Hope that help`s. If so please take a second and rate the solution I provided here at fixya for you.
Good luck.
macmarkus :)
Dec 05, 2009 | Maytag Kitchen Ranges
My kenmore oven igniter doesnt click and there is no gas getting to the oven
Oven ignitors are not the "clicking" variety - they use a hot surface ignitor and "feed through" to a current sensing gas valve - in short, if the ignitor is going bad, then the gas valve won't open (safety). Try replacing the HSI in the bottom of your oven - do an online search and match up model and serial of your unit to the part. Be careful no to touch or break the new ignitor - VERY FRAGILE!!!
Aug 31, 2009 | Kenmore Ovens
I have a gas oven whirlpool sf3020ekq2 buners work but oven won't
Sounding like your hot surface ignitor is getting bad. What I would like for you to do is open the oven and take the bottom panel off. This is so you can see the hot surface ignitor. Turn the oven on and look at the hot surface ignitor it is down on the bottom right next to the burner assembly. Does it start to glow and turn cherry red? This ignitor isn't too hard to replace couple of small screws and two wires. Will have to cut the wires so disconnect the unit from the 120 volt plug. Now if it starts to glow and get cherry red hot then the gas valve is sticking and it is the one going bad. That is a little tougher to replace. Turn the gas off at the source and get your wrenches unscrew the gas valve small space so if you want remove the door by just pulling it off the hinges.
If unit is old and you don't like it anyway maybe santa would be good to you and replace the stove oven. The gas valve is about 60 bucks or so and hot surface is about 20 bucks. let me know how it turns out.. ken
Dec 16, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Oven wont light
there is continuity, you can tell that by the glowing ignitor, althoug otslooks like its glowing red hot, it need to pull a certain amperage to open the valve.i would reccomned replacing the ignitor.with 99.99 percent certainty
Mar 11, 2008 | GE JGBP28 Gas Kitchen Range
Oven wont start
The control sends voltage down to the ignitor, the ignitor glows red, when and if the ignitor gets hot enough it opens the gas valsve to let gas in which is then lit by the ignitor.
If ignitor glows either the ignitor is bad or the oven valve
If the ignitor does not glow then either the ignitor is broken, the control is not sending voltage down, or the oven valve is bad and not sending voltage to the ignitor.
In most cases it is the ignitor which is the cheapest of the three parts
Oct 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
