Question about IdentityGuard Cross-Cut Shredder
Shredder is plugged in but nothing works - IdentityGuard Cross-Cut Shredder
My shredder won't seem to come on at all its a model OM96580
The shredder may have become jammed or overheated or both and the motor has failed.
Aug 06, 2016 | OfficeMax Office Equipment & Supplies
Unit runs with nothing inserted into shredder
About 598,000 results (0.73 seconds) Search Results
    [PDF]Shredder Troubleshooting FAQ
    https://images-na.ssl-images-amazon.com/images/I/81GTHxKpz9S.pdf
    Make sure that the unit is securely plugged into a working outlet / socket. 2. If you have ... The shredder runs but it does not pull paper down. 1. Be sure the ... When ready to shred, be sure to insert material directly into the center area to start.
    [PDF]Instructions Manual
    https://images-na.ssl-images-amazon.com/images/I/71EUxqIkPNS.pdf
    you leave the shredder in the "Off" position whenever the shredder is ... To beginshredding, locate the switch on the unit and select the "Auto" mode (FIGURE 2). ...Your basic vegetable or cooking oil (nothing flammable ... a) While in "Auto" mode, the motor will not start running until paper is inserted into the feed slot. Set.
    General Shredder Troubleshooting - iThinkBlue
    store.ithinkblue.com/shredder-troubleshooting/
    Make sure that the unit is securely plugged into a working outlet / socket. ... While in "Auto" mode, the shredder will not run until paper is inserted into the middle ...
    [PDF]troubleshooting paper shredders - Ativa
Jan 31, 2016 | Shredder Office Equipment & Supplies
Shredder doesn't work. New, within last year. Why, and what should I do?
Always include make and model info since different machines may have different devices in place to protect against overloads.
Nov 23, 2014 | Shredder Office Equipment & Supplies
Why do my fellow ds-3 shredder not turn on?
http://assets.fellowes.com/manuals/DS-3%20Manual_1L_2010.pdf
Check and make sure the receptacle where it is plugged in has current. Unplug the cable and then plug it back in. You have an Over-ride switch on your unit, try it. If it still does not work you will have a power supply problem.
Aug 18, 2014 | Fellowes 3231001 8-Sheet Ds-3 Deskside...
Shredder doesn't shred.
Shreader wont cut will reverse ok
Dec 17, 2012 | Office Equipment & Supplies
Plugged in and is on but nothing works. Is there a light that should come on? Is there a sound that you should hear?
Make sure you have it in the basket correctly. There is a small switch in the shredder head that must be in contact with the nib in the basket. Don't try to bypass it...it is a safety switch.
Oct 07, 2010 | Fellowes (30138) Shredder
Jam light comes on but there is nothing in the shredder
take the plastic top off of it by removing the four silver screws (two front two back)
in the upper left there is a circuit card that the top of the shredder is connected to by a ribbon cable.
ensure all the cables are plugged in (there is a small black plug near the top that has a habit of coming loose it seems).
If they are all plugged in, disengage them and clean all the connectors (i recommend using rubbing alcohol) and then plug them back in, test to make sure that everything is working before screwing the lid back on completely.
and as a final note: i highly recommend making sure the shredder is unplugged from the wall socket prior to opening it up to work on it, as with any energized equipment keeping it off while poking around inside of it is always a good idea.
Aug 01, 2008 | Dahle High Security 20634EC Shredder
IdentityGuard Cross-Cut Shredder Logo
44 people viewed this question
Top Identity Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Identity Office Equipment and Supply Expert? Answer questions, earn points and help others
