Question about Refrigerators
I have a hotpoint ff187 l water is comeing out on the floor
    Problem Solver:
  • 13 Answers
At the back of most fridges is a small channel with a drain hole. The condensate drips out of this hole through a small pipe and usually onto a tray on top of the motor. At the motor it simply evapourates. Sometimes when cleaning the fridge this pipe can get pushed off at the back so water drips through the back and onto the floor.
Posted on Oct 22, 2013
We have hotpoint wma63 on draining and spinning water on floor seems to appear
well I would look for a loose or damages hose fitting while it is working .
Feb 22, 2015 | Hotpoint Washing Machines
How do I disconnect the water line in the bottom of the door in hotpoint model csx24gr
Hi Cheryl,
to do that open the freezer door,remove kick(toe)plate, on the left side under the hinge you will see a plastic union coupling the tube from the resevior to the tube inside of the door unscrew that union and pull the tubing apart. BE PREPARED for some water in the tubing to come out onto the floor and possibly all the water in the resevior may also come out ontothe floor so have a few towels ready
Jul 22, 2011 | Refrigerators
Hotpoint. Water is leaking from behind light bulb
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Oct 22, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint ctx18 ref has water on floor on defrost cycle
Look on or under the compressor. There is a drip pan there.
Eric
Jun 29, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
It leaks water onto the floor.
Where is the water coming from? unless you have a leaking ice maker fitting on the back or somewhere else, the most likely cause would be a stopped up defrost drain. check inside the freezer on the back wall and floor. if you see ice you will need to unstop the drain. (most newer models don't have a removable drain pan)
Nov 08, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint Aquarius WD440: IT seem when it supposed to pump the dirty water out,the waters are not coming,but if i take the pump and put down on the floor ,the water are coming out and it run the whole spin...
If you are getting voltagae to the pump and the water is not pumping out then you have a bad pump, just replace it and you have the problem solved, If you do not have voltage then we would have to find out why.
May 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
