Question about Hitachi DZ-MV380A DVD Camcorder
Turn on camera after access disk display goes off error code 2281 appears
MPC 2550. What is error code sc 865 01?
SC865 (HDD access error) is displayed when the power is turned ON, and SC819 (kernel stopped) is displayed when the power is turned OFF and ON.
Some broken files may be left in the HDD image disk space.
Repair by initializing the HDD image disk space (SP5-832-002).
Dec 17, 2012 | Ricoh Office Equipment & Supplies
Read error appears after downloading pictures and looking back in the camera, some pictures have read error
When you hook your camera to your computer you are accessing it like a disk and changes made to "files" are saved to the disk. A common change is to rotate the image so it views correctly on the computer screen for images you turned the camera to take a portrait oriantation shot. That change is saved to the image on disk, then the camera can no longer display it because it is not the right "dimensions" for the camera (it is rotated)
Dec 13, 2011 | FUJIFILM FinePix S2950 / S2990 Digital...
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
Camera will not switch on/off properly, and "E18" appears on the screen
"E18"indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 06, 2010 | Canon PowerShot A95 Digital Camera
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
ERROR CODE E63:20
sir E63 ERR is related to lens err ur camera lens unit dislocated or gears problum. this is easyly repairable
Dec 31, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Oct 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
Problem with my camera
Your lens is jammed, and needs to be repaired or replaced.
Sep 04, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Hitachi DZ-MV380A DVD Camcorder Logo
15 people viewed this question
Top Hitachi Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
PNiss
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
