When i'm filling gas my 04 santa fe, when it's full, the gas spills out of the filler neck.
    Problem Solver:
  • 24 Answers
Is the car rusty? You might have a hole hear the top of the neck / tank.
Posted on Oct 22, 2013
My 2002 Hyundai Santa fe has trouble taking fuel..what are possible problem s?
When I had this problem I had a blockage in my filler tube causing gas pump to think tank was full.
Jan 14, 2018 | Hyundai Cars & Trucks
My 2004 hyundai santa fe has its check engine light on when i run it for codes p0443 comes up how do i get this to clear
Hi Amy,
My Dad's Santa Fe had a similar issue. It was correctly determined that the filler tube (between the gas cap and the tank itself) had begun to rot through. This is because of the way the metal tube passes through the wheel well to bring gas from the filler opening to the tank. Dirt becomes trapped (and builds up) between the tube and wall of the wheel well. When wet, it takes a long time to dry out and is a sponge for moisture. He first noticed an occasional whiff of gasoline when filling the tank (not all that unusual really) and then later, as the holes got larger - drops of gasoline appeared on the ground when filling the tank. If there's a lot of dirt wedged in there - you may not see gasoline leaking onto the ground though, so don't think if you don't see the gasoline - it's not rotted.
Santa Fe Fuel Filler Tube
The cost of the repair at the Hyundai Dealership was about $300. You might also want to visit the dealer to have them inspect your Santa Fe's "subframe" for rust / rot. My dad's Santa Fe had issues and this $2600 replacement was covered by the factory even though the car had been out of warranty for many years.
Let me know how you make out - I hope this helps & good luck!
Nov 20, 2013 | Santa Fe 2010 Hyundai Owners Manual,...
Gas spills back out and pump shuts off when trying to pump gas
Tank vent pipe is blocked, causing pressure that can only vent via the filler neck. You will find that the pipe is caked in mud. Locate the pipe (it's like a snorkel on the tank near the filler neck) and insert a straightened paperclip into the hole to remove the mud.
Alternatively, fill slower with the gun nozzle slightly at a twist in the filler neck.
But you almost certainly have a blocked tank vent pipe.
Dec 19, 2012 | Jeep 1998 Grand Cherokee Laredo
What is the outcome of having a broken gas filler neckon my 2001 caravan
Other than spilling gas on the ground when you are filling up, the check engine light should come on because the system is not sealed.
Jun 24, 2012 | Dodge Grand Caravan Cars & Trucks
Fuel light comes on when tank is just below full and can go all the way to e and back up,and a strong oder of gas in the car running and not running
The rheostat on the fuel sending unit is bad causeing a bad fuel reading. Check you vent lines on the tank and filler neck for leaks.
Aug 04, 2011 | 2003 Hyundai Santa Fe
I have a 2002 Chevy blazer and it has a problem filling up the tank. It acts like it is full even when it is empty. What do i do to fix this
the vent tube in the filler neck is either plugged or disconnected, remove the filler neck to check it, lack of ventilation causes the gas to foam in the filler neck and triggers the filling nozzle
Nov 07, 2010 | 2002 Chevrolet Blazer
I have a hard time starting my 04 Santa Fe after i fill up
it was running then you removed the gas cap to fill ( extremely dangerous practice with car running)
that indicates that there is a problem with the EVAP system.
run the fault codes ( what the dealers should have done first ) and check for the EVAP codes , purge vent or solenoid problems
Apr 02, 2017 | 2004 Hyundai Santa Fe
I have a 2003 sante fe that has died with a full gas tank. I have tried syphoning the gas out but it appears there is something blocking the syphon hose from going all the way into the tank. any...
there is a roll over ball blocking you if your vehicle was to roll over there is a ball that will close off filler neck trapping fuel for safety purposes under vehicle follow the filler neck down to tank beside the big filler neck hose should be a smaller hose remove that hose from tank and insert your syphon hose there this should work for you i assume you have determined that the uel pump is your problem and are trying to access the pump??
Apr 26, 2010 | 2003 Hyundai Santa Fe
Gas Leaking
There is likely a rust hole, or puncture in the neck of the gas tank (the pipe leading from the tank to the gas nozzle). When you are filling the tank the gas runs through the pipe and leaks out of the neck. when you are done filling, all the gas is in the tank, and not high enough to come out of the hole. You can probably pull the cover off the inside of the wheel well, and see the leak. if your lucky, you will be able to patch the hole.
Dec 30, 2008 | 2001 Hyundai Santa Fe
Fuel spills out when I fill up.
It is the filler neck it causes splash back.
Oct 09, 2008 | 2005 Ford Freestar
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
