Question about Craftsman Garden
Model # 358.350990 ... saw died while cutting...found small blue rubber plug with star washer... loose in bottom of fuel tank ...reattached to only line in tank it could go to... still hard to start and dies right away ..
  • George Freeling
    George Freeling Oct 24, 2013
    star washer and blue rubber plug are actully part ot gas cap
Check line for leak have u changed fuel filter inside tank
Posted on Oct 24, 2013
4 Suggested Answers
picatudo
  • 239 Answers
SOURCE: Chainsaw is extremely hard to start and won't stay running.
adjust the two little screws on the carburator
Posted on Dec 31, 2008
dontbother10
  • 2220 Answers
SOURCE: How to connect the fuel lines for Poulan Model # 1950 Chain Saw
The following link should be very helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
A link to a Poulan model 1950 Type 7 follows (may not be your saw, there are 7 different Types and 2 Woodsharks (LE))
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 22, 2010
  • 5 Answers
SOURCE: Homelite chainsaw won't stay running
I have a Homelite 33cc which has never run smoothly since it was brand new. Erratic running, sometimes wont idle, and never seems to develop full power. Adjusting the jets achieved no lasting improvement. In frustration I stripped it down right back to the intake port on the cylinder and found the problem. The two screws that hold the the carb mounting plate to the cylinder were a tad too long in manufacture, and even though done up very tight they bottomed out in their holes before applying proper pressure to the sealing gasket, which then developed some "flutter" in the airflow and partially disintegrated, leaving massive air leaks. No way it was EVER going to run properly like that. Check that this isn't the problem area on your particular model before you go crazy trying to tune your carburetor.
Posted on May 07, 2013
Pro ppb150e. Why is it cutting out after a few minutes of operation?
I have not seen this model of saw. If the fuel cap is on the top of the saw try running it with cap slightly loose. This will allow air come into the fuel tank. I have also seen vent holes in the fuel cap get plugged with saw dust. If this is the case just clean it out with a small piece of wire.
Nov 25, 2015 | Poulan Garden
Cuts out at highway speeds
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
roadstar 1600 cutting out at highway speeds CycleFish com
Re HELP Star 650 dies at half throttle Road Star Forum Yamaha Road Star
Yamaha XV1700P Service Manual
OEM parts for Yamaha
Yamaha XV1700PCR Road Star Warrior Owner Manual
Mar 09, 2014 | 2002 Yamaha Road Star Silverado
Saw runs for 5 minutes and bogs out
This is sometimes caused by dirt in the gas tank. When the saw is off and being moved around the dirt settles to the bottom. The saw will start OK and rev up but after a while the dirt gets shaken up and sticks to the fuel filter in the tank. When enough dirt covers the filter the saw looses power or dies all together. Sometimes it will get enough gas to idle but not enough to run at high speed. With the tank half full, shake the saw to get all the dirt stired up and dump it out. Put a little gas in it and shake & dump it again. If you can fish the fuel line with the filter on it out, remove the filter and either replace it or blow it out. If this doesn't cure all your problems you may have leaks in the fuel line to the carb that are letting in more air than gas causing your power problems.
Jul 14, 2012 | Makita DPC7311 73cc 14Inch Gas Powered...
55 rancher leaks thru the gas tank vent
a small amount of fuel leakege shouldnt hurt anything most gas tank vents are in the fuel cap if so replace cap
Nov 15, 2011 | Husqvarna Chain Saw 20" Bar
PP3516 ran slow for a while then quit.
Recheck the spark--if the plug is wet, it should have at least popped several times. Try a new plug gapped at 0.020". Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage--if replacing any, use original rubber lines only, not plastic. Does the primer bulb fill with fuel after several pumps? Remove the carburetor, and clean it inside and out with spray carburetor cleaner. Look closely at the lower chamber diaphragm which should be pliable with no holes or other damage. There is a small filter screen within the main body that can get plugged with stale fuel. Check the components between the carburetor and cylinder for any damage. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting which also applies to other carburetor brands as well. Hope some of this helps!
Jul 13, 2010 | Poulan ES350 16" Chain Saw
23cc weedeater fuel line to filter in tank is rotten
1st get new line. find where it goes on carb. pull the line out of the tank .cut a pc. of new line longer then what you need ,cut the end of the tubing with dia.pliers at a long angle then push it into the tank untill you can fish it out hook it back to the filter pull the extra tubing back towards the carb. leaving the filter at the bottom of the tank
Jun 18, 2009 | Craftsman 25cc Gas Line Trimmer
Lose gas line poulan weed eater
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines.
(HINT): when feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
Jim
Jun 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Loose Fuel Line In the Gas Tank
hi rhopdo
try to find the spark plug near the muffler(exhaust)
check where is the hole from the gas tank, connect the fuel line to the carb.
yours savumihai71
Dec 01, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Chainsaw kills when I press the throttle
My 372 xp did that and when I talked to the repair shop they even showed me. There is a fiberglass gasket that is used to mount the carburetor to the engine. I have no idea on how this happens, but I saw it with my own eyes. The gasket had actually folded over. They replaced it with a rubber one and have had no problem since. The saw was hard to start, would run as long as I didn't try to cut anything and when I did it would open up and then die. I could be giving wrong information, but that sounds exactly like the problem I was having.
Oct 08, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
91 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
