My sony vaio PCG-61211M won't boot from CD. I enabled booting from external drives and optical station is listed first but it won't boot. Bootcd is fine since I recently booted other pc's from it. I heard something about getting the laptop in Legacy boot mode but I can't find how to do it and/or if it works at all. So maybe anyone can help me?
  • Anne Zohlandt
    Anne Zohlandt Oct 22, 2013
    I tried this but it doesn't work. When I hit F11 it does try to read the disk (or that's what it sounds like) and stays a little while longer on the black screen (I suppose because it's trying to boot from CD) but than boots Windows anyway. I followed every step perfectly and I'm absoluty sure I did it the right way. So what else could it be?
    Master:
  • 630 Answers
Open this link and step by step follow instruction. May be solved your problem.
http://www.sony-asia.com/support/faq/31260
Thanks..
Technical Support
Posted on Oct 22, 2013
5 Suggested Answers
  • 44 Answers
SOURCE: Sony Vaio not Booting
Have you tried booting with a windows cd, and then running a disk check?
Posted on Dec 18, 2007
tat4u
  • 520 Answers
SOURCE: CMOS Battery
you want to be looking for the rtc(real time clock) which is a little unit not much bigger than ur thumb nail.next to it youll find the battery(sometimes heat sealed with plastic.)if you remove this battery for about 5 mins then replace it or in ur case maybe renew it this will reset bios to factory(also method for bypass passwords as every thing is reset)
you might also wanna check ur video card.(connections and dust)
Posted on Mar 04, 2008
SOURCE: Continuous Boot up - sony vaio PCG-1C1N
it is actually a sony pcg-u3???
if you press F8 and go into safe mode and then do a disk repair this will solve the problem for you,
also if you have got a cd drive then mount the winxp image to a memory stick duo and use disk repair from that...
Posted on Feb 08, 2009
graysand
  • 558 Answers
SOURCE: Laptop will not boot, Sony Vaio VGN CR220E, lights
I need you to try a few things.First remove the battery,memory no power whatsoever.Press and hold the power button for twenty seconds.Replace the memory then the ac cord and try again.Remove the power only this time and press and hold the power button again.Now replace the battery and the power adapter.Power up and you should work if not you will need to replace the motherboard.
Good Luck
Posted on Nov 11, 2009
How do I get motion eye driver installer for sony vaio pcg-61211m compatible in windows 7
Try here - http://driversdownload4u.blogspot.com/2013/11/sony-vaio-pcg-61211m-drivers-win7.html
Sep 25, 2014 | Computers & Internet
Boot from usb
go to bios menu and boot option boot external drive enable and change the boot order that's all
Sep 06, 2013 | Sony VAIO PCG-K23 Notebook
Where can i get a cd drive for a sony vaio pcg4
External ? http://www.bestbuy.com/site/Optical-Drives/External-DVD-Drives/pcmcat189600050009.c?id=pcmcat189600050009
May 12, 2012 | Sony Computers & Internet
Vaio pcg671l lost external power (no problem for the power supply cord, work well wit battery). I am looking for a compatible docking station as external power instead.
hi
hi. I would like to suggest you get these parts are offline, because it's easy for you to test before buying {make sure you match the parts before buying}
regards
May 15, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
Hello. I have Sony Vaio PCG-5426. And I can't reinstall windows on that machine. I have out CD-ROM "II FreeCom" and i try to reinstall with that. In BIOS menu I acces for first boot drive...
you shouldn't need to have to press f9 to boot from cd rom if you have it set in the bios as the first boot device , are you sure the copy of windows on cd that you have is bootable. Try booting from the disc on another laptop or pc and see if you can start it
Another option to try is to boot from a usb drive
instructions on how to do that are here
http://www.xtremesystems.org/forums/showthread.php?t=118576
once you have booted to usb you should be able to access the cd rom
depending on what version of windows you are trying to install you will need to run different programs.
you could also install vista or windows 7 to usb drive and install it from that, it is much quicker than installing from cd/dvd you would need to be able to boot from usb to start with though
how to install vista or windows 7 from usb instructions can be found here
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
please vote for me if you found any of this useful
Feb 20, 2011 | Sony VAIO PCG-5212 PCG-5426 PCG-551L...
Sony Vaio PCG-6L7P unable to boot. Unable to load
HARDWARE PROBLEM, TRY TO RESET THE BIOS OR REMOVE THE REMOVABLE DISK CD/DVD ROOM, THEN USE EXTERNAL
Jun 26, 2009 | Sony Computers & Internet
No boot
check the cd rom again make sure its plugged in ok, ,
with the hard drive you usually can hear it spinning or ticking
before buyin a new hard drive i would try to reinstall windows
Apr 02, 2009 | Sony VAIO Notebook
How Do I Boot A Sony VAIO PCG-Z505LS model # PCG-531A?
The BIOS one can usually be eliminated  by disconnecting the battery and shorting the terminals, if necessary, then plugging the battery back in.    The administrator pass work can sometimes be gotten around by pressing the F8 while loading,then changing it.   The most undesirable option is to reformat and buy another OS.   Sorry for the hard time.
Feb 16, 2009 | Sony VAIO Pcg-Z505LE Notebook
Sony pcg k45
Put the cd in and restart. If it doesn't give you a message to press "x" to boot from cd, then you need to chage the boot order in the BIOS.
To get into the BIOS, restart and press del or F2 (it might say something on the screen like press del to enter setup) that is the BIOS.
Change the boot order to CD first.
Dec 18, 2008 | Sony VAIO K45 Notebook
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
