Question about Sharp Aquos LC37D44U 37 in. LCD HDTV
Tv diagrames Please, I need the Service Manual or Diagram for Power Supply for This LCD Tv: Sharp Aquos LC-37D44U. Very much thanks for your attention.
    Top Expert:
  • Sharp Master
  • 75,571 Answers
Schematic diagrams are in PDF, and cannot upload by this window. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 23, 2013
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: I need a diagram for lcd tv Sharp LC-26SB14U.
I have a sharp LCD (LC-26SB14U) which I purchased one year ago and today the sound stop working as I was watching the olympics. Any idea how to fix this problem as the warranty is only good for a year.
Thanks, Bob
Posted on Feb 27, 2010
budmrtn
  • 11361 Answers
SOURCE: Sharp Aquos LC-42DH77E 42" LCD TV TV appears to
The PNL-POW (LCD panel Power) and the PS-ON will be 0V until the main board send out the signal to turn them on, it is working.
Do you get backlights?
Did you check the fuses on the Inverter board? You power supply is working.
This service manual may match your chassis:
http://elektrotanya.com/?q=showresult&megnev=Sharp&megnev2=LC-42DH77E&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 01, 2011
Testimonial: "Helpful"
gopakumarg43
  • 75571 Answers
SOURCE: Need user manual for 42"sharp aquos lcd tv
Hello
Get into this link. You can download the user manual for your device absolutely free.
www.retrevo.com > Sharp Manuals > Sharp TV Manuals
OK.
Posted on Jul 09, 2011
SOURCE: I have a Sharp AQUOS LC-19SB14U 19' LCD TV that won't power on
my la22a450c1 has no sound and picture . what's problem ?
Posted on Feb 10, 2013
I am ready to pay for the service manual or circuit diagram of Sharp Lcd TV model:LC-22L50m-BK please help
Contact Sharp directly to request the service manual and schematic diagram for model LC-22L50m-BK.
Feb 27, 2018 | Sharp Televison & Video
I have a sharp aquos lc-37d44u and I have the blinking green power light problem I replaced the backlight inverter board still nothing and the only thing i.think it could be is the lamps but Don't no
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. Check all the CCFL lamps for darkened ends. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 27, 2016 | Sharp Lc-37d44u LCD Tv
How do I replace fuse?
Sharp LC46D43U - Aquos - 720p LCD HDTV Service Manual
www.manualslib.com > ... > Service manual
Flat Panel TV Sharp AQUOS LC-46D82U Operation Manual. Sharp flat ... Flat Panel TV Sharp LC46SB54U - LC - 46" LCD TV Operation Manual. Operation ...
Sep 11, 2015 | Sharp Televison & Video
Hi Rebecca,
Please click this LINK to download the Pdf file format of Sharp LC-42D65U User Manual.
Click "Download Document", enter your email add, enter the confirmation no., and then click "Download". It is a safe website, I used it personally.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Jul 09, 2011 | Sharp Televison & Video
I need a new power supply for this model tv...Sharp Aquos LC-22SV6U 22 in. EDTV LCD Television...where can i find one and how much do they cost?
You could ask a tv repair shop to order you one but would be cheaper if you phone manifacturer and get them to send you one out if this helps please give thumbs up thanks
Feb 13, 2011 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
If my Sharp Aquos 37in LC-40C37U tv needs to be reset how would I do that? Not getting any power, only a green blinking light. The power supply board checked out ok.
Blinking light is an error code. Count the blinks before they repeat. Check your manual in the troubleshooting section. If you can't find it, contact a Sharp service center or try and get a service manual. Reset info is also in the user manual but you can't do it if your set doesn't power up. Are you sure about the power board?
Apr 30, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Blinking led
Free diagrams unlikely to be available take the board's out and check for blown capacitors following good antistatic procedures and decide from there
Or find a good independent repair specialist to do the work and set your self a budget
My sharp aquos stopped working with a blinking power light £2000 was the repair quote for a new board and LCD panel for a £699 TV after they tried the capacitor replacement
Jul 01, 2017 | Sharp AQUOS LC-40C32U 32 in. LCD TV
My Sharp Aquos LCD TV LC-40C37U will not power up. The green power lamp at the bottom right is blinking. We had a power surge last night, I even measured 180V on the power outlet. Is my TV now damaged?
Good day sir/maam, chances are, yes or no, yes, the surge do has the ability to damage your TV, but no, modern TVs are autovolt (it can work from 90v-240v) so check the manual or back panel to confirm. The most deadly part of the surge is it can hit more than 500v at a split of a second, damaging your TV's switching power supply. The TV's power supply is bad. it cannot produce the proper voltage to power your TV. thats why its on standby. Bring it to your dealer for proper advice on the status of your TV.
Oct 12, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Sharp Aquos LC-30HV4U
replace the supply board
or repair it *** there's problem with supply
Jun 13, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sharp Aquos LC37D44U 37 in. LCD HDTV Logo
145 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
