Question about Craftsman Garden
Flywheel key keeps breaking - Craftsman Garden
    Sergeant:
    Champion:
  • 320 Answers
Hello Bob
My name is George. I am a repair technician at a local shop here in Hickory N.C.
The reason the key keeps shearing is that the flywheel needs to be torqued to the engines specifications. Once you do this you will be ready to go again.
Thanks for letting me try to help.
George
Posted on Oct 22, 2013
3 Suggested Answers
BAMOUT
  • 2478 Answers
SOURCE: briggs & stratton backfires & breaks flywheel key on starting
Be sure blades turning easy, one of spindel may have a bearing out or going out.
Posted on Nov 26, 2011
  • 6468 Answers
SOURCE: model 31p777 flywheel keeps breaking after i put the key in
the flywheel key keeps breaking or the flywheel itself does?if it's the key the blade might be bent
Posted on Jul 16, 2012
Flywheel keeps breaking
By breaking I assume you mean into pieces? The only thing that would cause this is a badly misaligned transmission. Any other problems would cause such vibration you would not drive the vehicle .
Oct 14, 2015 | 1986 Ford Ranger 2WD
WHAT KEEPS BREAKING THE FLYWHEEL KEY/ CHANGED IT OUT TWICE. DOESN'T SEEM TO BE ANY DEBRIS IN AREA, DOESN'T SEEM TO BE CATCHING ON ANYTHING
Hi Tami:
When you replace the key, the flywheel attachment nut has to be really tight so that there is absolutely no slop in the flywheel connection. Give it another try. Don't strip the threads, but also, don't be afraid to pull on the wrench.
Apr 26, 2015 | Measuring Tools & Sensors
Flywheel breaking
If you aare sure the securing nut is tight, then it has to be a problem with the taper on the crank, it is the taper on the crank that holds the flywheel, the key is just to align the ignition timimg.
Oct 12, 2013 | Garden
Model 31p777 flywheel keeps breaking after i put the key in
Jul 14, 2012 | Briggs & Stratton Garden
Briggs & stratton backfires & breaks flywheel key on starting
Nov 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Runs rough and kicks back when pull starting
The timing may be off. Has this mower ever hit anything while running. There is a small aluminum key that keeps the engine in time (flywheel to magneto) and it breaks if the mower blade hits an immovable object (rock, tree stump, meteorite etc.) The timing will be skewed and symptoms like yours will result.You can check the flywheel key by removing the cover on top of the mower and the starter/recoil unit.The key is in a slot on the top side of the crankshaft and fits a notch inside the flywheel. Look carefully. If it is sheared, the notch in the flywheel will NOT be lined up with the notch in the crankshaft and a new key will need to be installed after removing the broken one.
May 04, 2011 | Briggs & Stratton Garden
My son hit a log with my js25 walk behind mower now it won't run.
He more than likely sheered the key in the crankshaft. When the key bends or breaks it throws the timing off and the engine will not start. The key is there to prevent damage to the crankshaft when you hit an object. You will need to remove the engine cover and then use a puller to remove the flywheel. Where the flywheel connects to the crankshaft you will see the key which is either broken or bent. All you do is buy a new one and replace it.
Apr 23, 2011 | Garden
Where is the flywheel key on a briggs and stratton
its between the crank and the flywheel on top side of engine, they sheer if you hit something. its a cheap easy fix if engine hasnt been damaged
Sep 04, 2009 | Garden
Mower wont start
You will need to replace an aluminum "key" in the flywheel. Whenever you hit something, the key is designed to shear so you don't break something major.
Sep 02, 2009 | Toro Lawn Mower With Toro Power Tools
Flywheel key breaks. Relaced 3 times
when you replace the flywheel key
the flywheel should be re torqued to 30 ft lbs
be sure all attatching areas are clean-no oil
check keyways to be sure they are in good shape flywheel and crankshaft
just a couple items to check and may help out
Jun 02, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
51 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
