Question about Water Heaters
Potterton heatmax he 28 when I use the hot water it keeps going from hot to cold with the temp gage going up to 92c then burner will stop and then start up again at about 60c it will not keep a steady temp any thoughts thanks
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
the problem was solved on my system by replacing thermostatic valve on shower and putting non return valves on hot and cold feed to shower . the problem was caused by cold water getting into the hot water line through the shower hope this helps
Posted on Dec 30, 2008
mrgrzz
  • 88 Answers
SOURCE: Vaillant turbomax 28 constant hot water problem.
got your fix, its a calcium buildup in the heat exchanger, and more than likely the rest of the unit, you will need to flush the unit with about 4 gallons of vinegar, you will need to recirculate it for about 20 mins through the unit, then flush with clean water, hook it back up, it might take a couple of mins for it to run properly, but it will, I have had the same problem with Rinnai on demand hot water systems, and it worked like a charm, check the filter thats inline as well, make sure it isnt plugged, clean if needed, also if you dont have a soft water system inplace, you might want to think about buying one and having it installed, that will reduce this from happening again for alot longer period of time, hope that helps
Posted on Jan 20, 2009
co7196
  • 3433 Answers
SOURCE: my bosh water wizard 10P pilot light keeps going out.
Very possible the thermocoupler is no good. The thermo coupler is that bulb that is in the pilot flame. It controls the main valve It's not expensive and fairly easy to change out.. Make sure you get no dirt in the cspillary tube hole.brass screw end. The bulb must be just in the flame tip when adjusting. Good Luck, Ned-
Posted on Sep 17, 2009
john224
  • 1378 Answers
SOURCE: Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Posted on Dec 17, 2009
  • 905 Answers
SOURCE: water heater pilot and burner keep going out.
If this is a common occurrence, then it may be time to replace the thermocouple that controls the pilot part of the gas valve. If it still keep going out, gas valve may be faulty.
Posted on Jun 29, 2010
The burner on the heater is working bu can't get water to stay hot at the faucets or showers water turns cold right away. whats the problem?
Test for crossover, where bad faucet cartridge or recirculation check valve keeps hot from reaching taps
http://waterheatertimer.org/Crossover.html
Add a comment and say what you find
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 28, 2013 | Rheem Water Heaters
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
Not getting any hot water. Pilot light and burner seem to be working properly. Went from working fine in morning to not working at all this evening.
No hot water anywhere,or just one faucet,doesn't sound right if burner is working,if its coming on then your gas valve/thermostat on front is not working properly.Can be changed,but I would turn up temp. red dial see if she fires and watch to see if she stays on.Gas valve is threaded in and can be changed,depending on warranty.Could also be dip tube is cracked or broken in half,its a tube that forces cold water to bottem of tank,if not working you'll get a real short shower because cold water is in top of tank.Tube can be replaced,its on the cold water fill side which would have to be taken apart.Thinking now its your tube
Jan 27, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
Water Heater Keeps Going Off
is there a check valvle on hot water side of heater,a flow restriction of some sort, water pressure to the heater, a filter in the line, line pressure in the heater kicks out burner, when you turn on the water, line pressure drops, heater comes on, when you turn on water in other part of house, heater should not fire, so there has to be a check valve somewhere,in heater?
Jan 24, 2010 | Noritz 6.9 Gallon Residential Tankless...
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
New Noritz 751M-OD not getting up to temp.
check the thermostat this would be the only thing keeping it from getting to any temp,, other then the gas valve, is it constant or happens here and there;;;
Jun 03, 2009 | Water Heaters
Parkray Cumbria efficiency problem
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Nov 25, 2008 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
