Question about Echo Zama Carb Kit For Shc210 For Rbk66b Rbk70 Carb
Echo srm-210 powers up fine on a flat surface, but it cuts out after a few seconds in the upright (usable) position. I rebuilt the carb, cleaned muffler screen, good gas and fuel filter. tank lines seem okay. Any help? Thanks.
  • Bill R
    Bill R Oct 22, 2013
    I saw a suggestion to replace fuel cap. I'm not sure why. The vent is attached to a line coming out of the tank. Besides, it powers up and runs okay as long as it's flat on the ground.
    Sergeant:
  • 417 Answers
Make sure you rebuilt the carb with a carb kit. Put a hose on each pipe coming out of the carb and blow and suck on them. One should seal completely and one should provide vacuum. If there is a leak, you need new check valves. If you rotate the trimmer and it runs poorly, you may have a pierced diaphragm.
Posted on Nov 22, 2013
3 Suggested Answers
  • 203 Answers
SOURCE: cleaned carb on echo headge trimmer how do i redo
It will depend on what type of carburetor you have. You can go to this website and enter your model and it should give you the correct settings. If you cannot find the info, start with each about 1 1/2 turns out and go from there. A little hit and miss and you will figure the correct setting. When setting the high speed, you want to hold the throttle wide open and slowly adjust the screw. It will suddenly start to run very smoothly, and that's a good setting for the high speed.
http://www.echo-usa.com/faqs.asp
Posted on Oct 24, 2009
dmiesner
SOURCE: ECHO HC-1500 hedge trimmer wont stay running cuts off
Replace the fuel cap.
Posted on May 29, 2010
Echo SRM-210 Boggs down when at full idle
Hi Bobbi Jo:
Here's a link that will get you the user manual.
http://lawnandgarden.manualsonline.com/manuals/mfg/echo/srm210.html?p=1
Page 24 details exhaust carbon removal, and Page 25 gives carb setup info.
Hope this help.
Cheers
Jun 22, 2016 | Echo Garden
How do I fix a echo srm 210 weedeater that starts but will only run a few seconds?
Try calling echo and ask for tech support or go online to get the phone # or check you tube to see if they have a video on it
Apr 05, 2016 | Echo Garden
SRM 210 starts idles fine NO high rpm seems to have power just no high rpms
clean your carb and if you are using old fuel mixture, change it .
Oct 02, 2013 | Garden
High speed jet adjustment
the carb is dirty take the card apart the dirt is clogging the float
Aug 14, 2012 | Echo Garden
Starts but cuts off when engine gets hot
when it first dies check for spark or even better get a inline spark tester
Apr 06, 2012 | Garden
Echo es-210 stop running
This is as simple as it gets. If the carb is 10 years old and has not
been rebuilt in the past 2 or 3 years it will need to be rebuilt or
replaced. The average life of the diaphragms is about 2 to 3 years,
If your carb has limiters which will only allow the adjustment
screws to turn about 1/2 turn, you will likely not get any relief from
adjusting the carb. You will have to take the unit to a local dealer
for help. Most likely you will need to replace or rebuild the carb.
Sep 13, 2009 | Garden
Echo Zama Carb Kit For Shc210 For Rbk66b Rbk70 Carb Logo
182 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
