Computers & Internet Logo
Elisa Macias Posted on Oct 22, 2013
Don't know my username and password to my emachine computer.
Wally Minor
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Oct 22, 2013
Wally Minor
Contributor
Level 1:
New Friend:
Answers
24
Questions
Helped
2508
Points
63
If you forgot your username and password the computer might not even be yours to begin with. But you could always install linux / windows all over again and create your own.
1 Related Answer
info2u
Nouveau IT, LLC
  • 596 Answers
  • Posted on Aug 09, 2009
SOURCE: forgot password for my emachine computer
Boot your pc into safe mode, usually F10 as the pc power on, Go into the Control Panel, then users and you should be able to delete your account's password from the user's manauel.
Good Luck
C2Solutions
Factory restore emachine 5414
Does you machine have a Factory Recovery Partition? Usually "D' drive. Or are you using a DVD? Perhaps this procedure will help: http://www.ehow.com/how_4829262_reset-emachine-computer.html
Reset username on e442 emachine
is that the admin password or the computer password
2helpful
A few weeks ago, one of my daughters friends changed my routers username and password, can you help me to find out how they managed to do this please many thanks mrs t holder
If you don't know the IP address of the router, you can open Windows Explorer, click 'Network', and then double-click your router. You'll be redirected to a webpage where you must put in a username and password. If THIS is the username/password she changed, the only way you can change it back without knowing what she changed it to is by resetting the router.This is usually done by pressing a small button near the back. If she changed the password that other computers use to CONNECT to the router (i.e. wireless), then you'll put in your username and password- the default is 'admin' and 'admin', unless you changed it- and from there you can enter the wireless settings to change the password back.
Lost the password to accsess my wireless router when putting new laptop on belkin ADLS 2
In which computer you have inter net in that computer please click on START and click on RUN in that box enter CMD. You will get command mode. In that command mode type this command. 'ipconfig'. You ll get the ip address and gate way. Please close all of the window and open internet explorer in that same computer and enter the gateway ip address in that address bar. it will open new webpage. then enter the username and password of the router. in that window you can find the wireless settings and security key. If you don't know the username and the password of the router please open this link and find the name of your router in this page and take the username and the password. The Link is : http://www.phenoelit-us.org/dpl/dpl.htm
Hi, I have been looking for the default username and password for a MetroBlazer mb1210s switch, but I don't have my user manual anymore. Does anyone have a copy of the user manual or know the default...
Use console upgrade the RP_G0802LB_FW_v1.06.24.bin firmware, then downgrade back to RP-G0802LB_FW_v1.05.06.bin. part of the configuration will be break in this case. default admin can use
1helpful
How to program to my new enternet connection
HEllo bro...
I don't know what model that use, however here the best explanation for you..
Preparation:
1. Username and password for router.
2.Username and password for provider internet.
3.Ethernet cable (rj45 connection)
5. Pc /laptop to setup router ( on step i'm referred to pc)
4. Web browser( more preferred to using internet explorer current version)
Step:
1. Plug Ethernet cable to router
2. Plug another end Ethernet cable to pcthat you are using to setup
(Now you have cable was connected between pc and router)
3.Switch on the router.
4.Open web browser. Or click here http://192.168.1.1
5.Some window will popup
6.Enter the username and password for router. If default( mean you don't change username or password,you can leave blank for username and fill password with "admin")
If still can't enter try search at google with your model and brand for username and password default.
7.After success enter, then using the wizard .
8. Fill the username and password for provider.
9.FInish.
For step 7th, to 9th, you can directly go setup internet connection( depend to model, sometimes it just type setup) where you will find ppp username and ppp password.. change it..
Good luck and be careful. sometimes you make it right but router need time to create new connection..
For the best go here Lynksis setup
Forgot username/password to access computer
Start the computer and tap F8 as it starts
Choose safe mode from the menu
Then log into the administrator account
Once logged in go to user accounts in control panel and remove your password
2answers
Having problems with the username and password to get to cox.net
You will have to contact cox for that information. I do not know where you are so I do not know the number. Cox can change your password or reset it for you. Been there, had the same problem myself one time.
Did my answer solve your problem?
Rate this as a Fixya if it is fixed.
I just bought a Router Linksys (model: WRT160N, serial# CSE01H201522). I installed the software into my deskop (Windows XP pro., IP= Comcast). I need it to use my laptop wireless (Dell inspiron 41200), I...
you need the default linksys router username and password in another words... correct?
Default:
username: <any>
password: admin
Any username can be used.
most of the time it is
username:administrator
password:admin
My emachine wouldnt let me log on even though im using proper username and password
Please elaborate more on what you mean by it would not allow you to log on discribe in detail what it actually is doing so I can know how to help you. For instant is it whirling at the bios screen and continuing doing this?
Grand Canyon Tech
Grand Canyon Tech
