Question about Beko Refrigerators
My Beko AB910S/1 is freezing the food on the bottom two shelves of the fridge. My wife commented it was making more noise than usual the day before this started to occur. ANy common faults?
    Problem Solver:
  • 13 Answers
The coldest part of your fridge is at the bottom. The bottom shelf will freeze before the top. Check the temperature with a thermometer - its should be about 6 degrees. Trying turning the fridge down a little. If this doesn't put things right chances are the thermostat has stuck and needs to be replaced.
Posted on Oct 22, 2013
3 Suggested Answers
  • 44 Answers
SOURCE: top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Posted on Aug 25, 2009
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
Please help ..my fridge is swelling on inside back wall where my shelves are protruding can anyone help please its a beko xx
Sounds like you have moisture in there and it's freezing causing swelling. Sounds like you need to defrost- really defrost your fridge.
Remove the food to somewhere else, FIRST unplug the thing, open the doors and use fans to blow air in there to melt any ice in the unit.
Be prepared to mop up lots of water.from the floor and keep emptying your pan under the fridge if it has one. This can take a whole day to get done and maybe a day and a night.
Oct 15, 2015 | Beko Refrigerators
My Samsung RL39WBMS fridge on m fridge freezer keeps freezing food. Why is this happening all the time and how can I prevent it?
maybe the fridge is set on a colder setting and if that's not it then stick it on the lower shelves and that might help from not freezing because are fridge is the same way when it is stuck by the coolant fan
Nov 02, 2014 | Refrigerators
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Fridge is freezing everything
Check the top of the inside of the fridge. There is usually a flap door mechanism that sometimes falls off or sticks. This regulates the temp in the fridge.
Jan 29, 2014 | Amana ABB2524DE Bottom Freezer...
My BEKO AB910 is freezing the food in the bottom two shelves of the fridge section. MY wife commented it was making a louder noise than usual the day before this phemonena started. Any common faults...
My fridge did the same. What I tried, first check the airflow vents to see nothing blocking them. Then I put in a thermometer, as I had increased the temperature dial a month previous. Cold air drops, so the temp was 36-38 F as checked in the morning. I turned down the freezer a tiny bit and upped the refrigerator dial a tiny bit. This corrected the problem for me.
Oct 22, 2013 | Kenmore 64802 Top Freezer Refrigerator
How do you stop ice building inside, at the back of fridge model Beko LA87 Larder fridge
It can be 2 things. One is that the thermostat is broken but then it will also freeze your food. The other reason is that it has lost part of its gas charge due to a leak on the system causing the unit not to reach temperature thus not switching of on the thermostat and building ice inside. Normally it is not economically viable to fix the unit.
Oct 06, 2017 | Refrigerators
My beko fridge freezers fridge keeps freezing
Your t'stat is probably bad. Should be easy to fix. At least it is freezing and not ruining your food from being too warm.
Feb 03, 2013 | Refrigerators
Fridge is freezing food
Make sure nothing fell below your crisper, deli drawer section. There are some air return vents below them and if they get partially obstructed would allow cold air to pool in the bottom of the fridge.
Make sure your freezer control did not get turned up too high.
Also you may want to check with the manufacturer as they did have some issues with some of the bottom mount models exhibiting this problem and they developed a repair kit for them.
Jun 11, 2010 | Amana ABB1927DE Bottom Freezer...
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
Refrigerators Logo
204 people viewed this question
Top Beko Refrigerators Experts
AJMAL KHAN
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
