Hp officejet 4630 printer won't print - Office Equipment & Supplies
5 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: printer - Hp Officejet Pro K8600dn
yeppers..you'll need a special driver either from the autocad program's website, for HP(or postscript) or you might find it at this link
Posted on Mar 30, 2008
  • 125 Answers
SOURCE: Master Reset
I don't have a 6310 but I do have 4 printers one of which is a 5610. I never bothered w/ a reset switch because I would just turn the printer off, then unplug everying for 2min. Then I would reconnect everything back. If it doesn't work, I suggest you uninstall the software and reinstall it again. Let me know if this helps.
Posted on Nov 12, 2008
Mhinhi
  • 10 Answers
SOURCE: HP Officejet 6500 will not print after sleep mode
Move the printer to a different location and keep it closer to the connected device (e.g. router) and away from large metal objects / other electromagnetic devices for stronger signal strength.
Posted on Mar 01, 2010
  • 5105 Answers
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Posted on Apr 19, 2010
Testimonial: "superb"
HP 4630 printer has error code oxc4eb827f
Welcome to the HP Support Forums!
I see that you're getting the error code: 0xc4eb827f on the front panel of your HP Officejet 4630 e-All-in-One Printer. I'd like to assist you today with resolving this error. The failure itself may be within the print system in your printer. Due to the error state there is only one support step that we can attempt, which is a Reset. Can you please follow the steps below.
Reset the Printer:
Without turning off the printer, disconnect the USB cable from the rear of the printer.
Remove the ink cartridges from the printer. *
Wait until a message to insert the ink cartridges displays. If you do not see a message within a few minutes, skip to step 4 to disconnect the power cord.
Disconnect the power cord from the rear of the printer.
Wait 60 seconds.
Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
Reinsert the ink cartridges, and then close any open doors on the printer.
If you receive a prompt to print a calibration page, do so.
If you disconnected the USB cable, reconnect it to the rear of the printer.
Try to print.
Copy to Hp support.. hope this will help
Jun 20, 2017 | HP Office Equipment & Supplies
How do I make the text larger on my office jet 4630 printer
This is the font setting in the application.
Make sure the font is at least 12.
(I am assuming the default settings in the printer setup.)
Oct 25, 2015 | HP Officejet 4630 Inkjet Multifunction...
How do i send a fax
User manual for hp officejet 4630
http://www.hp.com/ctg/Manual/c03909822.pdf
Chapter 6 contains all the setting details about fax.
The video showing how to send fax over telephone line
Oct 14, 2015 | HP Officejet 4630 e-All-in-One Printer
How do I copy 2 sided copy from 2 sided original on hp Officejet 4630 e- All-in-One Series
copy one side, then take copy and put back into blank paper try and then copy other side. trial and error will tell you how to put paper in paper tray but usually printed side up, top in
Sep 18, 2015 | HP Office Equipment & Supplies
Where do ink cartridiges go in an HP 4630 printer?
Download user guide from below link, you can understand how to load.
http://h10032.www1.hp.com/ctg/Manual/c03909822.pdf
Aug 25, 2014 | HP Officejet 4630 Inkjet Multifunction...
Does anyone know if I cancel the instant ink service online with HP for a little wile on my HP Officejet 4630 All-in-one, will I be able to use the ink that was sent to me thru the instant ink service
ok.... instant ink is a subscription service that sends you ink on a monthly basis according to how many pages you told them you print. that cartridges fit you machine, so yes you CAN use them, you paid for them upfront. there is no penalty for canceling, no annual fees, etc. The only thing you will lose is the recycling of your old cartridges..whoopie.....
Jul 04, 2014 | HP Officejet 4630 Inkjet Multifunction...
Wpa number for officejet 4630
setup menu options there is a readout of specs and print
Jun 29, 2014 | HP Photosmart 2575 All-In-One InkJet...
Hp officejet 4630 will not work with remanufactured ink cartridge
most wont.. they require the original expensive replacement cartriges..
Feb 02, 2014 | HP Office Equipment & Supplies
1,454 people viewed this question
k24674
