Question about Kenmore 64802 Top Freezer Refrigerator
My BEKO AB910 is freezing the food in the bottom two shelves of the fridge section. MY wife commented it was making a louder noise than usual the day before this phemonena started. Any common faults anyone knows of, any easy parts to replace?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
My fridge did the same. What I tried, first check the airflow vents to see nothing blocking them. Then I put in a thermometer, as I had increased the temperature dial a month previous. Cold air drops, so the temp was 36-38 F as checked in the morning. I turned down the freezer a tiny bit and upped the refrigerator dial a tiny bit. This corrected the problem for me.
Posted on Nov 10, 2013
  • 274 Answers
SOURCE: Freezer area smells and ice cubes and butter taste off?
It sounds like the ice maker if equiped. Remove Ice bin and clean out,and try a lite spray of bleach or vinegar (don't mix) If the smell is still happening and comming from ice you may want to install a inline filter.
Posted on Jul 26, 2010
bobicehouse
  • 1524 Answers
SOURCE: Freezer quit working on '04 Kenmore Trio Elite 25' bottom
Can either be starting components for compressor, or Motherboard.
Posted on May 04, 2009
rylee_smith
  • 8619 Answers
SOURCE: Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 03, 2009
  • 145 Answers
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
Posted on Jun 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Model 795 77244601
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Please help ..my fridge is swelling on inside back wall where my shelves are protruding can anyone help please its a beko xx
Sounds like you have moisture in there and it's freezing causing swelling. Sounds like you need to defrost- really defrost your fridge.
Remove the food to somewhere else, FIRST unplug the thing, open the doors and use fans to blow air in there to melt any ice in the unit.
Be prepared to mop up lots of water.from the floor and keep emptying your pan under the fridge if it has one. This can take a whole day to get done and maybe a day and a night.
Oct 15, 2015 | Beko Refrigerators
Fridge is freezing everything
Check the top of the inside of the fridge. There is usually a flap door mechanism that sometimes falls off or sticks. This regulates the temp in the fridge.
Jan 29, 2014 | Amana ABB2524DE Bottom Freezer...
My Beko AB910S/1 is freezing the food on the bottom two shelves of the fridge. My wife commented it was making more noise than usual the day before this started to occur. ANy common faults?
The coldest part of your fridge is at the bottom. The bottom shelf will freeze before the top. Check the temperature with a thermometer - its should be about 6 degrees. Trying turning the fridge down a little. If this doesn't put things right chances are the thermostat has stuck and needs to be replaced.
Oct 22, 2013 | Beko Refrigerators
Fridge is freezing food
Make sure nothing fell below your crisper, deli drawer section. There are some air return vents below them and if they get partially obstructed would allow cold air to pool in the bottom of the fridge.
Make sure your freezer control did not get turned up too high.
Also you may want to check with the manufacturer as they did have some issues with some of the bottom mount models exhibiting this problem and they developed a repair kit for them.
Jun 11, 2010 | Amana ABB1927DE Bottom Freezer...
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Aug 24, 2009 | Refrigerators
The refrigerator section is freezing. the temp adjust is at 1
This could be the actuator is not closing the door that controls how much cold air from the freezer is ciculated into the fresh food section. It could be something broken or there could be ice biuldup on the door itself, not allowing the door to open or close.
Nov 12, 2008 | Refrigerators
Kenmore 64802 Top Freezer Refrigerator Logo
77 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
