Question about Samsung Tab Tablets & eReaders
Finding router ssid
I cant find myy ssid code on my router where would i look
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 173 Answers
The SSID is not an indication on a label on the Wi-Fi device, it is the identifier broadcasted by the device ; to find it, two possibilities :
1) if you remember its password, access the setup of the wi-fi device (your router) ; this is done thru any computer connected to the router : simply enter the IP adress of the router (try 192.168.0.1 or find the right one using the ipconfig command) in the browser, and navigate to the wi-fi settings.
2) if you can't access the router, go to the wi-fi settings of your smartphone or tablet or netbook, and find he way to show the list of the access points available in the surrounding - yours is probably the first one (the stronger signal) in the list.
Good luck.
Posted on Oct 23, 2013
How to get connected to wi fi
To connect to a Wi-Fi network with a hidden SSID, select Add Wi-Fi network from the settings. Then manually type in your SSID and password, and select your network security type. Select Save when finished. Now you can browse the web through your Wi-Fi router or connect to other network devices
Sep 18, 2016 | Amazon Kindle Touch Screen Wi-fi W/...
Where do i find my ssdi number for my tablet?
If you tablet is acting as a hotspot, then you will see it on any device trying to connect to it (i.e. a computer). The SSID will be whatever you have assigned to it, normally through an application such as Portable Wi-Fi. Mine normally says it is an android connection.
SSDI's are the names of the wi-fi routers. If you are trying to connect to one, then you would turn on wi-fi and look at the list of what is available. As long as you have the proper password, you can connect to that router SSID with your tablet.
Mar 31, 2015 | Tablets & eReaders
How do I find my SSID number on Acer Iconia One 7
The SSID number is the identity of the router you are trying to connect to, not your computer.
Turn on the Wi-Fi under settings and look at the list of SSID's there.
Feb 15, 2015 | Acer Iconia One 7 B1-730HD-11S6 7-Inch HD...
What/where is ssid number on galaxy tab3?
The SSID is the Name given to the Wireless-Connection you want to join. Browse your Router-Configuration for these information.
Jul 20, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Need to find SSID
Look on the side or bottom of the modem/router. Generally there is a white label with SSID and password. The SSID is generally set to 'broadcast,' so doing a network scan on your tablet should come up with the SSID on a list, but if that is not the case, or if you pick up multiple SSIDs (as in an apartment building or condo), then check the label. You will have to check the label for the password, anyway. Have fun!
Jul 16, 2014 | Maylong Tablets & eReaders
How can i connect my samsung tablet to my wireless internet?
I assume you are either unable to see your network listed or when you select your network from the list of active Wi-Fi Networks within range of you device and depending on security level no password or the Security Key you have doesn't work. First, make sure you have a few pieces of information: 1) The SSID or name of the network 2) The security type and password 3) If no DHCP service you'll need the ip address subnet and an available address for your device, ip address of the gateway/router, & ip address of the DNS servers. Usually the router provides DHCP and provides all of the addressing information.
Typically, you are provided the SSID and a security key or password. On your tablet open settings and turn Wi-Fi in necessary and look for your SSID in the list to the right. If your SSID is not shown verify the name, that the router is on and you are within range. Be aware of obstructions between you and the router. My Pool House is a virtual dead zone due to some electrical wiring on the wall it shares with the office. The router is less than 5 feet away, but the signal is unreliable. If everything is working and still no SSID on list, then it may be hidden. Simply, select Add Wi-Fi Network at the bottom and enter the SSID (Netgear987), security type (WPA OR WPA2 typically) and the password (PASSWORD maybe case sensitive). If it connects and fails to obtainan ip address or just drops it may indicate another layer of security that requires each device MAC ID is added to the list of authorized devices for that router. Your MAC ID is listed on the Settings_About Device_Status screen WiFi MAC Address: (F7:C7:AE:78:E6:FC). Sounds like a lot but usually verified SSID and password do the trick. Good Luck
Apr 29, 2014 | Samsung Tab Tablets & eReaders
Where do i find my ssid
The SSID is the broadcasted "name" of your wireless router. It will be something like "2WIRE199", "NETGEAR99", or similar if not changed from default. It is NOT a part of your tablet or ereader, it is a part of your wireless router.
Apr 10, 2014 | Tablets & eReaders
Ssid number
Its the NAME usually in the letter from your broadband provider, a seperate card or a sticky label on the back or base of the router
Wireless Network
Name (SSID) WillyWombat785837
Key: 1234ABcD
Click on the SSID in your list of wifi networks and put in your KEY remembering to put the Case in correctly when it asks for password (confusing, wish they asked for key rather than password)
Good luck
Dec 25, 2013 | Amazon Kindle Fire HD
Rtresch@hotmail.com
Go to your NETWORK screen and touch your old router SSID (Name) and select FORGET.
If that is not available select RESCAN.
Now look for new router SSID and input new router KEY when it asks for Password.
Nov 24, 2013 | Amazon Kindle Fire HD
I have an Arnova 9G2 tablet and a Netgear WNDR3300 wireless router. How do I add the wi fi network to the tablet? I donot have any SSID for the router.....
Without the SSID, you can't add the Arnova tablet to that network. The default SSID for the WNDR3300 is NETGEAR. You'll need to log into the router (preferably with a device on the wired network ports). Make sure that the wireless network is on and broadcasting its SSID for the 2.4GHz network. Confirm the password (passkey) and the encryption protocol. (The default user name and password for the router is in the manual, see page 19 (page 23 on the PDF) of http://www.downloads.netgear.com/files/GDC/WNDR3300V1/WNDR3300_SM_12Nov07.pdf . )
The tablet will look for available networks after you go to the Settings menu on the Home screen. Go to the Wireless & Network. Then turn on the Wi-fi (if needed) and then go to Wi-fi settings. Then find the SSID and enter the password and encryption type.
I hope this helps.
Sep 23, 2013 | Tablets & eReaders
Tablets & eReaders Logo
52 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
