Question about Drills
How to replace electrical cord on Bosch 11264EVS
2 Suggested Answers
H2_Brad
  • 425 Answers
SOURCE: I have a bosch 11264EVS hammer drill that just stopped working. I checked the brushes and have continuity to the rotor. Is there somethingelse I need to check/replace before I hunt sown a service ce
Did you have continuity from one brush to the other? Some Bosch tools use "pop off" type of brushes. When they get worn down a spring loaded center pops out and keeps you from damaging the armature. If they are fine check cord continuity. If the cord is fine it is most likely the switch. You can test the field for continuity also but those rarely ever fail. Here is the parts diagram.
Bosch 11264EVS diagram
Posted on Aug 25, 2012
How do I replace brushes on this drill?
[PDF]Hammers and Hammer Drills - eBuild
www.ebuild.com/ImgRepos%5C2010%20Hammers.pdf_06072010_110..See pages 46-49,. 184-214 for hammer drill accessories. BOSCH. H a m m e rs a n d.... 11250VSRD - 3/4" SDS-plus® Rotary Hammer .... technician can quickly replacethe brushes and cord .... 11264EVS - 1-5/8" SDS-max® Rotary Hammer.
Oct 20, 2015 | Bosch 11264EVS 1-5/8 SDS-Max Rotary Hammer
Bosch GSH 10 C not. starting i replaced the brushes and the power cord is good even the switch works okay.
One of the four slide contacts on the electric field can be worn or broken .!!
measured switch and electric assembly for shure.
suc6
Feb 23, 2015 | Bosch Saws
I have a bosch 11264EVS hammer drill that just stopped working. I checked the brushes and have continuity to the rotor. Is there somethingelse I need to check/replace before I hunt sown a service center?
Aug 24, 2012 | Bosch 11264EVS 158 SDSMax Combination...
I have a shu43 bosch dishwasher and the whole machine is dead. No power. The circuit breaker is good but I would have to pull the dishwaher out to check the outlet. Is there an internal fuse?
There is no internal fuse (at least I've not seen or replaced any) on Bosch dishwashers. The most typical problems for Bosch are: 1) one of the power cord connections to the internal wiring is corroded and doesn't make a contact; or 2) the power button has failed.
The number one is so far the most common problem. To check: Turn off the power to the dishwasher by any means necessary. Remove the kick panel on the bottom. There should be a small metal box with power cord and 2 or 3 wires coming into it. Remove screw(s) holding the cover on that box. There should be 2 or 3 wires connected to the power cord wires by wire nuts. Any burnt insulation or wire nut will be the problem area. Cut burnt wires, remove 1/2" of insulation and clean of both connecting wires to bare copper. If you have an electrical contact grease - apply to copper. Install new wire nut.
Good luck,
Vlad with First Choice Appliance, Sacramento, CA
Jun 28, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 4000 table saw run backward and slowly
I had the same problem with the Bosch 4000.
Changed the field for a new one...end of problem
Apr 28, 2011 | Bosch 4000 - 07 Electric Table Saws
My bosch maxx laundry machine wont turn on
If you dont have power to the machine, your electric cord from machine to power point is broken. To check this turn on at power point and at machine hold cord in hand and shake if machine makes any noise you have a broken lead which can be cut at break and fixed,but better replacing with new cord Hope this helps
May 25, 2010 | Washing Machines
How to wire bosch oven pke691e02e
I guess you mean installing a plug and cord on the unit or do you mean hardwiring it from the breaker panel?Either way open up the access panel run your cord or wire thru the strain-relief and your white wire or smaller of the three wires goes to the "N"(neutral) terminal on the unit the other two wires,more than likely colored red & black go to "L1" and "L2" load 1 and load 2 those can be on either terminal after thats done arrange your wire and tighten the strain relief and replace your access cover
Jul 14, 2009 | Bosch Appliances 27 in. Wall Oven Electric...
Drills Logo
100 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
