Question about EuroTech Washing Machines
Where to buy the bearing and seal for drum on front loading EWF272EL washing machine
    Sergeant:
    Champion:
  • 257 Answers
It seems no bearing kit for this model. The drum bearing is hard to replace and seal it properly if you do not have special tool to do it.
Posted on Oct 23, 2013
Testimonial: "Thank you , but i found replacement seal and bearing in the U.K with instructions"
  • saint_sin872 Oct 26, 2013
    Thank's for the responce , took tub out , removed bearings , went to Princess auto , found replacement bearings , total cost $15.00 put everything back together , works like a charm .
  • 139 Answers
SOURCE: bearing noise
Hi there im the wash docotor. With your zanussis once you have removed the back half of the pannel and the top pannel. you will have to then detach the motor wire plug. then the heater wires and also the there is a sensoer on the side of the drum that also has a wiring connection. Also detactch the earth wires Then here come the tricky part. if you look on the top of the drum you have a rubber pipe connected to it comming from the washer draw detach that its easy. Then you have to dicconect the door seal from the front of the machine by the door (do not dissconect from the seal from the drum as you dont have to . Then disconnect the the drain hose. once this is all done you have to disconnect the legs, from the drum side. these are easily done as the pegs come out easily if you push in the pips from one side you can either knock them out with a hammer but it is best to pull em out with either some long bent nose pliers or gripping em in such a way with a monkey ranch Best way og getting the drum out is once you have done all that is to turn the machine onto its back and lifting the casing off leaving the drum on the floor.
Posted on Oct 10, 2006
BIKER T
  • 909 Answers
SOURCE: suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Posted on Aug 16, 2007
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
Krazytech
  • 725 Answers
SOURCE: WAsh machine drum bearing removal
check out the tommy tool on youtube .it will show you how to do it even if you don't buy the tool...
http://www.youtube.com/watch?v=F3Wrq6Yxra8
let me know krazytech
Posted on Aug 13, 2008
SOURCE: My HE2 front loading washing machine smells
remove the front bottom panel.
there is a trap down there just before the pump. mine was a cylinder with a handle to unscrew the cap/filter.
clean this out every 6 months..
Posted on Aug 25, 2009
How do I fix my Kenmore front load washer ?
your drum bearings have gotten water in them due to a bad lip seal on the back side of the inner drum,if you can buy the bearings and lipseal you can tear it down and replace these rusty noisy bearings,and leaking seal
Aug 26, 2012 | Washing Machines
Spin Cycle is very loud on front load washing machine
See here
How to fit a Bearing in a Washing Machine | Appliance Repair Help
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
From
DIY washing machine repairs (2)
for repairs check
Sep 04, 2008 | Washing Machines
Indesitw123 front load washing machine making very loud noise when spinning
The noise you can hear is the drum bearings, the seal between the drum and bearings has failed and let water into the bearings which has destroyed the bearings.
Mar 10, 2012 | Indesit Washing Machines
Cause of noisy spinning
your drum bearings have gotten water into them from a defective inner drum lip seal,now you need to tear down the machine and replace the lip seal and also replace both inner and outer drum bearings
Apr 18, 2010 | Zanussi ZWF1430W Front Load Washer
The drum seems to run crooked and rubs...
You can buy new drum Spider which has bearing fitted check cost 1st...
Nov 17, 2009 | Zanussi FJS1225W Front Load Washer
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Detergent build up
    try to wash clothes with pre-wash program
    Feb 17, 2009 | Candy CN146 Front Load Washer
    The drum on my front loading wash machine is very loose
    I recently replaced my bearings and seal for about $60. I could have bought the bearing cheaper online but I was in a hurry. If you do a search online there are several blogs about replacing these bearings. Here is a link for a service manual for $ 18 http://www.repairclinic.com/SSPartDetail.aspx?PartID=659075&PPStack=1 You pretty much have to disassemble the washer but it is not really that difficult depending on your mechanical experience. The manual should lay it all out for you. There are 2 notes on these frigidare washers: Sometimes the spider arms on the inner drum break and you will have to buy the complete inner drum assembly. I have heard they are warranted for 25 years, but they most likely will not warranty them if the owner does the work. Also, Frigidare does not list the bearings seperately, but you can buy the bearings from a bearing supply house, online or in your town. The bearing numbers are on the side of the old bearings when you remove them.
    NOTE- The bearings that came out of mine were 6306-2Z and 6307-2Z (shielded) I replaced mine with 6306-2RS and 6307-2RS (sealed). The significance is that the shielded bearings offer minimal protection from water where the sealed bearings are built to seal out water/contaminants if you new seal ever fails. The seal I used was a CR15939 rubber coated seal.
    If you need any other information, let me know
    Hope this helps
    Jan 17, 2009 | Frigidaire ATF6000ES Front Load Washer
    LG Top Load Washer
    this could be a drain hose loose or broken if the leak only occurs during rinse. If it leaks all the time, could be a broken outer drum or worn tub seal.
    Hold inner drum and turn bothways. If it turns bothways, you have a bad bearing, and hence, a bad tub seal. If it turns in one direction only, bearing's good; but tub seal could still be bad.
    Jul 17, 2008 | LG WFT1071TP Top Load Washer
    Indesit wash machine drum bearing
    depends on the model that you have some indesit machines you only have to undo the spider and others can be a bit of a pain because you have got too split the drum would recomend an engineer regards jason
    Jun 13, 2008 | Indesit W 123 Front Load Washer
    Washing Machines Logo
    49 people viewed this question
    Top EuroTech Washing Machines Experts
    shaun taylor
    richie46
    Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
