Question about Panasonic Panafax UF-9000 All-In-One Laser Printer
How can I find the uf 9000 ip address from the printer controls? When I try to install the driver, it does not find the printer on our network and I don't know what IP address was assigned to it through DHCP.
  • Renee Batey
    Renee Batey Oct 22, 2013
    I am the IT geek. We bought the printer from ebay and it apparently already has an ip address not on our subnet because my router doesn't see it. I want to reset it, but hey, thanks for being so helpful. Hopefully I can get a real answer on here instead of snarky sarcasm next time.
  • Panasonic Master
  • 7,993 Answers
If you are the network supervisor you know or should be able to know the IP address of every device. If you are not the supervisor why would try to install anything on the network? You should talk to the IT geek who supervises the network.
Posted on Oct 22, 2013
  • 2 more comments
  • Renee Batey
  • k24674 Oct 22, 2013
    Here is a link to the manual.http://zzz.physics.umn.edu/_media/comput...
  • Renee Batey
    Renee Batey Oct 23, 2013
    Well thanks again but I downloaded that first. Unless I completely missed it, there's no where in the manual that tells you where to find and reset the IP address on the machine. We did not get a disk with it so I had to download the driver and installation package from Panasonic
  • Renee Batey
    When I run the installation and it scans my network, it does not come up with any Panasonic models so asks me to input the IP address of the printer I'm installing, which leads me to this issue.
SOURCE: DP-190 Network Printer
I succeeded in printing via network to the Panasonic Workio DP-190.  Here is a brief summary of what needed to be done...
* HP laptop w/ Windows XP SP2 installed * requires LPR support via "Print Services for Unix" to be installed from Windows Components (http://technet.microsoft.com/en-us/library/bb457002.aspx) * Installed using GDI printer driver (http://panasonic.co.jp/pcc/products/en/mfp/download/dp-190/list.html)
During the GDI installation I choose a 'Network printer' and the printer was already setup for proper IP addressing, etc...
I created a new printer port of type LPR, doing so required me to input the printer's IP address and a queue name -- the queue name was left blank.
Hope this helps, John
Posted on Mar 30, 2008
tech435
  • 284 Answers
SOURCE: Network Printing
what you need to do is use a router and set the gateway to the machine and then you can comunicate with using the proper drivers
http://panasonic.co.jp/pcc/products/en/mfp/download/dp-190/gdi/eng.html
Posted on Sep 25, 2008
SOURCE: Need IP address of Workio dp-2330
"share" it on your server, then on each PC go to "add printer", select "network Printer", browse your network, and select the printer.
Posted on Mar 21, 2009
SOURCE: Dear Sir,need ip address
i want to configure a network printer on lan but i do not know how to assign an ip address to the printer panasonic dp-8016p
Posted on Jan 04, 2010
  • 224 Answers
SOURCE: Attempting to set up a Panasonic DP-1520P as a network printer
printing from mac requires a postscript driver and security utility from the panasonic website. if printing post script the device will need a postscript key and firmware. a technicians job i'm afraid
Posted on Mar 30, 2010
Loading software for network asking for IP address
Usually you can run a report on the printer that will show you the IP address it is using.
Mar 26, 2014 | Panasonic UF-8200 Panafax Panafax UF-8200...
Uf 9000 ip address
Just wondering if you've found a solution. I'm trying to do the same thing on our uf-9000. Any help would be appreciated.
Panasonic technical support is not good.
Oct 21, 2013 | Panasonic Panafax UF-9000 All-In-One Laser...
Free scanner driver for UF 9000
http://www.panasonic.net/pcc/support/bfax/uf-9000/index.html
Jun 23, 2012 | Panasonic Panafax UF-9000 All-In-One Laser...
How to install hp 2420 on network
First Configure IP Address on Printer and make sure all Other PCs are in same IP range.
Now goto Computer on which you want to install Printer. Insert CD and start Installation. It will Ask for Installation Mode You Must Select " Network" means your printer is connected to network. then HP installation will find printer in network automatically. and install.
Option 2 :
In control panel , printer and faxes
clik add printer, select network printer, select create TCP IP Port ; give IP address of printer, click next and slect printe driver. it will install printer.
Mar 11, 2010 | Televison & Video
I need the drivers for the Panafax UF-9000
You can download the drivers and software for
Panasonic UF-9000 Business Fax (including Panafax Desktop) from here:
Nov 23, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Dell 5100cn as a netwok printer via my LAN
Connect it to the router. It should hopefully be set to get an ip address from the router. On each computer that you want to print from you need to select Add Printer in the Printers section of Control Panel and select a "Network Printer". You should be able to either browse for it or put the ip address in (depends on the router, printer settings etc). It should then ask you for the drivers etc.
If stuck there is a comprehensive how to on the Dell website.
Nov 20, 2009 | Dell 5100cn Laser Printer
How do you set the IP address for network use?
Go to Start>> Control Panel>> Network Connections>> Right click your Local Area Connection and select Properties. Scroll the list for the entry titled: Internet Protocol (TCP/IP). Click the entry and select Properties. Under the General tab, tick the box titled: Use the following IP address. Enter the IP address and Subnet mask that you would like to use. eg - IP address = 192.198.0.1 & Subnet mask = 255.255.255.0.
Jun 24, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Panasonic uf-9000
Function
71
set
keep pressing set until you get to ip address
key in with the keyboard
Mar 09, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Network printing
do you have the driver from workio.com
do you have the ip, subnet mask, gateway all installed properly,
try a cross over cable to test the parameters are working if still more issuses re-post same thread
Jan 15, 2008 | Panasonic Panafax UF-9000 All-In-One Laser...
Panasonic Panafax UF-9000 All-In-One Laser Printer Logo
122 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
