Question about 98-99 Cadillac Seville 32v North Air Intake Duct
How do I manually relearn my key - 98-99 Cadillac Seville 32v North Air Intake Duct
    Problem Solver:
  • 12 Answers
Google
Posted on Oct 29, 2013
After completing the 45 minute relearn procedure for a 2004 Pontiac Grand Prix message center Now says system not programmed
Relearn for what ? Anti theft system PK3 ? The relearn procedure is three 10 min. procedures for a total of 30 min.
30-Minute Relearn Procedure
Use this procedure after replacing the following components:
The passkey III (PK3) keys
The BCM
The PCM, see important above
Important: This procedure is not available on vehicles equipped with option code (Z49).
If replacing a BCM with an GM SPO Replacement Part, perform the procedure to setup a new BCM prior to the 30-minute relearn procedure.
  1. With a master passkey III key, turn ON the ignition, with the engine OFF.
  2. Observe the STARTING DISABLED DUE TO THEFT message on the drivers information center (DIC), after approximately 10 minutes the STARTING DISABLED DUE TO THEFT message on the DIC will turn off.
  3. Turn OFF the ignition, and wait 5 seconds.
  4. Repeat steps 1-3 two more times for a total of 3 cycles or 30 minutes.
  5. Important: The vehicle learns the key transponder information and/or passwords on the ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
  6. With a master passkey III key, start the vehicle. The vehicle has now learned the key transponder information and the PCM has now learned the fuel continue password.
  7. With a scan tool, clear any DTCs.
Dec 07, 2015 | Pontiac Cars & Trucks
Where is the body control module located in 2002 gmc envoy?
It's under your back seat. See here for picture http://www.ebay.com/itm/like/261068608953?lpid=82
Here is the relearn procedure which you have to perform so the new BCM will recognize your key and start the car:
For those vehicles that use a BCM, the BCM can learn the resistance value of the existing key by using the relearn process. In order for the vehicle to start, the BCM (as well as the Passkey module in other vehicles) must identify the resistor pellet in the key, then the BCM sends a password to the PCM. If this password matches the password stored in the PCM, the system enables fuel delivery. So you can see that if either the BCM or PCM are replaced, a relearn procedure is necessary. This same relearn procedure can be used if an ignition key with a different resistance value is used to replace the existing key. Before beginning the relearn, make sure there is a fully charged battery in the vehicle, and both the BCM and PCM are properly powered up and in communication with each other. Now you're ready to initiate the relearn procedure.
1. First, insert the ignition key and turn the ignition switchto the "On" position (Do not start the engine). Leave the switch on for 11 minutes. The security light may flash or be on steady during this 11 minute period. Make sure the light is no longer on or flashing before proceeding to #2 .
2. Turn the ignition switchoff for 30 seconds.
3. Turn the ignition switchto the "On" position (as in step #1) for 11 minutes again.
4. Turn the ignition switchoff for another 30 seconds.
5. Turn the ignition switchto the "On" position for 11 minutes a third time.
6. Turn the ignition switchoff for 30 seconds one final time.
7. Turn the ignition switchto the "On" position one final time and wait 30 seconds.
8. Attempt to start the engine. If the engine starts and runs normally, the relearn is complete. If the engine does not start, check for trouble codes and address them before attempting the relearn procedure again.
You can pick one oif these up for $20 or less at a junkyard. For those vehicles that use a BCM, the BCM can learn the resistance value of the existing key by using the relearn process. In order for the vehicle to start, the BCM (as well as the Passkey module in other vehicles) must identify the resistor pellet in the key, then the BCM sends a password to the PCM. If this password matches the password stored in the PCM, the system enables fuel delivery. So you can see that if either the BCM or PCM are replaced, a relearn procedure is necessary. This same relearn procedure can be used if an ignition key with a different resistance value is used to replace the existing key. Before beginning the relearn, make sure there is a fully charged battery in the vehicle, and both the BCM and PCM are properly powered up and in communication with each other. Now you're ready to initiate the relearn procedure.
Dec 13, 2014 | 2002 GMC Envoy
Did the relearn for the master window switch - window goes down good but then stops 1 inch from closing completing on the way up. You have to manually close it the rest of the way? What do you do to
Start here... With the key on, engine off, press and hold the window switch in the down position for 5 seconds after the window reaches the bottom of its travel. Then hold the window switch in the up position for 5 seconds after the window reaches the top of its travel. This will relearn the positions and the the window should operate as desired.
Nov 25, 2014 | 2009 Lincoln Navigator L
S class mercedes 2.8. Changed battery and now only cranks over but does not start. Shows "Start Error" messgae on dash board
Your computer in the car needs to relearn your key signal. It might tell you how to relearn in your manual. But I would just turn the key on without starting and let it set for 5 min. Turn it on and off a couple more times for like a min each then try to start the car.
Jan 08, 2014 | Charging & Starting Systems for...
How do you reset anti theft in 2003 cadallic deville
Unfortunately sounds as though you have a non transponder key. Or it needs to be relearned . With out the tech 2 , you have to do a manual relearn. takes about 30 min
Apr 18, 2013 | 2003 Cadillac Deville
Engine willnot start
Try this,,,,relearn steps are crank it ,leave the key on 5 min,turn key off and repeat.
sometimes takes 2 or 3 times to relearn
Dec 23, 2012 | 2003 Cadillac Seville
I need 02 ford to relearn code in as-tcbm, getting incorrect key code error in theft module, i have no manual for as-tcbm
there is a factory ford key in the astcbm. I doubt it needs to be relearned most likely a connection issue,or the ring from the astcbm isnt mounted correctly.
Jul 29, 2011 | ASTCBM Generic Factory Remote Start ByPass...
Engine want start and I get a Starting Disabled Due to theft system message.
2005 grand prix battery went dead then the car would not start
received message starting disabled due to theft system
How can I reset myself
Apr 09, 2010 | 2004 Pontiac Grand Prix
I replaced key and tumbler and ignition switch in my 2002 chevy impala and now it wont start.why?
usually when u replace that you need to relearn the security system for it to start,,,,try to turn the key till the starter hits then release and leave it in the run position for 10 minutes,then turn the key off for 30 seconds and then repat this 3 times and then after the last time turn the key off for 2 minutes and then try to start it,,thats the manual way to relearn the key abd lock,,if that dont wokr take it to the dealer
Oct 12, 2009 | 2002 Chevrolet Impala
98-99 Cadillac Seville 32v North Air Intake Duct Logo
Top Star Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Star Vehicle Part and Accessory Expert? Answer questions, earn points and help others
