Question about Analyse-it Software Analyse-it Standard Edition
Analyse it activation code - Analyse-it Software Analyse-it Standard Edition
I can't change the time , not terracing my steps
You really have to sync up with a smartphone before you can use the watch.
Then gradually it starts working. After about 5 days it has learned your rhythms , if you keep it on at night it also analyses your sleep.
But without a smartphone, it's really hard to use.
Mar 31, 2015 | Fitbit Charge HR Heart Rate and Activity...
Code p1744
Take it 2 a respectable mechanic & they will plug an analyser into your cars computer & the analyser will tell them whats wrong - this service is usually free!!!! Could be something minor.......
May 17, 2014 | 1998 Mercury Mystique
Engine light flashing
Normally when you experience this problem this indicates that you have an engine malfuntion. your engine will not want to accelerate and give you unstable accelaration like jerking every so often.
I had this problem before with my Chysler van and I located the problem to the Exhaust Gaz Recycling unit located on the exhaust manifold. This unit allows the unburned gas of the exhaut to be burned again. It is a valve that is activated by the oxigen sensor.
I took the defective EGR apart and found that the diode connected across the activating coil that operates the valve to be defective. It is an expensive part for some to replace but do not attempt to replace it by a used one...otherwise your problem will reoccur. A good car dealer should be able to analyse your problem by checking your engine with his analyser/trouble shooter.
Feb 13, 2014 | Chrysler 2002 Concorde LX
CCD CODE ON CHRYSLER SEBRING CONV JXI
put car on analyser--dont doit at a dealer-they dont hav updated software
Jun 03, 2013 | 1999 Chrysler Sebring
How to activate auto chkdsk after improper shutdown
To do that:
1. Click Start button
2. Click Run
3. Type CMD
4. Type "chkdsk/ f" at the command prompt
CHKDSK Starts when Windows restarts from an improper shutdown.
Chkdsk is part of Windows - it is a utility to analyse and fix HD errors.
Hope this helps!!! Let me know if you need more help
-Nadeem
Dec 25, 2012 | Computers & Internet
Codes diagnostic 2000 oldsmobile intrigue
not on modern cars ,vehicles older than 1995 then yes but not newer ones
Dec 24, 2011 | 2000 Oldsmobile Intrigue
I HAVE 1992 f150 RUNNING RICH, I HAVE REPLACED NEW BATTERY, CHECKED GROUNDS, USED CODE READER (TELLS ME MULTIPLE CODES EVEN CODE 998 ENGINE RUNNING IN FAILURE MODE).
02 sensor shud be tested as well as some others since car is 20yrs--computer nay be failin--1st put it on a tech ll analyser that runs a data stream for precise solution and dont replace any parts until
Aug 08, 2011 | Ford F-150 Cars & Trucks
No dial tone and I got the message " analyse en cours "
analyse en cours is french for analyze in progress.It might be that you have to re enter in the security code for the handset to sync up. also to change the language from french to english press feature *501
Jan 11, 2010 | NorStar T7406 Cordless Phone
Computers & Internet Logo
37 people viewed this question
Top Analyse-it Software Computers & Internet Experts
David Payne
David Payne
Are you an Analyse-it Software Computer and Internet Expert? Answer questions, earn points and help others
