ONE GAS EYE ON DACOR GAS RANGE DOES NOT IGNITE. THE IGNITER WORKS WHEN CONTROL TO OTHER EYES ARE TURNED ON BUT NOT WHEN THE CORRECT CONTROL IS USED.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Your peazo-electric igniter is not working. It could be when the distance form the tip of the igniter is too far from the frame of your burner. Adjust it.
Posted on Nov 03, 2013
My Maytag gas oven will not come on. Range eyes will work so gas is coming to range.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 21, 2011 | Maytag Kitchen Ranges
Dacor gas range. I'm trying to figure out why it
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 01, 2010 | Dacor Preference RSD30 Gas Kitchen Range
Igniter keeps clicking
looking same proable did fix it and what ddid you do
May 31, 2010 | Whirlpool SF367 Gas Kitchen Range
10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
Igniter problem on Dacor grill
After flame ignites you have to turn knob back to the "ON" position only.
Nov 07, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven control, possibly thermostat or oven selector switch
my dacor ER36G oven will not ignite. The top range works perfectly. When I turn on the oven, I don't even hear the gas or the ignition sequence as I used to. The heat preset light just blinks and the oven will not engage. I have reset the circuit breakers just in case, but nothing works.
Dec 07, 2008 | Whirlpool Kitchen Ranges
The oven doesn't work ,the ignator doesn't light up. no gas coming
The technical jargon is,.....:
In order for your gas oven to work this is what has to happen: 1. when you turn on the oven, the range sends 120 volts to the glow bar igniter. 2. as the igniter heats up (and starts to glow) it starts using more electricity. 3. when the electric use reaches a set amount (say 3.2 amps) the range knows the glow bar igniter is hot enough to ignite the gas, so it then releases gas through the gas safety valve. 4. when the thermostat tells the oven controller that the temperature has been reached, the control cuts power to the igniter, cutting the amp draw down, causing the safety gas valve to close. 5. process repeats to hold oven temp until you turn off oven.
So,..........the solution is:
most likely your oven igniter burnt out. Find your model number, usually on the range frame just behind the lower drawer or broiler drawer (depending on if it is a self clean gas range or not) and order the correct igniter and replace it.
Nov 02, 2008 | Kitchen Ranges
Tappan gas stove
I had the same problem, and finally took the rings and the covers off of the burners. I used an old toothbrush to clean everything really good, and then used a vacuum ( or you can just close your eyes and blow really hard ) around the burners. If there is a build up of junk or if a pot has ever boiled over, sometimes junk can get lodged in the little igniter and this prevents it from lighting.
Jan 14, 2008 | Tappan TGF320 Gas Kitchen Range
Igniter
Does the knob control both the gas and spark, try turning on the knob only, if it starts to spark right away then it is possible that the switch is bad. because most of these units are designed where you turn on the gas then push in and hold the knob to ignite then release and spark should stop.
Dec 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Computers & Internet Logo
David Payne
David Payne
